Mirrors not syncing in reverse
Discussion in '2.5 Gen Tundras (2014-2021)' started by Double Aught, Aug 11, 2020.
  1. Aug 11, 2020 at 10:09 PM
    Double Aught
    Double Aught [OP] New Member
    2018 Magnetic Grey 1794 Edition CM 4wd
    For some reason, my mirrors are no longer tilting down when putting the truck in reverse. B.U. camera still works normal. Has anyone dealt with this issue before and is there a fix? Thanks in advance.
  2. Aug 11, 2020 at 10:19 PM
    Chelly
    Chelly ...
    Mt Hood / PDX OR
    2020 Platinum - Super White
    Elka DSC Suspension, Ray-10s, MaxTrax, Dirt King UCA, 295/70/18 Toyo AT3, TRD Skid + Intake, .25 Bumper Shim, UnderCover UltraFlex Tonneau, RoadActive Suspension, Tuffskinz, etc.
    Check your mirror switch is set to either left or right, when the switch is in the middle, the mirrors don't tilt. Its a feature in case you don't want the tilt when backing up.
    mountainpete likes this.
  3. Aug 12, 2020 at 5:15 AM
    Jaypown
    Jaypown New Member
    Justin
    Rubber City
    Stupid question. Is this on all models or just 1794's?
  4. Aug 12, 2020 at 5:25 AM
    NCSkeeter
    NCSkeeter New Member
    2019 Silver Tundra Crewmax 4x4 1794
    TRD Rear Sway Bar, Truxedo X15 Tonneau Cover, Toyota OEM Bed Mat
    Think just 1794/platinums.
    Jaypown[QUOTED] likes this.
  5. Aug 12, 2020 at 5:30 AM
    Jaypown
    Jaypown New Member
    Justin
    Rubber City
    Thanks. I have an SR5. Always out of habit ever since I've had vehicles with power mirrors, I keep the mirror switch on the middle setting. No reason just habit. I thought maybe, just maybe there was a nifty feature I didn't know I had. Nope.
  6. Aug 12, 2020 at 5:33 AM
    0.S.T.
    0.S.T. New Member
    EAST COAST
    2007 BLACK TUNDRA 4X4 CREWMAX LIMITED 5.7 LITER
    My old 2007 Limited has this feature. Maybe because back then it was top of the line.
    O.S.T.
  7. Aug 12, 2020 at 6:40 AM
    Double Aught
    Thank you for the response, Chelly. I will look at that when I leave for work in a few.
  8. Aug 13, 2020 at 1:00 PM
    Tisoy281
    Tisoy281 New Member
    Wait... Platinum's have this feature? I haven't noticed it on mine. I have a 17 platinum.
  9. Aug 13, 2020 at 4:14 PM
    Chelly
    Chelly ...
    Mt Hood / PDX OR
    They do, give it a go! You can also adjust where they tilt in reverse and they will go back to that spot each time.
    Double Aught[OP] likes this.
  10. Aug 13, 2020 at 6:05 PM
    Tisoy281
    Tisoy281 New Member
    I tried it after work today and it doesn't work on mine. I have a 17 platinum. Maybe this was an 18 and up feature?
  11. Aug 13, 2020 at 6:21 PM
    Double Aught
    Well, it went back to normal. I set the switch for the left mirror and as soon as I put it in reverse, they tilted down.
  12. Aug 13, 2020 at 6:36 PM
    Predator Tundra
    Predator Tundra New Member
    Fallon, NV
    2020 Platinum
    Lol I had no idea they did this. Mines always in the middle. Gonna try it in the morning when I go to work.
  13. Aug 13, 2020 at 10:07 PM
    MJoeP
    MJoeP New Member
    Joe
    2016 Tundra 1794
    2016 Tundra 1794 DiamondBack ATV Tonneau Cover 7" BDS Lift 20" Fuel Krank Wheels 37X13.50X20 Toyo Open Country M/T
    Learned something new! Guess I'll move my switch from the middle to left or right position and check it out next time I back up.
  14. Aug 14, 2020 at 6:02 PM
    Tundra Fan
    Tundra Fan Got 17's?
    Toby
    Nor Cal (Placer Co.)
    Nope. Mine tilt too.
  15. Aug 14, 2020 at 6:18 PM
    omgboost
    omgboost The Accountant
    East Coast
    2012 Sequoia Platinum
    I have a Sequoia with the reverse tilt function. It's a button I have to press for the function to turn on, I leave it on all the time. Every time I'm in reverse, both mirrors tilt down. I leave my mirror adjustment in the middle.
  16. Aug 14, 2020 at 8:31 PM
    Tisoy281
    Tisoy281 New Member
    How do you get them to tilt?
  17. Aug 15, 2020 at 11:19 AM
    Tundra Fan
    Toby
    Never mind. I was thinking about the wife's car. Sorry :facepalm:
    What I did with mine, although I never use it now, was program driver 2 memory with both mirrors adjusted down and in a little so I can see the rear wheels.
