Morimoto headlights
Discussion in 'Lighting' started by Abdul98, Sep 16, 2020.
  1. Sep 16, 2020 at 7:15 PM
    Abdul98
    Abdul98 [OP] New Member
    Abdul
    2020 Toyota Tundra limited double cab
    Hello everyone, I recently purchased headlights from morimoto for my 2020 tundra limited. I installed the lights with harness equipped and purchased the led harness as well (I was told it was required even tho my truck has stock led lights and led running lights) the lights work perfectly fine, the issue I’m having is my tails don’t work, I have brakes, turn signal, just no running lights in the rear. I ran through my fuses and found that my TAIL 10 amp was blown. I replaced it and everything works fine up until the lights turn on, the fuse blows again. I contacted morimoto and I was told the fuse supplied with the headlights needed to be placed on the Injector/ecl 2 tap. I also placed them there with no luck as soon as the lights turn on, the tails blow out right away. If anyone is having that same issue and found a solution, please let me know. It’s super frustrating and annoying having to deal with this issue. Morimoto Told me to tap in to the (ign 10 amp) Once that didn’t work they told me to tap into (inj 10 am) again that didn’t work, I was told to tap into (Efi 2 10 amp) that also didn’t work. Thank you for your help.
  2. Sep 16, 2020 at 7:50 PM
    alwzdfiant
    alwzdfiant New Member
    2013 Tundra Crew Max
    Headlight Revolution likes this.
  3. Sep 16, 2020 at 8:04 PM
    Post a pic of where your fuse tap is plugged in. I just installed mine in my 2020 a couple of hours ago with no issues.
  4. Sep 16, 2020 at 8:05 PM
    Welcome from NY.
    Hopefully you will figure it out.
  5. Sep 16, 2020 at 8:15 PM
    Abdul98
    Abdul
    Where’d you plug in your tap? Also I’m sure you purchased the led harness, my package came with a 2 end extension that plugs in to the trucks harness and the other end plugs in the lights. I tried it with that harness as well as the led harness and it also didn’t work
  6. Sep 16, 2020 at 8:28 PM
  7. Sep 16, 2020 at 8:32 PM
    Mine is plugged into the 10 amp fuse "IGN" I think it was. Morimotos video on the install for the 14-19 models shows the fuse in a different spot. I can take a pic of it in the morning. Mine was halogen so I didn't have to order the led harness.
  8. Sep 16, 2020 at 8:34 PM
    The fuse that it shows is the 10 amp on the end, but it's different on the 2020. On the 20, there is a 7.5 in that spot, so it's actually needs to be plugged into the 10 amp which is next to it.
  9. Sep 16, 2020 at 8:47 PM
    On the video posted, the fuse in that position on your truck is a 7.5 instead of a 10 amp like the video shows. The next one is a 10 amp.....that where I plugged mine in.
  10. Sep 16, 2020 at 8:50 PM
    Abdul98
    Abdul
    I plugged it in the one directly on top, the 10 amp IGN with no luck
  11. Sep 16, 2020 at 8:56 PM
    Abdul98
    Abdul
    The harness on the left I was told I needed to purchase. Which works fine. Did you end up having a harness like the one the right? Because I plugged the one on the right and I had no turn signals. When I disconnected the harness on the right, the turn signals worked fine
    Gee Dub likes this.
  12. Sep 16, 2020 at 9:00 PM
    The one next to the yellow mark that I put on the pic?
  13. Sep 16, 2020 at 9:03 PM
    Abdul98
    Abdul
    Yes
  14. Sep 16, 2020 at 9:04 PM
    The harness on the right doesn't get used on trucks with halogen headlights if I recall correctly. Let me find the thread that talks about it.
  15. Sep 16, 2020 at 9:05 PM
    Abdul98
    Abdul
    I appreciate your help!
  16. Sep 16, 2020 at 9:10 PM
  17. Sep 21, 2020 at 7:16 PM
    2020VATundra
    2020VATundra New Member
    Willy
    2020 Tundra TRD PRO Super White
    Jumping in here to see if I can learn. Just bought a 2020 TRD Pro and am disappointed with the factory LED lights. I had Morimoto HIDs in my 2018 Tacoma that I traded and loved them. Are the Morimoto LEDs a significant upgrade over the factory LED lights? Seems like there are issues wiring these up in the 2020 models, but its probably worth the hassle if they have better light output and a longer range. Any info or opinions is greatly appreciated.
    So sorry to thread jack~~
  18. Sep 21, 2020 at 7:18 PM
    :threadjacked:
    Welcome from NY.
  19. Sep 21, 2020 at 7:18 PM
    Abdul98
    Abdul
    They are definitely worth the upgrade in my opinion. I had them in my 18 4Runner and they were amazing. If they work properly and function as they should, they’re worth the upgrade. Hope that helped.
  20. Sep 28, 2021 at 1:56 PM
    CanDras
    CanDras New Member
    Marc
    Canada
    2018 Plat. Supercharger, Fox 2.5 DSC, Total Chaos UCA, ADD Stealth Bumper, ARE topper, 35x12.5x20 Toyo MT, Fuel D671
    Did any have any issues with the DRL turning off once low/high beam comes on. Pretty sure they're just supposed to dim and not go off. @Headlight Revolution
    2018 platinum, morimoto gen 2
  21. Sep 28, 2021 at 2:02 PM
    How long have you had them installed and what slot is the fuse tap plugged into?
  22. Sep 28, 2021 at 6:13 PM
    CanDras
    CanDras New Member
    Marc
    Canada
    Just installed them this summer, didn't have to use the fuse tap, the platinum came with LED DRL...
  23. Sep 22, 2022 at 5:16 PM
    JOrtiz23
    JOrtiz23 New Member
    Josean
    Good afternoon guys new here. I have a question . Did you guys were able to fix this problem because i am having the same problem blowing up my 10a tail fuse. And i dont know what else to do. I have a 2020 tundra limited
  24. Sep 23, 2022 at 8:06 PM
    JOrtiz23
    JOrtiz23 New Member
    Josean
    Was you able to fix this problem? im am having the same problem on my 2020 limited and im loosing my patience.lol I installed evreything as they says in the install guide and now mybturn signals dont work. After the morimoto guy told me to move a cable in the oem turn signal conector like the one in this pic since it was a recall. But after soing that i have no turn signal and evreything else works fine. But if i but the cables back how they werein the turn signal conector have turn signals but no tail lights..‍♂️.. i really dont know what else to do
  25. Sep 24, 2022 at 10:02 AM
    JOrtiz23
    JOrtiz23 New Member
    Josean
    For those who will come to this post in the future looking for an answer in how to stop your tail light fuse to get blown up once you install morimoto 2nd gen on ypur tundra w/ oem led the only thing i had to do was swap the position on this 2 cables the ( black and yellow) in the turn signal adapter provided by the supplier and your problem should be fix. If you try that and still have no turn signal check your fuse box under the drivers the 15a Haz fuse could be blown replace it. that should do it it worked for my 2020. Tundra limited
    Gee Dub likes this.
  26. Sep 24, 2022 at 10:03 AM
    JOrtiz23
    JOrtiz23 New Member
    Josean
    Put the yellow cable where the black is and the black where the yellow is.
