Miscalculated
Discussion in 'Wheels & Tires' started by JFerg8384, Jul 13, 2019.
  1. Jul 13, 2019 at 6:37 PM
    JFerg8384
    JFerg8384 [OP] New Member
    2016 Tundra 1794
    Rough Country 3.5” Suspension Lift 295/60R20 Falken Wildpeak 20x9 DX4 Boost
    Recently completed lease buyout on my 2016 Tundra 1794. Took the past month, researching and trying to figure proper fitment of lift, tires and wheels.
    Rough Country 3.5” Suspension Lift (yeah yeah, this is cosmetic and not a performance lift. I am a pavement driver)
    20 x 9 DX4 Boost (+10)
    Knew I would need minor trimming of some plastic. Turns out, I am hitting body mount -front and rear on driver side - front only on passenger side.
    First question, would a different offset correct this? Perhaps a +20? Seems marginal in my opinion.
    Second question, what are pros and cons of body mount chopping? Not opposed to this option if it makes sense.
    Lastly, as the lift settles, will the rub area increase, decrease, or stay the same?
    Looking for great ideas, so I can move to some other upgrades.
    Thanks in advance.
    Black Wolf and Erichudgins like this.
  2. Jul 13, 2019 at 8:21 PM
    Welcome from Co. Remove mud flaps, and push front plastic fender liner forward if you need to.
    JFerg8384[OP] likes this.
  3. Jul 13, 2019 at 8:25 PM
    TheGreyTundra28
    TheGreyTundra28 New Member
    2018 Grey Tundra Sport
    Dirty Deeds 10 budget exhaust, Roof rack, 52" windshield, Truxedo Tonneau, and Line x Bedliner
    Not sure where your from but a company in Cali called 88 rotors shows there work on body mount chops on their tundra lifts. just pointless info but nice to see other peoples rides getting fixed up.
    JFerg8384[OP] and Bigboitundra like this.
  4. Jul 13, 2019 at 8:33 PM
    realtorblake
    realtorblake Tundra Thunda
    Redneckistan... aka Cypress, TX
    2019 Crewmax Platinum 5" Zone lift Fox 2.5 /OME suspension 12.5x35x18 ProComp's
    I run +18 with 35's and no BMC... hut I am 1.5" higher. With those tires, I think you could go to +24 if you had to. Definitely have to remove mud flaps and modify fender liner though.
  5. Jul 13, 2019 at 8:56 PM
    Welcome from NY.
  6. Jul 14, 2019 at 1:19 AM
    kgb4187
    kgb4187 New Member
    I'd try spacers before chopping metal bits off
  7. Jul 14, 2019 at 4:13 AM
    Diesel3612
    Diesel3612 New Member
    2019 tundra SR5 crewmax 4X4 super white
    Bull bar, chase rack leveling kit 33s on anthracite rims
    Hey from Wisconsin
    I have a 2017 tundra and i put 33s on mine with just a 2" front level kit i did buy new rims that were offset
    I really wouldn't recommend spacer they wheel eventually eat your wheel bearings up
    Thats just my 2cents
  8. Jul 14, 2019 at 4:24 AM
    Netmonkey
    Netmonkey Don't be a Dumbass
    Georgetown, TX
    2016 Texas Edition, 5.7, CM, MGM
    Icon stage 2 lift, 295 60 20 nitto ridge grapplers, fuel kranks, TRD dual exhaust, TRD rear sway bar
    going with a higher offset will reduce the rubbing (+18 or +25 for example). or, just do the body mount chop (and fill). there are no issue in doing that mod.
