Moisture under drivers floor mat
Discussion in '3rd Gen Tundras (2022+)' started by Troyboy84, Jan 25, 2023.
  1. Jan 25, 2023 at 6:45 PM
    Troyboy84
    Troyboy84 [OP] New Member
    BC Canada
    2022 SR5 TRD Offroad
    I know there is already a thread on this so this may need to be deleted but I wanted to try and make as many people aware as possible. After driving on wet roads due to rain and melting snow, both I and a friend have excessive moisture under our drivers side floor mats. Toyota corporate (Canada) has given an unacceptable excuse of it coming from our feet. Anyone with a 3rd gen who has driven in similar conditions, do yourself a favour and check under the mat on the drivers side.
  2. Feb 10, 2023 at 10:47 AM
    korslite
    korslite New Member
    Justin
    Bellingham, WA
    2022 SR5 TRD OR 6.5' Bed
    Just noticed this while vacuuming under my mat. WTH?
  3. Feb 10, 2023 at 10:49 AM
    2000 Limited TRD AC 4X4 Thunder Grey 270k miles. 2019 Limited TRD CM 4x4 Cement Grey 75k miles
    2000: Bilstein 5100's 16x8 589's with 265/75/16 and 1.25" spacers Flowmaster 50 series over the axle dump Pioneer touchscreen with backup camera Full interior and dash LED conversion Trailer brake controller with 7 pin Bedliner coat bumpers & trim ARE topper 2019: ARE topper with full Bedrug kit and Vortex rack TRD shifter 1.25" wheel spacers (I like to live dangerously) Red tow hooks for that +15 grip bonus
    Probably a body plug that is incorrectly installed or was left out, or incorrectly applied seam sealer. May be able to look under the truck and see it if it’s a missing plug.
  4. Feb 10, 2023 at 11:05 AM
    Troyboy84
    BC Canada
    I’ve been dealing with it at my dealership. Even after showing them the posts from another member about water coming up through the floor boards due to failed sealant, they are saying Toyota Canada is blaming a poorly designed all weather floor mat. If you get enough water or melted snow, there is a possibility that it will drain towards the center console and gas peddle.
  5. Feb 10, 2023 at 11:37 AM
    TTund16
    TTund16 New Member
    FYI, Some 2.5 Gen people had issues with leaking 3rd brake light but I think water or some moisture was collected under the back seats.
  6. Feb 10, 2023 at 7:36 PM
    ToyotaBeast
    ToyotaBeast New Member
    It could be coming from the windshield urethane... it may not have been sealed properly. Removing the plastic a pillar trims inside might show some signs of water in the ridges of the plastic after it rained.. Just a though :(
