Moisture collects in cabin after adding sound deadening to rear wall
Discussion in '2.5 Gen Tundras (2014-2021)' started by SiberianTundra, Jan 10, 2020.
  1. Jan 10, 2020 at 8:00 PM
    SiberianTundra
    SiberianTundra [OP] I heard Unicorns get horrible MPG
    Greg
    War Machine
    Camper shell, LED lighting VLEDs, Front Camera, Pro Comp wheels. Trd HID LED headlights. ESP storage rear seats.
    I added killmat and sound foam to my doors and rear window wall in my crew max
    Doors were first
    Rear wall was a few weeks after
    Noticed moisture collection in the vehicle after i did the rear wall. Now i do recall there being a rubber plug there. Also i wonder if Toyota designed the rear of the truck wall to dissipate moisture collected in the truck.
  2. Jan 10, 2020 at 8:17 PM
    14CRWMX
    14CRWMX New Member
    Tampa Bay
    2014 SR5
    I was thinking to soundproof rear panel, will definitely look in it. Thanks for sharing this info
    SiberianTundra[OP] likes this.
  3. Jan 10, 2020 at 8:19 PM
    SiberianTundra
    Greg
    War Machine
  4. Jan 10, 2020 at 8:20 PM
    SiberianTundra
    Greg
    War Machine
    It’s mild but it is noticeable. Specially the moist smell after rain or damp feeling in the cabin after overnight.
    Never had that issue until rear wall was done
    14CRWMX[QUOTED] likes this.
  5. Jan 11, 2020 at 1:20 AM
    astro-jason
    astro-jason New Member
    2022 CHEVROLET 3500 CC L/B Duramax 10spd
    There is a vent on the rear wall of the cab, so the cabin doesn't hold positive pressure, I bet you covered that up. I dont remember exactly where it is. Uncover it and all will be good. Also if you keep your HVAC on recirculate that helps also.
    -Jason
    15whtrd and SiberianTundra[OP] like this.
  6. Jan 11, 2020 at 10:23 AM
    SiberianTundra
    Greg
    War Machine
    Dang I need to find that vent. Thank you!
  7. Jan 11, 2020 at 11:28 AM
    SiberianTundra
    Greg
    War Machine
    Does any one happen to where the vent is here are pics of my install
    Before the install
    After the first layer of killmat
    And final layer of Noico
  8. Jan 12, 2020 at 3:08 AM
    astro-jason
  9. Jan 12, 2020 at 4:04 AM
    Adam New Member
  10. Jan 12, 2020 at 5:01 AM
    JohnLakeman
    Outside of Weird, TX
    2017 MGM DC TSS 4.6L
    I saw that thread, and it confirms that Toyota is serious about providing a substantial, functional cabin over-pressure vent. IMO, there is not enough clearance around that access cover to guarantee Toyota's idea of "venting" back through that volume. I see nothing else in @SiberianTundra pics that even suggests a dedicated over-pressure vent ala previous Tundra models on the cabin back wall. I conclude it's not there, and it hasn't been covered over.
    Typically, the relative humidity inside the cabin is low enough, and the ambient temperature high enough, that condensation inside the cabin is not a problem. The fact that you're observing condensation says you have high relative humidity inside the cabin, and the exterior ambient temperature is low enough (even through the treatment) to reach the dew point. Normally, the way to remove water vapor from inside the cabin is to run the AC...in Defrost if you like, but that's not necessary. If you removed the fiber insulation to replace it with sound treatment, I believe I would re-install it back over the top of the treatment.
    As suggested above, you probably have something besides your sweat that is raising the relative humidity inside the cab. Check out the carpet under the dash on the passenger side. Of course, if your AC condensate drain is stopped up and the condensate is just leaking back into the cab as suggested, running the AC won't help...the condensation is simply running in a vicious cycle. :thumbsup:
    StihlBuckin and rockmup like this.
  11. Jan 12, 2020 at 6:18 AM
    Vizsla
    Vizsla 2 = 2.5
    GAknight, 15whtrd, Flyinryank and 6 others like this.
  12. Jan 12, 2020 at 6:32 AM
    Rex Kramer
    Rex Kramer Vinyl Spinner
    Georgia
    Your vents are behind these panels.
  13. Jan 12, 2020 at 9:53 AM
    SiberianTundra
    Greg
    War Machine
    In that case i did not tape over them.
    Thank you for your help
  14. Jan 12, 2020 at 11:28 AM
    FirstGenVol
    East TN
    2002 AC TRD 4x4 V8
  15. Jan 12, 2020 at 11:31 AM
    FirstGenVol
    East TN
    2002 AC TRD 4x4 V8
    Actually, can you double check behind your seat? Maybe you partially covered it.
  16. Jan 12, 2020 at 11:45 AM
    SiberianTundra
    Greg
    War Machine
    Ok i will take the seat out again and check. Last time I took out the seat one of bolts would not thread back in. So I had to retread the bolt and the hole it goes into. Pain in the ... ~Good point I should check.
    Rex Kramer and tundra_20 like this.
  17. Jan 21, 2020 at 2:08 PM
    SiberianTundra
    Greg
    War Machine
    Well it was not taped over but I did cover the passage under seat very well with tool boxes
    So after shuffling things around it seems to be much better
    legiz and Rex Kramer like this.
  18. Jan 21, 2020 at 3:29 PM
    mr_lasseter
    mr_lasseter New Member
    This happend to me when I took out my back seats too. One of the bolts on mine was bigger than all the others but it went very far back left on the bigger of the two seats in the back.
  19. Apr 4, 2020 at 4:01 PM
    Burdturger
    Burdturger New Member
    Did you ever figure this out? I thought about adding some sound proofing material in the cab too and this was the first thread that popped up. Hope you got it cleared up!
  20. Apr 4, 2020 at 5:53 PM
    SiberianTundra
    Greg
    War Machine
    Yes above you can see my response
    It was junk in the rear of seat tool boxes and other covering the breathing hole
  21. Jul 26, 2020 at 4:35 PM
    Ad4mmd
    Ad4mmd New Member
    2012 Toyota Tundra TRD DC
    Camburg UCA Fox shocks TRD Front/Rear SwayBars TRD Air-box Intake Mod KN Air filters EBC Brakes TRD 3rd Gen wheels/tires JL Subwoofer 700watt PIONEER Nav HU Focal speakers 3way Dynomat Center Console Safe Led Interior Lights
    Was wondering if any one has a solution for muffling/killing the seat belt pretensioners from sub? Trying to get rid of that annoying rattle.
    AggiePhil likes this.
