Minimum lift to fit 35" tires on my TRD Pro?
Discussion in '2.5 Gen TRD Pro (2014-2021)' started by Worm, Dec 26, 2015.
  1. Mar 9, 2016 at 2:27 PM
    #61
    csuviper
    Broomfield, CO
    2019 TRD Sport CM 5.7L 4X4
    Haven't done much wheeling per say with the truck yet. Just a few light trails, mud and snow. Doesn't feel any different to me.
    Plan to do more this summer though as i hit the trails for camping.
  2. Mar 9, 2016 at 2:28 PM
    #62
    csuviper
    Broomfield, CO
    Yes i am. Corrects the speed and odometer and a little of the wandering gears.
    dcsleeper408[QUOTED] likes this.
  3. Mar 9, 2016 at 2:29 PM
    #63
    dcsleeper408
    dcsleeper408 BASTRDS
    mark
    San Jose CA
    2015 TRD PRO
    sweet thats good to know. thanks again. welp we'll see how it goes. going to try to get everything going by mid/late april
  4. Mar 9, 2016 at 5:00 PM
    #64
    bobeast
    bobeast really old member
    Bob
    Hollister, CA
    2008 DC
    I think the pro already sits 2" taller in front than does the non pro. Can probably get away with 1" of shims.
  5. Apr 14, 2019 at 11:54 AM
    #65
    Boricuabori2015
    Boricuabori2015 New Member
    Orlando
    2015 Tundra
    Just starting. Blacked out badges, custom leather interior.
    I know it's a old thread but I was curious what offset you did with this set up?
    Luckydwg likes this.
  6. Apr 14, 2019 at 7:36 PM
    #66
    jlee
    jlee New Member Vendor
    jerry
    Bay area CA
    2016 TRD Off Road on 35's supercharged and Kings and A 2002 SAS'ed supercharged Tacoma on 37's Linked front and rear
    Oh one or two.
    +25mm I'm pretty sure.
  7. Apr 14, 2019 at 7:39 PM
    #67
    csuviper
    Broomfield, CO
    SCS R818"x9." +25mm offset Matte gun metal w/ machined lip
  8. Apr 14, 2019 at 7:47 PM
    #68
    jlee
    jerry
    Bay area CA
    Oh one or two.
    What he said ^
  9. Apr 14, 2019 at 8:06 PM
    #69
    Boricuabori2015
    Orlando
    2015 Tundra
    Right on! I just noticed your from the bay too I'm in the east bay Antioch. Where did you go to get your wheels and tires? And that pic is a stock SR5 TRD off road. No lift just stuffed the tires in there right? I have the same truck and am worried about clearnccl issues into my garage if I put 35s on it. My garage is 6'9". Your help is much appreciated thanks in advance!
  10. Apr 14, 2019 at 10:20 PM
    #70
    jlee
    jerry
    Bay area CA
    Oh one or two.
    I didn't just stuff them in there. I had to cut the front bumper and pull out the fender liner. My build has everything I've done to it. https://www.tundras.com/threads/bamf-2016-crew-max-build.2607/
  11. Apr 14, 2019 at 10:41 PM
    #71
    Boricuabori2015
    Orlando
    2015 Tundra
    I was just quoting you.
    Mine is not even leveled I'm still a little low in the front and I can stuff 35's with just a little trimming and removing the front plastic.
    Thanks for the tip glad it can be done with just a little triming and removing the front plastic. I just wanted to be sure because most say you need at least a level lift. Thanks again
  12. Jul 19, 2019 at 8:09 PM
    #72
    ncomeau35
    ncomeau35 New Member
    North of Boston
    2019 White Toyota Tundra TRD PRO
    Nitro Ridge Grappler 285/75/18
    Im running Nitto Ridge Grappler 285/75/18 on my 19 TRD PRO, they are just north of 35" tires, and they fit my stock TRD PRO level kit with minimal rubbing on the front mud flap
    KERNEL_DALE likes this.
  13. Jun 11, 2021 at 10:08 PM
    #73
    Bjbbeauchamp
    Bjbbeauchamp New Member
    SRB, FL
    2020 Super White Sequoia TRD Pro
    Did you do the 35x12.50r18? I have a TRD pro sequoia and put a 2.5 spacer lift and 35x12.50 Nitto Ridge Grapplers with my stock 18 wheels. The tires are so close to the UCA I’m considering spacers or new wheels. Did you have to do spacers? And if so 1.25” or 1.5” spacers?
    @csuviper which spacers did you go with? this is my truck now while I try and figure out spacers. 2CC05BC2-C40D-45B7-AA43-FC35D3E3A980.jpg 2ED3E882-C853-4E39-93AF-A2B41D2DB29E.jpg
  14. Jun 12, 2021 at 11:21 AM
    #74
    dcsleeper408
    mark
    San Jose CA
    2015 TRD PRO
    Yes with oem wheels you will need spacers to get it away from the Uca.
    joonbug likes this.
  15. Jun 30, 2021 at 10:02 PM
    #75
    Mark73
    Mark73 New Member
    MGM 2020 Tundra TRD PRO
    ReadyLift SST 2” plus 2 Lift Kit, Coach builder +3 shackles & drop kit, Nitto RG 295/70/18
    Here’s the kit you need from David. I run 295/70/18 Nitto Ridge Grapplers and I’m happy with stock TRD wheels. Great look and ride.
    jimbrophotodotcom likes this.
  16. Aug 13, 2021 at 9:30 PM
    #76
    Bigbird57
    Bigbird57 New Member
    Yipes! Over kill IMHO.
  17. Aug 30, 2021 at 9:53 PM
    #77
    woofhauler
    woofhauler New Member
    Pacifica, CA
    Another option for 35s is 285/75/R18.
    Only removed the front flaps and has a completely stock fox pro suspension in this photo. They are on the skinny side, The duratrcas I have on are spec'd at 35.1 x 11.2 but no rub, no need to trim, and plenty of space between tire and UCA.
  18. Oct 2, 2021 at 3:28 PM
    #78
    UnicornHunter
    UnicornHunter New Member
    Brandon
    Smyrna, GA
    2021 Lunar Rock Tundra TRD Pro CM
    If I want to put 20x9 wheels and 285/65/20 KO2’s on a 21 Pro, am I gonna have to do a lot of modifying to avoid rubbing?
    Thanks
  19. Oct 8, 2021 at 4:50 PM
    #79
    boostedtrdpro
    boostedtrdpro voided warranty
    Jeremy
    2024 GMC Sierra 2500HD AT4X 2020 Sequoia TRD Pro 040
    Can anyone enlighten me as to how you con the tire shop (Discount Tire) into mounting true 35x12.50 on an 8” TRD Pro wheel? They say they flat will not sell them to me nor mount them. I mean, I’ve always known the minimum is an 8-1/2” wheel for a size like this, but I’ve never been told no by a tire shop. I guess I could go with a 285/75 at 34.8” or a 295/70 at 34.2”…I just really wanted them 35’s. Am I just being unreasonable and dangerous?
  20. Oct 8, 2021 at 7:19 PM
    #80
    boostedtrdpro
    Jeremy
    Screw it, simpletire it is…:thumbsup:
  21. Oct 8, 2021 at 9:46 PM
    #81
    1P7R9O4
    1P7R9O4
    AZ
    ‘17 White 1794 Pro
    Toyo and Nitto both make 35x11.5 that might be a better fit on the narrower wheel. Just a thought…but can’t remember if they have them for smaller than 20” or 18” wheels, but might be worth looking into. Not sure what the metric conversion is to get to 35’s with slightly narrower tires, but that would be another option
  22. Mar 25, 2022 at 7:19 AM
    #82
    SuperWhitePro19
    SuperWhitePro19 New Member
    2019 Trd Pro Tundra CrewMax
    Sitting on 275/65r18 duratracs, truxedo sport soft roll topper, home install bed lights
    how has this tire/ tire size done for you? Any road vibration/alignment issues? Would you buy them again?
  23. Mar 27, 2022 at 9:21 AM
    #83
    woofhauler
    Pacifica, CA
    Size and tire has worked out great. They are not highway tires but do run smooth. They have a nice AT rumble to let you know they are there but nothing like a MT tire. Would buy again.
  24. May 5, 2022 at 7:50 AM
    #84
    koifish
    koifish New Member
    2015 Inferno Double Cab TRD Pro
    Just put on 285/75r18 Geolandar X-AT, with stock trd pro Bilstein suspension. Tires measurements - 35.1” x 11.6”. Barely rubs front wheel well plastic at full lock in reverse.
    woofhauler, rruff and SuperWhitePro19 like this.
  25. May 5, 2022 at 8:53 AM
    #85
    GRADIEGO
    GRADIEGO New Member
    2019 VooDoo Blue Tundra TRD PRO
    I just threw 35 12.5 Toyos under my TRD Pro.
    Wescott preload collar in front. removed mudflaps. no UCA rub or need from BMC
    Coachbuilder +3 shackles in back
  26. May 5, 2022 at 9:43 AM
    #86
    rruff
    rruff New Member
    2016 Tundra SR DC Long
    Doesn't the collar add ~2.25"... giving you about 4" of lift now?
  27. May 5, 2022 at 10:26 AM
    #87
    GRADIEGO
    GRADIEGO New Member
    Picked up 1.5” w the Wescott Collar
    Started at 23.5” from midpoint on axle and sit at 25” now
    rruff likes this.
  28. May 5, 2022 at 11:00 AM
    #88
    Bo Dangles
    Bo Dangles New Member
    Jesse
    Canada
    2021 Tundra TRD Sport Premium
    Nice to see a few trucks running 285/75r18 without having to remove the front mud flaps. I might have to consider that route. Trying to keep the tires tucked in and protect the paint.
  29. Sep 1, 2023 at 6:06 AM
    #89
    Mac_Tundra
    Mac_Tundra New Member
    2020 Tundra TRD Pro
    I just bought a 2020 Tundra TRD Pro and looking to add 35. Reading the comments it seems like that not possible unless I modify it. What is the best/cheapest way to do this? I really don’t want to add wheel spacers since I don’t want to damage the paint from rocks kicking up. I’m a newb to this kind of stuff so any help would be greatly appreciated! :)
  30. Sep 1, 2023 at 8:05 AM
    #90
    rruff
    rruff New Member
    A "35" is nominally 34.6" tall. A 295/70r18 is 34.3" tall. A 285/75r18 is 34.8" tall. Both will fit on your stock rims just fine, and you'll have enough clearance to the UCA.
    You don't need wheel spacers or a lift. You *may* need to mod the front of your wheelwell plastic... and when you get an alignment, bias towards high caster to make sure you can retain the rear mudflaps... which I'm sure you want to do to. This is easy enough and cheap/free if you do it yourself.
    If you want to be sure to avoid doing anything at all, 275/70r18 (33.2") are about as big as you'd want to go. Tires in that size are cheaper also.
