Minor Rear lift, suggestions?
Discussion in 'Suspension' started by Andrew4776, Jun 25, 2021.
  1. Jun 29, 2021 at 12:41 PM
    Winning8
    Winning8 New Member
    Da Bay Area
    2019 MGM DC 4x4 SR5
    I don’t go off road, but I’m in construction so I brought the timbren once I got the truck, I want to buy the add a leaf to raise the back and give me some suspension travel be4 hitting the timbren.
    Black Wolf and Andrew4776[OP] like this.
  2. Jun 29, 2021 at 12:46 PM
    Andrew4776
    Andrew4776 [OP] New Member
    Andrew
    2018 tundra trd off-road
    I thought of that, although the only thing I noticed was sag from the front, and the .5” tundra lean.
    here are some pics including the beat UCA ball joints
    C1F81E3B-8382-479D-9E7B-27D9BA376C28.jpg 8C0EF94A-9B7D-437B-BAB1-876812BB73C4.jpg C00DF46C-EDB8-4459-9C90-7FE567F73170.jpg
    2mchfun[QUOTED] likes this.
  3. Jun 29, 2021 at 12:48 PM
    Andrew4776
    Andrew
    Don’t mind how filthy it is, just came back from ~3500 mi road trip.
  4. Jun 29, 2021 at 12:50 PM
    Winning8
    Winning8 New Member
    Da Bay Area
    2019 MGM DC 4x4 SR5
    Your front shocks are gone bud
  5. Jun 29, 2021 at 12:51 PM
    Winning8
    Winning8 New Member
    Da Bay Area
    2019 MGM DC 4x4 SR5
    Toyota are known for bad shocks and leaf springs
    Andrew4776[OP] and 2mchfun like this.
  6. Jun 29, 2021 at 1:02 PM
    Andrew4776
    Andrew
    Lol yeah they are.. I’m going with 6112 and camburg upfront.
    I’ve also seen people get the SCP cam adjusters, is it necessary for my application or just skip that?
  7. Jun 29, 2021 at 1:12 PM
    2mchfun
    Might want to consider if you need to add front bump stop extensions, front sway bar drop spacers, and front differential drop spacers to keep cv shaft angles good
  8. Jun 29, 2021 at 1:21 PM
    Andrew4776
    Andrew
    Wouldn’t I need the diff drop only for 3”+ lifts?
  9. Jun 29, 2021 at 1:26 PM
    2mchfun
    I didn't know what your plans are for total height. I am a big fan of trying to keep both upward and downward travel unaffected if possible for just a few dollars. Id say if you are going 2 1/2 or more do it.
  10. Jun 29, 2021 at 1:30 PM
    2mchfun
    SPC cam adjusters might be needed when you get alignment done if those on your truck are seized with rust. Sometimes cutting off rusted parts is more practical than spending too much labor messing around.
    Andrew4776[OP] likes this.
  11. Jun 29, 2021 at 1:35 PM
    Yep. The carrier bearing and diff drop kits can both be had for around $60 total. Keeping proper geometry is always good. My front is 2.75". Zone uca's are pretty much level with the built in +3 caster (excellent alignment job too) and CV/axles. No driveshaft vibration either.
  12. Jun 29, 2021 at 4:28 PM
    Andrew4776
    Andrew
    I might do 1.5-2 in front and see what I’ll do with the back. My 6112 are gonna take a couple weeks to get here.
  13. Jun 29, 2021 at 4:29 PM
    Andrew4776
    Andrew
    Should I forget about it for now then, or get it while I’m doing this job while I’m at it
  14. Jun 29, 2021 at 4:29 PM
    Andrew4776
    Andrew
    Damn, that looks proper
  15. Jun 29, 2021 at 4:34 PM
    I used to do this sort of thing myself. (not the alignment) Paul, the installer, has done many aftermarket coilover lifts and what not over the years. Even more alignments. Worth every $.
  16. Jun 29, 2021 at 4:44 PM
    2mchfun
    Only you know the condition of your hardware, I have no idea whether or not the bolts are seized. If you can get them and return if you don't need them, you might want to bring them along to the alignment shop.
  17. Jun 29, 2021 at 4:58 PM
    TONKA TUNDRA
    TONKA TUNDRA HULK SMASH!!
    KY
    2014 DC Magnetic Grey
    Andrew4776[OP] and Black Wolf like this.
  18. Jun 29, 2021 at 5:07 PM
    There are so many many options a person can do. I'm focusing on the OP's thread title. "minor rear lift"...very many good points here so far. Decisions........
    2mchfun and Andrew4776[OP] like this.
  19. Jun 29, 2021 at 5:08 PM
    #49
    Andrew4776
    Andrew
  20. Jun 29, 2021 at 5:09 PM
    #50
    Andrew4776
    Andrew
    Yeah I never really looked into forums, this is my first. Everyone is pretty informative and helpful, appreciate it fellas
    2mchfun and Black Wolf[QUOTED] like this.
  21. Jun 29, 2021 at 5:12 PM
    #51
    TONKA TUNDRA
    KY
    Of course I forgot to take a pre-install measurement but my calibrated eyeball says around an inch with the topper installed. There's a before and after pic in the install thread link and you can see the difference. My goal was similar to yours, to add back some rake and it came out just about right.
  22. Jun 29, 2021 at 5:21 PM
    #52
    Andrew4776
    Andrew
    I got rear fox 2.0’s that are 0-1” lift since it was exactly what I was willing to do in the rear. That’s why I ask.
    Good looks though, your rig is clean
    TONKA TUNDRA[QUOTED] likes this.
  23. Jun 29, 2021 at 6:02 PM
    #53
    As I mentioned my 07 had OME coilovers up front and I got 2.75" with a winch bumper and winch. If I recall correctly, I went with the 614 coils. I have a Ranch Hand grille guard on now. A bit heavy. I'm running with Fat Bob Garage Vated coilovers set at 2.75". Contrary to what has been posted previously, the Fat Bob's are US sourced parts. The 700 lb rated coils are made in Utah at SpringWorks. Shock guts are Bilstein without the Bilstein sticker on the shock body. Saves a $100. Anyways, my 07 never got the CO made SPC's which I wanted. The OEM uca's slanted down a lot on my 07. Never hit my coils though but alignments were always marginal. Adding the Zone uca's on my 14 made a world of difference alignment wise. This goes with any decent aftermarket UCA. Aftermarket UCA's can go sky high $ wise, but once again it depends on budget and what you do with your Tunny. We have folks here that run the deserts hard. Real hard, so you budget accordingly. They even break shit. Shit happens. You jump a tunny going fast....gravity will win in most cases unless your tunny is built for that type of use. You do your best to minimize any potential damage. Most of us here aren't totally nuts and don't push our tunnies to the limit like they do. "Ahem"... Props to those who do and post their trials and tribulations here. That's a whole different ball game. Bottom line.....it's all relative to what you expect performance wise. Hauling ass, towing a camper, work truck use, and slow white cable guy stuff....heh....heh...
  24. Jun 29, 2021 at 6:11 PM
    #54
    2mchfun
    Fat Bob's here too, many haters here, but they are doing a great job with my heavy a55 Ranchhand bumper. And yes, everything depends on how you intend to use the truck.
  25. Jun 29, 2021 at 6:17 PM
    #55
    2mchfun
    For reference: FBG coilovers SPC UCA'S
  26. Jun 29, 2021 at 6:17 PM
    #56
    Fat Bob did have issues a few years back and was covered here. A bankruptcy. Under new management by a tech that witnessed the bs back then has turned around FBG bigtime. I was hesitant at first but quite pleased and the folks there know their shit. A same scenario happened here in Denver. RSG. Went to shit so some techs quit and started their own shop.
  27. Jun 29, 2021 at 6:26 PM
    #57
    I got the Zone's for $500. Not adjustable but having the built in caster and being fully boxed welded steel was nice. That being said...I have it in writing....if my Vated coilovers ever fail, they will replace. I said .."what if I jump my tunny"? Replaced....I'm an old fart now and not jumping anything much anymore. Ha!
  28. Jun 29, 2021 at 6:31 PM
    #58
    2mchfun
    Since we are on the UCA subject a bit, if you guys like SPC you might do what I did and order Mevotech from partsgeek. The box says Mevotech, but the parts are in fact SPC and you will save some coin..like about $130.
  29. Jun 29, 2021 at 6:36 PM
    #59
    True, but several folks are getting mismatched pairs. One side might not have a zerk. If you buy from @Toytec Lifts for example, you get a new set and customer support. I verified this with SPC here in Loveland. Edit....Longmont, RCI is in Loveland. Mevotech is old stock. Same thing when buying from RockAuto. SPC's rarely break, if ever, but I prefer buying from local dealers that get actual support from the mfr.
  30. Jun 29, 2021 at 7:44 PM
    #60
    2mchfun
    Yes, I am aware of the problems and I actually received each from a different warehouse plus the right side was missing all the hardware. Had to order another one and return the other. So, yes maybe not perfect but all said and done, I still saved and just thought others might like to know about the price difference. Thanks for informing them that there may be some hiccups, I was just trying to not derail the thread too much.
