Milky Oil In Cap
Discussion in '1st Gen Tundras (2000-2006)' started by Filthyphil, Sep 28, 2019.
  1. Sep 28, 2019 at 4:00 PM
    Filthyphil
    Filthyphil [OP] Lions Not Sheep
    Phil
    2000 Toyota Tundra TRD 4.7
    Fellas.... I was doing some under hood inspections today and noticed a little bit of milky oil in the letters and some water bubbles inside my oil cap. Should this be something to worry about? I haven’t seen any coolant loss in the reservoir.
  2. Sep 28, 2019 at 4:03 PM
    Padj
    Padj Life is what happens when you're making plans
    Denver, Colorado
    2019 Limited CM TRD MGM
    My first guess would be a head gasket.
  3. Sep 28, 2019 at 4:07 PM
    Filthyphil
    Phil
    the oil has about 1,000 miles on it, when I last did it the oil looked normal. The truck does sit all week and is used for mainly short trips a lot so I have read that can cause some condensation.? I’m hoping....
    speedtre, Casper421 and 15Yota like this.
  4. Sep 28, 2019 at 4:08 PM
    Drew C
    Drew C New Member
    I used to see that from time to time on my Tacoma, never had any problems.
    Filthyphil[OP] likes this.
  5. Sep 28, 2019 at 4:11 PM
    Aerindel
    Aerindel New Member
    Montana
    That is the most likely explanation.
    There is a reason for the crank case ventilation system after all. Pull your dipstick or drain your oil, if it looks okay then you are probably fine. A true HG coolant to oil leak will make all your oil look milky, not just a very small amount on the cap, condensation there is normal.
  6. Sep 28, 2019 at 4:11 PM
    Filthyphil
    Phil
    I’ve never dealt with anything like this before so I’m just a little confused, my 1996 Tacoma has 300,000 miles and cap is perfectly clean so that had me a little nervous.
    15Yota likes this.
  7. Sep 28, 2019 at 4:18 PM
    Aerindel
    Aerindel New Member
    Montana
    It depends a lot on how you drive. Sitting long times and short trips are notorious for this. Normally some moisture gets into the oil from blow by through your rings but when you fully warm up the engine the oil is at about 180º so the water evaporates out and is sucked through your PCV valve and re-burned, but short trips can mean it never runs long enough to pull all the moisture out. When you shut off your engine that water vapor just hangs out in the crank and can condense on the inside of your cap.
    Now, of course head gaskets CAN fail but the amount you are showing in your photo looks just fine. Now, if you pull your dipstick and the oil is milky thats a problem.
    Jengel451, speedtre, kparrow and 2 others like this.
  8. Sep 28, 2019 at 4:23 PM
    KarmaKannon
    KarmaKannon Master of None
    Utah
    2006 Double Cab w/long travel
    Some junk
    You don't have to drain much to check it. I'd pull the plug and let a cup out and see what it looks like. That's if I couldn't see what color it was just from the dipstick.
  9. Sep 28, 2019 at 4:31 PM
    RollTide82
    RollTide82 New Member
    Michael
    2019 Tundra 4x4
    Mine did the same thing cause I had a one mile drive to work. Never enough time to heat up. In saying that truck has 230,000 miles when I got rid of it.
    GODZILLA and Filthyphil[OP] like this.
  10. Sep 28, 2019 at 4:34 PM
    kparrow
    kparrow New Member
    Kevin
    Nampa, ID
    This. Short infrequent trips the condensate can accumulate.
  11. Sep 28, 2019 at 4:40 PM
    15whtrd
    15whtrd Mr. Blonde
    I concur, too many short trips. Next time take the long way home LOL
  12. Sep 28, 2019 at 4:51 PM
    hagrid
    Spraynard
    Pittsburgh
    K1600GTL ZX-14R
    paynuss stretchers
    You just found your culprit: short trips.
  13. Sep 28, 2019 at 4:55 PM
    MS22
    MS22 New Member
    02 Tundra 4x4
    Agree my 02 will do that if I do short trips.
    YardBird and Filthyphil[OP] like this.
  14. Sep 28, 2019 at 4:56 PM
    marbleville
    marbleville Agent Provocateur
    Yep, last name too.
    State of Confusion
    2002 Thunder Gray Metallic TRD.
    Air freshener died, washer fluid empty, wipers streak.
    Not that it is a rule of any kind, but in the past I've associated a sweet smell to my exhaust (anti-freeze) as a sign the head gasket may have failed or a crack in a coolant passage in the head. Just saying...
    Grumpy74 and Filthyphil[OP] like this.
  15. Sep 28, 2019 at 5:05 PM
    hagrid
    Spraynard
    Pittsburgh
    K1600GTL ZX-14R
    paynuss stretchers
    This is accurate. If it's bad enough you can get misfire codes as well.
  16. Sep 28, 2019 at 5:08 PM
    Filthyphil
    Phil
    I have also heard tasting the water that comes out of the tail pipe could help if it’s sweet also. It smells good and doesn’t steam. I think I’m going to drain some oil out tomorrow and see what it looks like. I’ll check the dip stick later tonight when I get back home too.
    marbleville[QUOTED] likes this.
  17. Sep 28, 2019 at 5:12 PM
    marbleville
    Yep, last name too.
    State of Confusion
    Well don't get carried away in the tasting.:burp: Pets die all the time from drinking the stuff. Duh.
  18. Sep 28, 2019 at 6:08 PM
    Filthyphil
    Phil
    Could my PCV valve being original contribute to any of this by chance too?
  19. Sep 28, 2019 at 6:40 PM
    TundraMcGov.
    Jofus
    Burpinham, Babalama
    No.
  20. Sep 28, 2019 at 6:51 PM
    Filthyphil
    Phil
    That’s a Texas sized 10-4
    KarmaKannon and bmf4069 like this.
  21. Sep 28, 2019 at 6:56 PM
    FirstGenVol
    FirstGenVol Brake Czar
    East TN
    2002 AC
    Hand Model posted a very similar picture to yours a few months ago. I agree with the others, likely nothing to be worried about
  22. Sep 28, 2019 at 7:30 PM
    Filthyphil
    Phil
    Damn must have missed it, oil looked good tonight. I’m going up in the hills early tomorrow for a few hour drive to find some elk so I’ll check the cap after putting 100 or so miles on it. But I feel pretty good about it after you guys helped talk me down. Thanks for the help guys appreciate it:thumbsup:
    GODZILLA and KarmaKannon like this.
  23. Sep 28, 2019 at 7:45 PM
    ZappBrannigan
    Canada, by way of Hawaii
    2018 1794 MGM
    NVS light bar
    Small cracks in the head will do this as well. And spit water right into the oil up top...
  24. Sep 28, 2019 at 8:53 PM
    Aerindel
    Aerindel New Member
    Montana
    Well, it won't go away unless you clean it off, but it may not occur again if you clean it off and drive for long enough to heat up all your oil and get the trace moisture out before shutting off the engine.
    But what you have right now is not a problem regardless of why it's there. It's only a problem if it gets dramatically worse.
  25. Sep 28, 2019 at 9:38 PM
    Batel
    Batel New Member
    2019 Tundra SR5 TRD Offroad
    Plastic caps, especially on plastic extentions are always prone to this when the engine driven short trips.
  26. Oct 5, 2019 at 12:16 PM
    Professional Hand Model
    Hand Protectors
    Adding to the mix of diagnoses/solutions here.
    Back fill: My truck is a 2002 4.7L. Never had a problem (snot on inside cap) until I made a switch over to full synthetic oil. Truck for 17 years ran on dino and then was moved to syn/blend.
    In 2018, I took over maintenance on the truck and decided on Mobil 1 Extended Performance Oil Full Synthetic as it was on sale and came with the Mobil filter. A thousand miles on the oil I noticed a finger tip of snot on the cap. Also, I noticed (very slight) weeping around the oil pan gasket. This oil has high parafins in it and the molecules are very uniform so older gaskets can’t handle the new tech.
    I did also observe a slight oil film on my last coolant drain and fill right after the initial snot observation.
    Theory Conclusion: Some coolant leaked into the engine case due to the high detergent action and penetration of the syn oil. This is fairly normal on most cars regardless of oil type from my readings.
    I cleaned the snot off and monitored the cap. Changed the oil another thousand miles in over to ‘High Mileage’ Mobil 1 Synthetic which has seal conditioner. Weeping has stopped. I’m on my 3rd oil change since last year. Engine feels peppier now than last year.
    No film currently on the coolant. No snot on cap. Lessons learned and should have put High Mile Syn in the first place, instead of the Ext. Performance.
    Here is a good link from a shop owner about the subject. You can link around and learn more.
    http://www.agcoauto.com/content/news/p2_articleid/122
    Report back on your new oil type Phil.
  27. Oct 5, 2019 at 12:23 PM
    Hand Protectors
    revtune, Filthyphil[OP] and Pinay like this.
  28. Oct 5, 2019 at 12:24 PM
    Pinay
    Pinay New Member
    Monet
    Mahal kita Kuya
    Good to see you back dude!!! Everyone’s been asking about you!
  29. Oct 5, 2019 at 12:27 PM
    Randy Morton
    Randy
    Deepinahearta, Texas
    2012 Tundra Double Cab, Beta Variant (I call it my Land Yacht)
    Take a nice long drive and check the cap and the dipstick. That's probably condensation from the short trips. Getting the engine up to full temp for a while will evaporate the moisture. If it's a problem, the oil on the dipstick will still be milky when the engine's at full temp.
    YardBird likes this.
  30. Oct 5, 2019 at 12:33 PM
    Hand Protectors
    Thank you. Been busy with Dereks Center for Kids Who Can’t Read Good. Glad to be missed.
