Morimoto XB Headlights, Fox 2.0, Top Gear Auto Sport Tow Mirrors
Discussion in '2nd Gen Tundras (2007-2013)' started by vietvenom, Jun 27, 2020.
How was my review?
  1. Sucked Ass
    28.6%
  2. Okay
    71.4%
  1. Jul 16, 2020 at 10:31 PM
    JustSomeGuy
    JustSomeGuy New Member
    Okanagan Valley, BC, Canada
    2009 Tundra SR5 TRD Off Road CrewMax in Slate Blue
    Diamondback HD tonneau cover, Cooper S/T MAXX tires, Rock Warrior grille, debadged, dechromed, Compustar alarm/remote start, Kenwood touchscreen with navigation, Cobra 75 WX ST CB, dual exhaust, limo tint on rear windows, Firestone Winterforce LT studded tires.
    Cool! Looking forward to hearing how the fog light installation goes. I'll be doing the same thing in a few weeks.
  2. Jul 19, 2020 at 8:53 AM
    GijoeTundra14
    GijoeTundra14 New Member
    Northen California
    2013 Tundra DBL Cab SR5
    Hello All
    Just finished installing the Morimoto XB Fog lights. That went pretty easy. The tough part is taken out the original fog light. if you never done it. Once its out you just have to pop out the lamp from the plastic housing it sit in and then putting the new one in is a snap. and then popping the plastic housing back into the fog light cut out of the truck and then putting all the fasteners that hold the unit to the truck and then the two remaining screws. Hit me up if you have questions.
  3. Jul 19, 2020 at 4:15 PM
    JustSomeGuy
    Good to hear the new XB fog lights went in well. I heard that in the third gen Tundras some people had trouble fitting in the XB fog lights. Still waiting to receive mine. It always takes a while to get things from the US here in Canada, now a bit longer due to COVID-19 and the border being closed to non-essential travel etc.
  4. Jan 31, 2021 at 1:20 AM
    vietvenom
    vietvenom [OP] New Member
    Joseph
    2010 Toyota Tundra RWD SR5 Double Cap
    Fox 2.0, Morimoto XB, Top Gear Auto Sport Tow Mirros
    Heres an update approximately 7 months later for the Morimoto XB's if anyone is curious. I am now on my 3rd set of Morimoto XB's for my 2nd Gen. The headlights are outstanding as far as light output and look compared to the OEM headlights. My only gripe is that they have a horrible seal and i've had to replace them due to moisture intruding into the housing. The first set lasted about 3 months before water got in, I reached out to Headlight revolution to get them replaced and the process was smooth and they did not give me any pushback, just had to pay $650 deposit and they sent me a new set. The second set lasted for approximately a month or so and only one of the headlights had an issue where water got into the headlight. I reached out to Headlight revolution again and they said that I couldn't only replace one and that I'd have to send in both because they got rid of the blacked out side marker to be DOT compliant. I really love the headlights but what pisses me off is that water keeps getting into the damn headlights. For the amount I paid, I thought that they'd be better. I'd be pretty fucked once this warranty runs out and then i'd have to deal with the issue myself instead of warrantying it out. The 3rd set seems to be fine but its only been about a couple of months or so, hopefully they have figured out the issue and used a better sealant.
    As far as the other mods that I've done like the Fox 2.0 coilovers, they are still running strong and I still stick to my original review. Also to the dude that said that my review is trash because I do not have any experience, fuck you this is not the only vehicle i've ever owned and have modded.
    Now for the tow mirrors they are still running strong and I have not had any issues with the led's at all. I reached out to topgearautosport about my issue about the tow mirror not staying in place and they pretty much said fuck you because they never responded. I guess I'll just deal with it because from what I heard some people never even received their purchase.
    I've also done a few other things since my first post like buying Toyo RT's and the tires seem to be doing okay after 20k miles, just sucks that they recommend that I rotate the tires every 3k miles. I've noticed a considerable amount of wear from the front outer edges of the front tires, i'm not sure if its because I drive the truck really hard or if its because I do not stick to the rotation of the tires every 3k miles.
    Another thing i've done is replaced the rotors with stoptech cryo-treated slotted rotors and replaced the brake pads with hawk HP super duty brake pads. The feel to them is outstanding compared to the stock rotors and pads. I impulse bought the slotted rotors thinking that they were way better than non slotted or drilled rotors but after a little bit of research people seem to say that slotted rotors wear out the pads quicker and that smooth rotors provide the same stopping power as slotted or drilled ones. I was afraid and thought that slotted rotors were going to wear out my pads a lot faster but they seem to be doing fine after 10k miles.
    SkipperPete likes this.
  5. Jan 31, 2021 at 6:18 AM
    Texas_Cowboy
    Texas_Cowboy New Member
    2011 Tundra Limited Platinum
    XB LED Headlights, 1k lumen reverse lights
    I got the Morimotos about 3 weeks ago. They are plenty bright for me, but 2 nights ago I started getting clicking from one side like it is arcing inside, and a flashing like they are "refreshing". I'll update when I find out what is going on
  6. Mar 4, 2021 at 12:38 PM
    SkipperPete
    SkipperPete New Member
    Pete
    Nicholasville, KY
    2012 Silver Tundra Crewmax
    Yeah screw that guy! Means absolutely nothing! I for one appreciate your review and especially the update. Fingers crossed these ones hold up for you... I'm holding out a while before I pull the trigger.
  7. Mar 4, 2021 at 2:12 PM
    Texas_Cowboy
    Never did get an answer but headlight revolution did replace the light, so far no problem with the new light
