Morimoto XB Issue '15 SR5
Discussion in 'Lighting' started by Mcoop, Feb 27, 2021.
  1. Feb 27, 2021 at 12:37 PM
    Mcoop
    Mcoop [OP] Throbbing Member
    Michael
    Berlin, NJ
    2015 Black SR5 5.7L DCLB 4x4
    Hooked up the passenger side and only the middle projector is working. The inside high beam works. What am I missing? There is an extra connector on the headlight for which I do not have a match in the truck.
  2. Feb 27, 2021 at 12:46 PM
    See what the driver side does....
  3. Feb 27, 2021 at 12:58 PM
    Mcoop
    Michael
    Berlin, NJ
    Both low beam projectors and high beam work on driver's side. I also made sure all connectors are secure on both sides.
  4. Feb 27, 2021 at 1:07 PM
    Mcoop
    Michael
    Berlin, NJ
    Can I connect the passenger side light to the driver side without screwing anything up just to see if it is the wiring in the truck?
  5. Feb 27, 2021 at 1:07 PM
    Just to narrow it down to the light I would connect it to the driver's side to rule out the harness on the truck and then contact the vendor that you purchased from. Double check all of the connectors on the passenger side to make sure there are no damaged or bent pins. I'm pretty sure both low beams are powered from the same connector. This is the first that I have heard of one not working... @Headlight Revolution
    Mcoop[OP] likes this.
  6. Feb 27, 2021 at 1:08 PM
    Yes you should be able to.
  7. Feb 27, 2021 at 1:13 PM
    Mcoop
    Michael
    Berlin, NJ
    Ugh. Connected passenger side light to driver side and got the same result. The same low beam projector is not working.
    Message sent to Headlight Revolution.
    Thanks @Tundra234 .
  8. Feb 28, 2021 at 6:24 AM
    Rotaryphoneuser
    Rotaryphoneuser New Member
    Ontario. Canada
    2018 Cement CrewMax
    Man, that sucks. Excitement to disappointment in flick of switch. Hopefully they make it right really fast.
  9. Feb 28, 2021 at 4:28 PM
    Mcoop
    Michael
    Berlin, NJ
    True dat! I spent some bank on those lights. But sh!t happens. Maybe I just need to change something with my wiring. I am sure Headlight Revolution will make it right.
  10. Mar 6, 2021 at 12:53 PM
    Mcoop
    Michael
    Berlin, NJ
    UUUUUUUUUUUUUGH!!!!!!!!!!
    I received the replacement light assembly from Headlight Revolution BUT the f'ing inside low projector does not work. I tried it on both passenger and driver sides. WTF
  11. Mar 6, 2021 at 1:03 PM
    Now I think it is something on the truck side. Can you plug in the stock headlight and see if it works? Do you know anyone else that you could try it on their truck?
  12. Mar 6, 2021 at 1:06 PM
    Mcoop
    Michael
    Berlin, NJ
    I have been using the stock headlights. They work fine. When the assembly did not work last time, I took both XBs out and put in the OEMs.
  13. Mar 6, 2021 at 1:06 PM
    Also, if the driver's side works as it should, move it to the passenger side and see what happens. That would rule out the passenger light itself.
  14. Mar 6, 2021 at 1:08 PM
    Mcoop
    Michael
    Berlin, NJ
    Strange how the inside projector worked on the first unit but does not on the replacement. I am going to try the driver side assembly on the right side. Stay tuned.
  15. Mar 6, 2021 at 1:14 PM
    Mcoop
    Michael
    Berlin, NJ
    Driver side light operates properly on passenger side. I am at a loss.
  16. Mar 6, 2021 at 1:52 PM
    Does the new passenger light work on the drivers side?
  17. Mar 6, 2021 at 2:02 PM
    Mcoop
    Michael
    Berlin, NJ
    Negative. Middle projector does not function when plugged in on either side. High beam works.
  18. Mar 6, 2021 at 2:23 PM
    I'm stumped that you have had 2 passenger side lights do the same thing.
  19. Mar 6, 2021 at 2:31 PM
    Mcoop
    Michael
    Berlin, NJ
    Ha. Join the club. I guess a phone call to @Headlight Revolution on Monday is the next step. If I get a third assembly I wonder if they can test it before shipping.
    Thanks for taking the time to try and diagnose the problem @Tundra234 .
  20. Mar 6, 2021 at 2:52 PM
    There is a guy named Travis that is a Morimoto technician I believe. Let me see if I can find his email. I forgot all about him.
    Mcoop[QUOTED][OP] likes this.
  21. Mar 6, 2021 at 2:57 PM
  22. Mar 6, 2021 at 3:09 PM
    Mcoop
    Michael
    Berlin, NJ
    Thanks. I was emailing back and forth with him last week. He set up my replacement item.
    Tundra234 likes this.
  23. Mar 8, 2021 at 9:49 AM
    Occidentalis
    Occidentalis Out Snakin'
    North Florida
    2015 Inferno TRD Pro
    Very odd problem, I hope you figure it out soon! Will be watching.
  24. Mar 12, 2021 at 7:25 PM
    Mcoop
    Michael
    Berlin, NJ
    Update
    Gotta tell ya I am not too happy with Morimoto and Headlight Revolution. Over two weeks since I shelled out mega bucks for the original set (plus a replacement!) and I still do not have a functioning pair of LED headlights. After last weekend's disappointment I called HR on Monday to get a third passenger side XB assembly. I had to call again today only to be told the unit will ship Monday. Not a happy camper.
  25. Mar 16, 2021 at 5:01 AM
    BrandonL812
    BrandonL812 New Member
    Brandon
    2021 Tundra Platinum
    Return all of it and get oem led headlights instead?
    1lowlife likes this.
  26. Mar 16, 2021 at 5:06 AM
    Rotaryphoneuser
    Ontario. Canada
    2018 Cement CrewMax
    I'm with BrandonL812. I would return for refund and get OEM.
  27. Mar 19, 2021 at 6:38 PM
    Mcoop
    Michael
    Berlin, NJ
    Update II
    Received the 3rd passenger side assembly and.....it WORKS! Its about time. Now I need to adjust them. How the heck do you adjust them left to right? The hot spots are too far apart. I can adjust up and down by turning the white screw head- see picture of driver side. I think the left/right adjustment is tucked up under the fender.
  28. Mar 19, 2021 at 6:43 PM
    BrandonL812
    Brandon
    Is that parked from 25ft away? That look awfully closed to the garage.
  29. Mar 19, 2021 at 6:51 PM
    Mcoop
    Michael
    Berlin, NJ
    That was a little close. This is 25 ft.
  30. Mar 19, 2021 at 6:56 PM
    BrandonL812
    Brandon
    I would pull up as closed to the garage door as u can. Use painter tape, tape the center of the beam for each side. Then back up 25 ft and adjust you cutoff to that mark. Thats where the center of your beam for each side should be. If u feel it's still high, drop another 2inch. Then u won't blind anyone.
