Mike's DIY "Raptor Style" LED Mod Thread
Discussion in '2.5 Gen Tundras (2014-2021)' started by ToyotaTundraMike, Jan 30, 2016.
  1. Sep 25, 2016 at 3:41 AM
    #61
    rons23
    rons23 Get The Led Out!!!
    Ron
    Kill Devil Hills
    2008 Nautical Blue TRD
    I was wondering what that plastic coil was around the wire, thanks for the wiring 101 lesson there Ron
    NewImprovedRon likes this.
  2. Sep 25, 2016 at 3:58 AM
    #62
    rons23
    Ron
    Kill Devil Hills
    This is a great write up, thanks to everyone's input. Will be doing this once I bullet line my grill surround and repaint my grill. Great work guy's :cool:
  3. Sep 25, 2016 at 5:45 AM
    #63
    TTU19
    TTU19 Wreck 'Em
    Wes
    Tx
    2021 TRD Sport
    Yeah I'll have to check it out when I get back from my photo session this morning. I basically want them on all the time so gotta find the fuse to do that.
  4. Oct 30, 2016 at 5:32 PM
    #64
    xando
    xando New Member
    Oregon
    Tundra TRD OFF ROAD 2015 crewmax/ silver metallic
    Where do you guys find the 5AMP AMT LP fuse? I can not purchase it anywhere. Is there a place on-line? Any link?
  5. Oct 30, 2016 at 5:35 PM
    #65
    TTU19
    TTU19 Wreck 'Em
    Wes
    Tx
    2021 TRD Sport
    I found the little fuses at Autozone, along with the fuse tap.
  6. Oct 30, 2016 at 5:57 PM
    #66
    ToyotaTundraMike
    ToyotaTundraMike [OP] Not A New Member
    2015 Tundra
    My regular auto part store didnt have them in the low profile version but I was able to find them at auto zone or one of those places as well, cant remember if it was them or advanced auto parts. Look around in your area someone should have em.
  7. Oct 30, 2016 at 5:59 PM
    #67
    xando
    xando New Member
    Oregon
    I went there too and bought the assorted mini LP fuses. The lowest amp is 7.5 which I used it without good results now.
    I looked on-line, but could not locate these damn 5AMT LP fuses....:annoyed:
  8. Oct 30, 2016 at 8:12 PM
    #68
    xando
    xando New Member
    Oregon
    i found them at Amazon.com
    you need to search "ATM 5LP mini fuse"
    it ships free for 5bucks (six of them)
  9. Oct 30, 2016 at 9:33 PM
    #69
    Que pasa TTU? What's the 19? When u graduate?
  10. Oct 31, 2016 at 6:28 AM
    #70
    TTU19
    TTU19 Wreck 'Em
    Wes
    Tx
    2021 TRD Sport
    Just my favorite number. I graduated in '04, but that was already taken, so I went with 19.
  11. Oct 31, 2016 at 6:35 AM
    #71
    Alrighty then
  12. Nov 5, 2016 at 5:48 PM
    #72
    vidman
    vidman New Member
    Rick
    Massachusetts
    004.jpg 029.jpg These are my hood bulge LEDs
  13. Nov 5, 2016 at 5:58 PM
    #73
    xando
    xando New Member
    Oregon
    Rick,
    Where did you buy those (part number & price)?
    How did you install in your truck?
    More close up pics please!!
  14. Nov 5, 2016 at 6:04 PM
    #74
    ToyotaTundraMike
    2015 Tundra
    Nice job man! Also interested in how you mounted em and where they came from!
  15. Nov 5, 2016 at 6:08 PM
    #75
    vidman
    vidman New Member
    Rick
    Massachusetts
    I got them from Super Bright LEDs. They are waterproof big rig -trailer-clearance lights. i used 8 of them at 6 bucks each. they just fit into that bulge pocket and used some aluminum angle to mount them003.jpg 005.jpg 006.jpg
    Mountun Goat, geno0506 and PR_02 like this.
  16. Nov 5, 2016 at 6:09 PM
    #76
    vidman
    vidman New Member
    Rick
    Massachusetts
    These are the only pics that i have
  17. Nov 6, 2016 at 8:46 PM
    #77
    xando
    xando New Member
    Oregon
    i used your idea and moved my LED lights into the bulge.
    i like there better than orinal mod
  18. Nov 6, 2016 at 9:29 PM
    #78
    ToyotaTundraMike
    2015 Tundra
    Looks good man! Did you just measure and drill your own holes to mount em?
  19. Nov 7, 2016 at 3:22 PM
    #79
    xando
    xando New Member
    Oregon
    Yes. Behind the plastic mesh of the bulge there are 4 'pockets'. I drilled the holes on its center and about 10mm from the edge. I inserted the 4 LED lights from the bottom into vertical position so they stand up. Wire connection is exactly the same. Then, attach everything back.
    It's very clean look. The original mod I could see the inside of the truck when lit.
  20. Nov 7, 2016 at 4:04 PM
    #80
    ToyotaTundraMike
    2015 Tundra
    Nice! May have to try it like that next time around.
  21. Nov 16, 2016 at 1:29 PM
    #81
    Matte Tundra
    Matte Tundra New Member
    2017 TRD PRO Cement
    www.tctwraps.com
    So, I am going to be doing this mod as well.. As for wiring, I want the LED's to be on whenever the amber driving lights are on. Which it seems like they are on anytime the parking b rake is off. So where is the best slot to connect my add a circuit? The IGN? TAIL?
    Again, I want them on whenever the driving lights are automatically on. I don't want a switch nor have to turn my headlights on.
    Thank you!
  22. Nov 16, 2016 at 1:37 PM
    #82
    Krezz
    Krezz Doesn't want to be new member
    Kevin
    Southern Ontario, Canada
    2022 Tundra Crewmax Hybrid TRD Pro
    Sub'd to this one as this is a great upcomer.
  23. Nov 16, 2016 at 1:44 PM
    #83
    ToyotaTundraMike
    2015 Tundra
    Matte, I think the IGN would be a good place to try first if you wanted them on all the time whenever the truck is on.
    Personally I would do it into the TAIL, that way you could have them off if you didn't want them on, but could also have them on without the headlights or with. On mine I wen't into the headlights because I was too lazy to route the wire all the way into the cab to get to the TAIL fuse.
  24. Nov 16, 2016 at 1:51 PM
    #84
    Matte Tundra
    2017 TRD PRO Cement
    www.tctwraps.com
    Thanks for the quick response!
  25. Nov 16, 2016 at 2:04 PM
    #85
    AnonVet
    AnonVet That's what she said!
    Weatherford TX
    2015 TRD SR5 CM
    7 inch pro comp 35x12.5 RPB Repulsars (Hate'em) 18x9 Rhino Glamis Bilstein 5100's TRD Pro grille Murdered out Spyder heads Smoked tails Leds all around her Debadged Go Rhino BR5 Front Bumper
    Has anyone looked into dampening the light a little and making it a bit more "raptorish" so to speak. I like this mod a lot but I'd rather not have the LED's light up the whole underside of my grill. I'm thinking about going all "nerd" on this possibly modding in some flush mount LED's but once I cut, there is no going back.
  26. Nov 16, 2016 at 3:02 PM
    #86
    csuviper
    Broomfield, CO
    2019 TRD Sport CM 5.7L 4X4
    I am considering trying to light up the whole area behind the top grill (hood bulge) rather than just 3-4 lights showing.
    Not sure if this is achievable without making it look like individual bulbs. Thoughts?
    Going to have to test out running a strip of LEDs and see what it looks like.
    Fiesta346 and Mountun Goat like this.
  27. Nov 16, 2016 at 3:05 PM
    #87
    csuviper
    Broomfield, CO
    Kinda like this so the individual bulbs don't show.
    #87
    Mountun Goat likes this.
  28. Nov 16, 2016 at 3:15 PM
    #88
    vidman
    vidman New Member
    Rick
    Massachusetts
    This is what i was going to try if i didn,t like my first attempt. I think it would look good with the LED strip or strips
  29. Nov 16, 2016 at 3:19 PM
    #89
    ToyotaTundraMike
    2015 Tundra
    Sounds cool, not sure how that would work either though. What color are you thinking about doing? Maybe some of the amber ones that vidman posted lined up next to eachother could give you that look?
  30. Nov 16, 2016 at 6:19 PM
    #90
    xando
    xando New Member
    Oregon
    I have done under the bulge. I did not like how the lights were showing behind the grill.
    Even my wife (who usually gives me hard time) said the truck looks cool
    geno0506 and NewImprovedRon like this.
