MORIMOTO XB LED HEADLIGHTS 16+
Discussion in 'Lighting' started by eledobleu, Feb 13, 2019.
Thread Status:
Not open for further replies.
  1. Aug 20, 2019 at 7:32 AM
    #301
    ZackRP
    ZackRP New Member
    Zack
    Wyoming
    2016 Magnetic Gunmetal Metallic Platinum
    Tinted Windows, Baja Designs LED Fog Lights, EGR Matte Black Bug Guard, SCS SR8 Gunmetal wheels, 295/70/18 Nitto Ridge Grapplers, 3/1" Readylift Kit, Morimoto XB Headlights, Viper Smartstart Remote Start, Kobalt Low-Profile Toolbox, Husky X-Act Contour Floor Mats
    It seems plenty flexible to bend there so I'm not sure it'll crack but at the price point it should be spot on. I've also noticed when I was driving with them last night that the light pattern of the drivers side is 8-10 feet lower on the road than the passenger side. I understand it should illuminate the right hand side more than the left, but it's a big difference. I don't have a picture of it but will get one tonight. It's strange because at ~15 feet it looks pretty close to my retrofit beam pattern. Here's the beams at ~15 feet.
  2. Aug 20, 2019 at 7:33 AM
    #302
    ZackRP
    ZackRP New Member
    Zack
    Wyoming
    These are the actual production lights they have for sale.
  3. Aug 20, 2019 at 7:43 AM
    #303
    YotaMan
    YotaMan Silver Bullet
    Colorado Springs
    2021 Platinum
    Mine are like this as well...will remove and readjust when I get back in town
  4. Aug 20, 2019 at 7:47 AM
    #304
    ZackRP
    ZackRP New Member
    Zack
    Wyoming
    How are you planning to adjust? I tried to push that drivers side assembly up a little while tightening the screws down and it didn't help so I'm going to have to figure something out. If I can't fix it I might have to go back to my retrofits, not sure that's something I can handle forever haha.
  5. Aug 20, 2019 at 7:48 AM
    #305
    Danimal86
    Daniel
    Sacramento, CA
    2017 White Tundra SR5
    You need to lower your right beam. The slanted piece of the cutoffs should be level.
  6. Aug 20, 2019 at 8:04 AM
    #306
    ZackRP
    ZackRP New Member
    Zack
    Wyoming
    Yeah gotta figure out how to do that. I didn't notice if the little slot to manually raise/lower one is there on the new assemblies but I'll have to check it out. Here's hoping it's that easy!
  7. Aug 20, 2019 at 8:48 AM
    #307
    NCTundra1980
    NCTundra1980 New Member
    Stephen
    2019 SR5
    No adjustment screws?
  8. Aug 20, 2019 at 8:57 AM
    #308
    Stumpjumper
    Stumpjumper Not a new member
    Fate, Tx
    2017 Tundra TSS 4x4
    Lift should not really matter unless you changed the rake.
  9. Aug 20, 2019 at 10:40 AM
    #309
    19Platinum
    19Platinum New Member
    2019 Magnetic Gray Tundra Platinum
    These look amazing! Just curious if they would outperform my oem LED's on my 2019 Platinum............
  10. Aug 20, 2019 at 10:40 AM
    #310
    MMichaelJJ
    MMichaelJJ New Member
    14 Platinum CM
    Shouldn’t the cutoff heights be the same for both lights? The low cutoff for both lights should be the same, just like the high.
    The picture makes it look like the high cutoff on the drivers side is level with the low cutoff on the passenger side.
  11. Aug 20, 2019 at 11:16 AM
    #311
    YotaMan
    Colorado Springs
    2021 Platinum
    What needs to be done is just an individual lamp height adjustment (or lower) to make the 2 beams even. The "step" you see in the picture is on both headlamps. Essentially "2" steps if you will. On LHD vehicles, it is to light up road signs on the right side (higher) and not blind oncoming traffic on the left (lower). This is the purpose of the "step".
    Now...we have to get these 2 beams aligned. I personally also have a slight tilt to my drivers side lamp as well as it being lower like shown in previous pics.
    ryanwgregg likes this.
  12. Aug 20, 2019 at 4:34 PM
    #312
    ZackRP
    ZackRP New Member
    Zack
    Wyoming
    Yeah I knew they should be level across with the step up towards the right, I just need to figure out how to adjust. Do I need to shim the light assembly itself with washers or something? I don't see a way to manually adjust the beam per light with the leveling motors.
  13. Aug 20, 2019 at 6:04 PM
    #313
    MMichaelJJ
    14 Platinum CM
    One of these on each light. Turn it. I prefer a socket over a screwdriver.
  14. Aug 20, 2019 at 6:26 PM
    #314
    YotaMan
    Colorado Springs
    2021 Platinum
    I still think its the driver's side tundra lean :eek:
    TheBeast likes this.
  15. Aug 21, 2019 at 7:03 PM
    #315
    ZackRP
    ZackRP New Member
    Zack
    Wyoming
    I did get mine leveled out with the adjustment screw on the assembly. I brought the driver's side up to the level of the passenger. Now I gotta wait for it to get dark so I can see what they're like aligned!
    YotaMan likes this.
  16. Aug 21, 2019 at 7:13 PM
    #316
    eledobleu
    eledobleu [OP] retrofitwholesale.com
    Orlando, FL
    Koito Bi-LED Retrofit
    Didnt realize there was so many comments on this thread. I just finished reading through them all. First, the lights you have ARE NOT final production lights. TRS received about 50 of them along with other XB Headlights. They made these available only for customers and not DEALERS so that they can have actual real life tests and feedback to send to Morimoto. The final versions are set for release end of September/October depending on the build of the responses of the first 50. For example, there were alot of issues with the 4Runner Headlights which were available at the same time as the Tundras. They are now fixing those issues and I assume the same for Tundra.
    As for the group buy, There may or may not be a group buy depending on how many people will participate. These are expensive lights so it wont be like the previous group buys like the fog lights.
    Overall, these headlights will be alot brighter than the stock LED lights on the 18+ Tundras. I see some people are just looking at the looks of the headlights but are not thinking about the overall performance increase you will receive. So far Morimoto has the brightest LED headlights on the market and no other company can compare including OEM manufactures.
    Honestly Morimoto seems to be taking over the LED market.
    And for those that wondered why I havent been on, I have been handling other group buys from other Toyota forums and its been a complete PITA. So im a bit hesitant about offering a group buy for these headlights unless you guys convince me otherwise. Also, TRS don't offer group buys on their XB Headlights.
    ryanwgregg and NCTundra1980 like this.
  17. Aug 21, 2019 at 7:41 PM
    #317
    Hippo442
    Hippo442 New Member
    2016 Sunset Mica 1794 Tundra
    Thanks for keeping us posted! Beautiful headlights, will be keeping my eyes (and wallet) on them! thanks again.
  18. Aug 22, 2019 at 4:08 AM
    #318
    NCTundra1980
    Stephen
    2019 SR5
    I think that it’s actually really wise to ask certain customers to try them out before the final release, sounds like they want everything to be just right. Wish all companies operated this way!
  19. Aug 22, 2019 at 7:22 AM
    #319
    02goldie
    02goldie New Member
    Brock
    2011 Crewmax SR5
    3" lift, 285/75r18 wildpeak at3
    I actually helped them test when they were prototyping the silverado headlights. Matt (owner) had a team there checking every measurement possible to ensure a good product from fitment to light output/cutoff. Awesome company and products to show for it. Hopefully they release a 2nd gen set
    TheBeast and ryanwgregg like this.
  20. Aug 22, 2019 at 1:35 PM
    #320
    Mrlumens
    Mrlumens New Member
    Yeah it's smart for them to test it but what about people like me who bought them at that high price point thinking these were the final perfect product!? I feel like I should have been told that. Do I get a free gen 2 set when they come out or am I stuck with the issues of a test set?
    If I had known these wouldn't be perfect I wouldn't of payed a grand for them.
    Newm, Pudge, WVrackaholic and 4 others like this.
  21. Aug 22, 2019 at 2:45 PM
    #321
    SoCalTundy
    SoCalTundy Tundra Owner since 2017
    Icon Shocks. Total Chaos UCA. Deaver u748 TC shackles. Dirty Deeds standard 10 exhaust. Diode Dynamics fogs. 5.29 Revolution Gears. SSW 17" wheels on BFG 35x12.5.
    You said exactly what I was thinking. Were these first buyers told they were going to be the testers? So far, these are the issues I believe have been reported:
    1. Error message on dashboard
    2. Uneven light output
    3. units not properly sealed allowing moisture under wet conditions
    4. tabs not aligning with holes on truck. Some have reported having to bend them to fit.
    Anything else? Man, I really want to like these headlights. They look awesome, but at over 1k for the set with the issues, I don't know. Hopefully they fix them soon.
    WVrackaholic likes this.
  22. Aug 22, 2019 at 7:28 PM
    #322
    Mrlumens
    Mrlumens New Member
    Exactly! I just installed them and the only issue I had was the tab having to be warped some to screw it in. Won't break but shouldn't be that way.
    They do look awesome during the day and at night FYI
    Well actually I have to adjust the height. They are way too low even when adjusted on the dash all the way up, if they can be leveled enough to right this then I won't mind, but if not...I'll be pissed...royally pissed!
    Also something I don't like is I bought their fog lights as well and the temperature of the light is not the same as the headlights. That grinds my gears.
  23. Aug 22, 2019 at 9:19 PM
    #323
    WVrackaholic
    WVrackaholic New Member
    2016 Platinum
    Now I am freaking confused... I didn’t buy mine through TRS, I got them through latemodellighting because they have allowed pre-order since June! So do I even get a chance to get mine replaced with Gen 2 if that is even possible/offered? I damn sure didn’t spend over a grand to get test lights.
    I also have the problem with the tabs not lining up and the lights are ridiculously hard to get level. Easy process with the Adjustment screw but doesn’t seem to be right.
    Only other thing and maybe it is just me, I do not believe the DRL’s are that bright, I see other vehicles with LED DRL strips and they are noticeably on, whereas mine seems to be dim... Could this be because I did not use the harness, because my truck had the LED DRL’s stock?
  24. Aug 23, 2019 at 4:52 AM
    #324
    Mrlumens
    Mrlumens New Member
    Yeah exactly. We might be screwed with the first batch. Who knows
    My DRL are not that bright either. I did not have stock led DRL so I didn't need the harness but yeah at night they look bright enough but during the day they are not that bright.
  25. Aug 23, 2019 at 4:57 AM
    #325
    NCTundra1980
    Stephen
    2019 SR5
    I am hoping they get y’all taken care of. That’s a lot of money to spend on something that you didn’t know was the final product.
  26. Aug 23, 2019 at 4:58 AM
    #326
    Mrlumens
    Mrlumens New Member
    I agree. Thanks man!
  27. Aug 23, 2019 at 6:53 AM
    #327
    TRD_femi
    TRD_femi New Member
    2015 TRD Pro
    Has anyone raised these issues with TRS?
    #4, to me, is an absolute no-no!!
  28. Aug 23, 2019 at 4:55 PM
    #328
    eledobleu
    Orlando, FL
    Let me clarify, they are not changing the lights so there's no Gen 1 or gen 2 versions. These are the final product but with any new product there might be bugs to work. Like if you buy a new Playstation and they work out all the issues if any. The people who bought the lights are not "testers". The lights have been tested thoroughly at Morimoto, but we all know real life applications are important as well. With that being said, if those who bought them have issues remember that they have a warranty and TRS will replace any lights with defects and issues. But it's important to contact them immediately if you notice any issues so you can open a claim and get a replacement.
    So no one is wasting there $1000+ on the headlights.
    YotaMan likes this.
  29. Aug 23, 2019 at 4:58 PM
    #329
    eledobleu
    Orlando, FL
    # 4, anyone who attempts to try to fix the lights themselves risk voiding their warranty. It's best to take pictures, videos and contact TRS. They are great at fixing issues and getting warranty items replaced.
  30. Aug 23, 2019 at 5:02 PM
    #330
    TRD_femi
    TRD_femi New Member
    2015 TRD Pro
    Maybe you should go back & re-read your previous post...I'll paste it down here in case you cant find it. btw, you shouldn't be making statements like that.
    You're basically saying Morimoto/TRS/Xenon Depot were "fraudulent" because they sold lights that were NOT final production & claimed they were production ready!
    Ryuu, Pudge and BlueBottle like this.
Thread Status:
