Mike's Build page.
Discussion in '1st Gen Builds (2000-2006)' started by Mike, Apr 29, 2015.
  1. Jun 29, 2016 at 3:01 PM
    #121
  2. Jun 29, 2016 at 9:00 PM
    #122
    Mike [OP] Tread lightly.
    south carolina
    It tags in at 60 pounds it's not light.. IMO its worth it..
  3. Jun 29, 2016 at 11:10 PM
    #123
    south carolina
    Looking into replacing the factory steps.. since bamf and relentless doesn't make them for my year(hint hint)..... what to do...
  4. Jun 30, 2016 at 5:41 AM
    #124
    Definitely worth it.
  5. Jun 30, 2016 at 5:41 AM
    #125
    Hint Hint X 2
  6. Jul 3, 2016 at 7:34 PM
    #126
    south carolina
    White knuckle or all pro for sliders.. since I must replace the factory steps..
  7. Jul 8, 2016 at 4:24 PM
    #127
    south carolina
    This is in beta testing(Tacoma) but so far I like it... tho the tundra does have capabilities of shore power it's needs remote settings too.
    Tho this set up will be identical on both trucks minus the different solar array used. Tundra will use a flat panel (sheet) solar array still at 100watts..
    100 watt (Italy made solar panel)
    Morningstar pm15.
    10 awg (solar wiring) for solar to battery and panel. Not shown is the remote sensing the controller does..
    This controller used, doesn't need to be disconnected when engine is running or starting.. Everything is done automatically when voltage is at specific voltage the controller shuts down and kills solar array till engine is shut down and controller will resume normal operation...
    6b4e224c59f00f7ddd8166cfb6aceff9_b45266611eac9824550114903e9b6f5dd01b8f64.jpg solar array
    Controller.. it's floating when I took the pic.. battery is at 14.3 volts.. showing amps off the solar array used now..
    Edit added clarification..
    Black Wolf and TruckyTruck like this.
  8. Jul 24, 2016 at 7:30 AM
    #128
    south carolina
    dd8bedea7081b416e5d75175dadcc794_d1382246662a2e0cb8a2c37f141d5d89e66ac0d2.jpgnew one
    Not only did the lens crap out so did the LEDs..
  9. Jul 24, 2016 at 7:32 AM
    #129
    south carolina
    Finally added the carbon fiber trim to the top and got rid of the rubber seal up there which looked bad...
    T-Rex266, Black Wolf, rons23 and 2 others like this.
  10. Jul 24, 2016 at 8:37 AM
    #130
    frogger
    frogger just boost it
    Stephen
    Louisville Ky
    2008 S/C Tim Mica SR5 5.7L DC 4X4
    too much to list
    Looks good...even on my second gen I have had to re-glue a corner of mine down due to flapping in the wind. The factory rain gutters just take a whoopin' in the sun.
  11. Jul 26, 2016 at 11:21 AM
    #131
    south carolina
    Sliders have been shipped. Will be modified work before paint and trash the factory ones.
    T-Rex266 likes this.
  12. Jul 26, 2016 at 11:32 AM
    #132
    Which sliders did you go with??
  13. Jul 26, 2016 at 12:00 PM
    #133
    south carolina
    I went with all pro design(ugh) . I was going to with white knuckle but shipping cost was too high for the east coast..
    I will be pulling the welder out I'm going to do some custom work to it before paint and install.
    NewImprovedRon and csuviper like this.
  14. Jul 26, 2016 at 12:05 PM
    #134
    csuviper
    Broomfield, CO
    2019 TRD Sport CM 5.7L 4X4
    What kind of custom work? Interested. :popcorn:
  15. Jul 26, 2016 at 12:06 PM
    #135
    csuviper
    Broomfield, CO
    I have two sticks of 1.5" DOM tubing just itching to be made into something. Just need a tube bender and welder and im set.
  16. Jul 26, 2016 at 12:32 PM
    #136
    south carolina
    I have the welder and gas and plasma cutter. the local metal supplier, I will stop by this week and do some paper and pen work.. I have something in mind..
    But I really need to see them in my hands see how good or how poorly it's done and reengineer it some.
  17. Jul 26, 2016 at 12:52 PM
    #137
    If I remember correctly White Knuckle is out in Kommiefornicatia...Probably super high shipping cost.
  18. Jul 26, 2016 at 12:55 PM
    #138
    south carolina
    Bamf(Jerry) did work for me and his prices where good.. some people just rip you off in shipping...
  19. Jul 30, 2016 at 12:30 PM
    #139
    south carolina
    Ok finally.. c62aba25353437aa6577a3e76744fa05_2f68caaa57122d9debf50f8d3ab17357bca1f672.jpg175859de25d5da9dd3b206c54419243f_3d4f8ca25c62f680c1754fd394fb554ee7a89cf0.jpgb850de3cf509f390fd54f966350749ca_a5b39ed56edb732d309b8800fda1d2d2211f26f2.jpg111769679c5b7d4b560327d8c6601e58_35565e5ee09b02bbbed621e076669e5d67936d21.jpg
    Then I got BORED.. dfc4fde5e705f76df2f01a32935f43e8_f90a3fdf587a3c6e10414c8cfe61b9f8943efdc8.jpg98765dd7d4cb1508ca61c24e30495a58_b1a04fa633c61a48a578cff99ff2a3fef9659b54.jpg
    Paracord has reflective strip as it showed up in a few pics.
  20. Jul 30, 2016 at 12:35 PM
    #140
    Nifty. I like the reflective strip.
    Mike[OP] likes this.
  21. Jul 30, 2016 at 1:20 PM
    #141
    south carolina
    I was on the fence about it.. not bad..
  22. Jul 30, 2016 at 1:50 PM
    #142
    Now if you could next print out a SC, that would be way cool........
  23. Jul 30, 2016 at 1:56 PM
    #143
    rons23
    rons23 Get The Led Out!!!
    Ron
    Kill Devil Hills
    2008 Nautical Blue TRD
    Hells yes Mike, looks good. I like the reflective through it. Also forgot to comment on the carbon fiber weather strips you posted, nice little face lift. Next on my short list :cool:
  24. Jul 30, 2016 at 2:21 PM
    #144
    south carolina
    No more printing for me for a long time..
  25. Jul 30, 2016 at 2:22 PM
    #145
    Sounds like the printing takes up a lot of your time. I would imagine you have other things to do.
  26. Jul 30, 2016 at 2:24 PM
    #146
    south carolina
    You must have missed it check my other build page on that last two pages.. edit page 24 on Tapatalk that is.
  27. Jul 30, 2016 at 2:31 PM
    #147
    I'm up to date now. Sorry I missed that. Explains everything though. Guess my key fob is a collector piece already, heh heh. Hey, you've got to advantage of whatever comes up. Keeps life from getting too boring.
  28. Jul 30, 2016 at 2:35 PM
    #148
    south carolina
    If @RowdyRon ever posts the last piece I did there might be a fight...
  29. Jul 30, 2016 at 2:36 PM
    #149
    :duel:
  30. Jul 30, 2016 at 2:42 PM
    #150
    south carolina
    Main page has been updated to reflect progress now.
