Morimito Fog Lights
Discussion in '2.5 Gen Tundras (2014-2021)' started by dv8TRDPRO, Jan 18, 2020.
  1. Jan 18, 2020 at 6:48 PM
    dv8TRDPRO
    dv8TRDPRO [OP] NOOGTRDPRO
    Chattanooga
    2017 Tundra Pro White
    Weather Tech mats, Stubby antenna, AJT gear shift knob, AJT keyfob, Tundra door sill protectors, Cup holder inserts, door pocket inserts, console inserts, Tundra tailgate letter, and TRD PRO bed insert. Kenwood dnx996xr 1299 with navigation, vehicle gauges, and tire pressure sensors gauges Keyless Remote CL6 app remote start 4 rolls of sound shield 1 Jl rd 900/5 2 Jl c2 650 components 2 Jl 10w1
    Installed my fog lights and the passenger side seems to be aimed wrong. I have a weird shadow coming from the bottom. Are they adjustable. I plan to pull it out in the morning and look closer. Wasn’t sure anyone else had this issue.
  2. Jan 18, 2020 at 7:26 PM
    Danman34
    Danman34 New Member
    Danny
    2018 White Tundra TRD Sport
    Should be adjustable. Explain “weird shadow coming from the bottom”.
    dv8TRDPRO[OP] likes this.
  3. Jan 18, 2020 at 8:02 PM
    dv8TRDPRO
    Chattanooga
    The driver side has clean beam of light from the center of truck to the side. The passenger side has a clean line from the center for about 3 ft and then it’s like the light beam is blocked. Making it look like we have a shadow. The beam goes across it’s just looks partially blocked.
  4. Jan 18, 2020 at 8:52 PM
    BlueBottle
    BlueBottle not a PRO
    '16 Platinum 4x4
    See fine print
    It has a screw adjuster on the bottom. You should be able to get to it with the liner off.
  5. Jan 18, 2020 at 8:56 PM
    Pudge
    CT
    2015 Blue Ribbon Platinum
    Lemme see if I can find a pic of my morimoto output. They have a small sliver of light just I'm front of the truck then the regular beam after that. I believe its normal
  6. Jan 18, 2020 at 9:04 PM
    Pudge
    CT
  7. Jan 20, 2020 at 5:25 PM
    dv8TRDPRO
    Chattanooga
    I didn't get to work on the truck this weekend ended up sick. So I thought I would add some pics of the beam pattern and the issue. Need to do another shot with the pattern on a wall. I will try to get that tomorrow. It does feel like the headlight on the passenger side may be running higher or maybe dimmer that the driver's side.
    Any ideas?
    Fog lights on
    Fog lights off
  8. Jan 22, 2020 at 2:16 PM
    LlamaResistance
    LlamaResistance Member
    Concord, CA
    2017 White Crewmax SR5 TRD Offroad
    MLED Retrofitted Platinum Headlights, Ranch Hand bumper, Firestone airsprings, Leer 100XR Shell, Amp Research Steps
    Definitely looks like the passenger side fog is aimed very low and needs to be adjusted up. You can see that the main body of light is hitting the ground much closer to your truck than the driver's side.
