Minor Rear lift, suggestions?
Discussion in 'Suspension' started by Andrew4776, Jun 25, 2021.
  1. Jun 29, 2021 at 7:48 PM
    #61
    Nothing derailing since everything goes hand in hand. You alter the the front you then you compensate for the rear. Visa versa applies here. All "rails" need to be addressed. Can't hurt:thumbsup:
  2. Jun 29, 2021 at 8:28 PM
    #62
    Andrew4776
    Andrew4776 [OP] New Member
    Andrew
    2018 tundra trd off-road
    I had some people on here recommend the camburgs with the MOOG ball joints. So I went with those.
    idk much about trucks and truck parts, this would be my first truck. Previous car was 3 series 323it. Like it a lot, but my work needs required a truck.
    6D031303-92EF-47BF-967B-8139671DBD8D.jpg 54BA2F00-760D-4478-B829-6EE5B0455F70.jpg 7EE1B8EA-9190-4D9B-BD5B-D63EEAB5356D.jpg
    DZ_, equin, 2mchfun and 1 other person like this.
  3. Jun 30, 2021 at 5:12 AM
    #63
    Camburg is quite good. Quality stuff.
    Andrew4776[OP] and 2mchfun like this.
  4. Jun 30, 2021 at 9:41 AM
    #64
    Andrew4776
    Andrew
    Yeah I’ll post up once I get everything, excited to get this thing back in good shape again.
  5. Jul 24, 2021 at 7:14 PM
    #65
    Andrew4776
    Andrew
    Little update, ended up changing plans a bit. Went with the fox 2.5 IFP upfront, kept the rear leafs stock. I have little over 1” rake towards the rear, and probably a bit more once they settle, which is what I was looking for.
    Spent the weekend working on the front end and threw on the 2.0’s in the back as well. Ride is better, and Definitely noticed the added caster with the Camburgs.
    5D23D9D0-D7CC-411E-82E7-1A89DE8BB0EA.jpg 9C0B89B2-0DC3-4F3B-AC21-E565FDBFB4B0.jpg 7D2E66C7-DFD9-4273-8BD2-61ECE8F56343.jpg image.jpg image.jpg
  6. Jul 27, 2021 at 9:13 AM
    #66
    JPB_VT
    JPB_VT New Member
    Jesse
    ‘21 Nightshade Wind Chill Pearl
    Fox 2.5 Fox DSC front & rear Camburg UCAs Alcan leaf springs Kenwood 1037S HU OEM Audio Plus
    Andrew....let me know how you like the setup. I've ordered the Fox 2.5 DSC coil-overs with the Camburg UCA for the front and 2.5 DSC for the rear. I'll be running Method 18" w a +18 offset on 33s for now. Will likely move up to a 34.5" next year. I don't want a tall lift, just enough to run the 35s eventually. From what i understand, I may need to add a spring or different set on the rear for that. Considering the Icon options. I'll run the 33s for the next year at least.
    I'll take any suggestions as well. My first time upgrading the suspension. My current (soon to be prior) Tundra came with the TRD setup installed. Cheers.
    Andrew4776[OP] likes this.
  7. Jul 27, 2021 at 3:57 PM
    #67
    Andrew4776
    Andrew
    Yeah I’ve heard nothing but good things about the DSC’s. Only issue I’m facing now is rubbing the skid plate, which was surprising since I usually see it on wider tires and not 275’s.
    besides that, I phoned fox while installing they said it’s about a 2:1 ratio for adjustment; so every 1” of threads is 2” of lift. I have my pass set to .68 and driver set to .73 of threads. And it looks like that^^
  8. Oct 17, 2021 at 9:24 AM
    #68
    scruffy727
    scruffy727 New Member
    Rob
    Ventura County, CA
    2020 SSM Platinum 4x4
    TRD Dual Exhaust TRD Rear Stabilizer Color-Keyed Mirror Caps Amp Research Bed Extender BedRug XLT Toyota Power Tailgate Lock Extang Xceed Tonneau Cover CarPlay 2 Air
    What size tire are you running?
  9. Oct 17, 2021 at 6:47 PM
    #69
    Andrew4776
    Andrew
    Those were 275/70/18. I just switched to 285/70/17 in wildpeaks
    toyofan87 likes this.
  10. Oct 18, 2021 at 7:25 PM
    #70
    scruffy727
    Rob
    Ventura County, CA
    Are those the Rock Warrior wheels? They look great!
  11. Oct 19, 2021 at 12:03 PM
    #71
    Andrew4776
    Andrew
    Yes sir, I found someone that sold them to me for 400 bucks. I sold the BBS wheels yesterday. They’re pretty neat.
    the difference between the two sizes was the KO2 18” wheels were 33.2”x11”, wildpeaks are 33”x11.6”
  12. Oct 23, 2021 at 9:54 AM
    #72
    scruffy727
    Rob
    Ventura County, CA
    Wow! That’s a heck of a deal!
    Good to know on the tire sizes. I recently purchased the TRD Pro Fox Suspension. My plan is to get a set of the BBS wheels and wrap them in 285/70/18 tires, which is a great size for that suspension kit.
    However, I am toying around with the idea of installing the icon 51200 AAL so I retain towing capability. Adding that would maintain factory rake, but I was also hoping to reduce the rake slightly. I reached out to Westcott Designs about installing their front lift without the 1/2” spacer and they said it was perfectly fine. If I did that, total front would be 2.5” taller than factory and rear would be 1.5” taller than factory.
    I keep hoping I will find someone on here with a similar setup so I can visualize what it will look like but everyone seems to go with bigger tires with a similar lift.
    I plan to do more city/highway driving and towing than off-road, so I don’t want a bigger tire than the 285/70/18.
    Your truck looks great, how much is it lifted in the front/rear? Not sure that was mentioned previously. If so, I missed it.
  13. Oct 23, 2021 at 11:11 AM
    #73
    Andrew4776
    Andrew
    I have stock rear ride height and about a 1.5 in lift upfront, which still has me at about .7” rake towards the rear. Imho the 285/70/18 would be too skinny/small for a higher lift. Not only visually but mechanically too, that higher center of Gravity with skinny tall tires and the +60 offset will contribute to cornering instability.
  14. Oct 23, 2021 at 11:13 AM
    #74
    Andrew4776
    Andrew
    I see lots of people run 295/70/18. On the pro wheels and they look good. If you wunna stick with skinnier see if you like any wheels with less offset, poke them out a bit more.
    The RW wheels have less offset and the tire is wider and tint bit shorter than the 18’s, and it was rainy to notice.
    After all I have nothing more to say than my personal experience. If you go with you setup and notice some roll but like the look, you could always look into anti sway bars, esp the rear will make a big difference since you won’t off-road much.
    I have the thicker TRD one upfront and noticed it just slightly on faster corners.
    here are a few pics of it currently with the RW’s vs the BBS’s.
  15. Oct 24, 2021 at 9:45 AM
    #75
    scruffy727
    Rob
    Ventura County, CA
    Great advice! Thank you for posting the additional pictures! This really helps!! I was considering 295/70/18 because of the width but was concerned about losing MPG's as well as potential rubbing issues. I may decide to go with the stock TRD Pro suspension setup and only add the 51200 in the rear if I really find that I need it. The RWs might be a better choice for me to add a bit more stability. Do you happen to know the offset and weight of the RW wheels?
  16. Oct 24, 2021 at 10:35 AM
    #76
    Andrew4776
    Andrew
    Trd offroad/trd pro wheels are +60, RW wheels are +50mm.
  17. Oct 24, 2021 at 10:40 AM
    #77
    toyofan87
    toyofan87 Beer thirty
    Seth
    Gettysburg, Penna
    Looks killer. Well done
  18. Oct 24, 2021 at 10:42 AM
    #78
    Andrew4776
    Andrew
    Thanks appreciate it
    toyofan87[QUOTED] likes this.
  19. Nov 29, 2021 at 11:40 AM
    #79
    DgoTss
    DgoTss New Member
    Wesley
    Durango Colorado
    2015 dbl TSS
    Truck looks great! This makes me less worried about dropping from 305/70/17 down to 285/70. I am amazed how tall the rear of your truck looks being totally stock height in the rear but I guess my shell and decked drawers add some weight. Did you do anything to the rock rings or center caps on the RW wheels or were they just in good shape to start? Very jealous of the Red!
  20. Nov 29, 2021 at 1:08 PM
    #80
    Andrew4776
    Andrew
    They were alright, I got the set for 400 bucks, so didn’t expect a pristine set, but was surprised how clean they were.
    Just some slight scuffs on the wheel and ring, you have to get really close to see them.
    I actually thought it wouldn’t go with the red for a while and contemplated selling them. But thought I mount some tires and see if I like them more than the BBS’s, if not I can still sell them for what I spent or more. Was really glad they matched the truck and they look neat with the falkens.
