Midland USA Promo Code - 15% off
Discussion in 'Deals & Group Buys' started by the_midwesterner, Jan 25, 2021.
Thread Status:
Not open for further replies.
  1. Jan 25, 2021 at 3:04 PM
    the_midwesterner
    the_midwesterner [OP] New Member
    Luis
    None, yet....
    Hey folks,
    Wanted to share the love. Midland USA reached out to us and provided a discount code. Figured I’d share on here and pass on the discount. Code is good for 15% off.
    Discount code: 4lobound15
    We used it for some GMRS radios and small handhelds for the kiddos to get them involved. Here’s some pics of one of our setups. We used an MXT115 hard wired to the battery and a 3db gain Ghost antenna on an extended ditch light bracket mount.
  2. Jan 25, 2021 at 3:25 PM
    Piki
    Piki New Member
    2017 Tundra crewmax 1794 TRD
    I was about to pull the trigger. Thanks
  3. Jan 25, 2021 at 7:34 PM
    the_midwesterner
    Luis
    None, yet....
    Cool. Glad to hear that it helped you save some money.
    Piki[QUOTED] likes this.
  4. Jan 25, 2021 at 7:48 PM
    Where did you get the ghost antenna from?
  5. Jan 25, 2021 at 7:57 PM
    the_midwesterner
    Luis
    None, yet....
    From Midland. Here you go. Specifically tuned to work on GMRS 462.xxx frequencies though.
    YotaBro and Jim LE 1301[QUOTED] like this.
  6. Jan 25, 2021 at 7:58 PM
    :hattip:
  7. Jan 29, 2021 at 6:15 PM
    YotaBro
    Calvin
    FL
    Lots of shenanigans.
    I have the Midland 115 coming in, any idea which fuse that I should tap into? Sorry, not very familiar with electrical stuff. This is what Midland sent me when I asked, but not entirely sure what to do still. I would like to hardwire the radio to the interior fuse box.
  8. Jan 29, 2021 at 7:51 PM
    the_midwesterner
    Luis
    None, yet....
    You set on tapping into fuses? We normally just shield the wires with loom and then route them outside directly to the battery. That allows you to use the radio, even if the truck is off. There is even a little nipple on the harness grommet that is perfect for running a couple wires.
  9. Jan 29, 2021 at 7:53 PM
    YotaBro
    Calvin
    FL
    Nope, open to any suggestions. I was gonna open that nipple for the antenna, my worry is that it would take up too much room though, thoughts? I also plan on having a We Boost Antenna in the future so I'm worried that it would take up all of the space that hole would provide. Tapping into the fuses just seemed to be the easiest option.
  10. Jan 29, 2021 at 7:56 PM
    YotaBro
    Calvin
    FL
  11. Jan 29, 2021 at 8:29 PM
    the_midwesterner
    Luis
    None, yet....
    The grommet on the passenger side has 2 nipples. Run the antenna to the passenger side and there’s a good spot behind the dash to put the excess cable, if you have any. I’d run the weboost through there too.
    We run the extension from caliraised. Something like this.
    YotaBro[QUOTED] likes this.
  12. Jan 29, 2021 at 8:41 PM
    YotaBro
    Calvin
    FL
    Thanks for the advice! By any chance would you have pictures of the grommet on the passenger side? Is it bigger than the driver grommet? Seems like the cable for the antenna is gonna be thick.
  13. Jan 29, 2021 at 8:41 PM
    YotaBro
    Calvin
    FL
    And just ordered that CB extension! I already have their ditch light brackets so this will work perfectly!
    the_midwesterner[OP] likes this.
  14. Jan 30, 2021 at 9:04 PM
    the_midwesterner
    Luis
    None, yet....
    I’ll have to get one tomorrow, but it should fit. I’ve had success cutting the end of the nipple off and then slitting it down the center so that it stretches a bit. Hopefully that makes sense.
  15. Jan 30, 2021 at 9:14 PM
    YotaBro
    Calvin
    FL
    any issues with slicing it down more? as in exposing the cabin to the outside since the nipple will have a larger gash in it?
  16. Jan 30, 2021 at 9:24 PM
    TheBeast The Beach
    good timing. FCC just approved my GMRS license :)
  17. Jan 30, 2021 at 11:12 PM
    the_midwesterner
    Luis
    None, yet....
    I’ve done this to 2 personal Tundras and a tacoma. Never had an issue. Unless you’re fording water to that level, minimal quantities of water, if any will hit there to saturate and leak in.
  18. Jan 31, 2021 at 5:17 AM
    YotaBro
    Calvin
    FL
    How far would you say that you slice?
  19. Jan 31, 2021 at 11:23 AM
    TheBeast The Beach
  20. Jan 31, 2021 at 1:09 PM
    the_midwesterner
    Luis
    None, yet....
  21. Jan 31, 2021 at 1:14 PM
    the_midwesterner
    Luis
    None, yet....
    Here you go. There is a nipple on the top and the bottom. Chop off the nipple end and split it.
  22. Jan 31, 2021 at 4:22 PM
    YotaBro
    Calvin
    FL
    Thanks!!! I wired it to the fuse box today, waiting to wire the antenna
  23. Jan 31, 2021 at 4:24 PM
    YotaBro
    Calvin
    FL
  24. Jan 31, 2021 at 6:25 PM
    YotaBro
    Calvin
    FL
    So I noticed that channels 8-14 (FRS) aren't included, so how do we talk to FRS channels? I'm pretty new to this, as in I just installed it a couple hours ago so trying to figure everything out before I go off roading in a couple weeks.
  25. Feb 3, 2021 at 2:26 PM
    PRO5
    PRO5 New Member
    2019 Tundra Limited TRD
    Appreciate the code. Basically copied you on the 115 and the kids walkies. The little guys will be stoked.
  26. Feb 8, 2021 at 10:30 AM
    eick
    eick New Member
    2020 CrewMax TRD Off Road
    Yea sorry to break it to you but you can't on that radio :(
    You're limited to the shared freq's as the 8-14 are FRS only
  27. Feb 12, 2021 at 8:37 PM
    the_midwesterner
    Luis
    None, yet....
    Hey guys, sorry for the delayed reply, but I forgot about this. Yes, what he said. Depending on your radio, some are GMRS only and some are both.
  28. Feb 18, 2021 at 5:59 PM
    the_midwesterner
    Luis
    None, yet....
    Bump.
    20% off with code: 4lobound20
    Code is good through 2/27/21. Enjoy folks!
    NWPirate, RJVA, Piki and 3 others like this.
  29. Feb 18, 2021 at 6:22 PM
    TheBeast The Beach
    say whattttt
  30. Feb 18, 2021 at 7:09 PM
    YotaBro
    Calvin
    FL
    Shoulda had this a month ago when I was buying lol
    TheBeast[QUOTED] likes this.
Thread Status:
