Mictuning dual USB installation help..
Discussion in '2.5 Gen Tundra Parts Marketplace (2014-2021)' started by phabej, Oct 30, 2019.
Thread Status:
Not open for further replies.
  1. Oct 30, 2019 at 8:02 PM
    phabej
    phabej [OP] New Member
    Washington
    2018 Platnium
    Hello, had anyone installed the mictuning 6.4A Car Charger with LED Light Qualcomm 3.0 Quick Charger for Toyota 12-24V?
    I just bought it and no instructions came with it. I'm guessing I need to slice or tap it as the plug doesn't for OE wires.
    Ideally it might need a constant power cause I want to use it without having to turn the key.
    Thanks
  2. Oct 30, 2019 at 8:35 PM
    phabej
    Washington
    2018 Platnium
    Moderators please move to the 3rd gen forum. I created in wrong section. Thanks
  3. Oct 30, 2019 at 8:53 PM
    computeruser6
    computeruser6 Gott Mit Uns
    Dirk
    Escondido
    2008 Regular Cab Tundra
    You could get a fuse tap and get power from the interior fuse box. I have mine powered from a separate fuse box in the engine compartment that I use for all of my aftermarket accessories.
    Fuse Tap example 1 Fuse Tap example 2
    bensky likes this.
  4. Oct 31, 2019 at 5:55 AM
    phabej
    Washington
    2018 Platnium
    Awesome thanks.
  5. Oct 31, 2019 at 6:03 AM
    Jrharvey02
    Jrharvey02 New Member
    2010 Tundra CM 5.7 Platinum Dark Black
    You don’t need to run an add-a fuse for this simple instal. I assume you’re going to be removing a cigarette power adapter and replacing it with this usb? If so, you just need to tap into the two wires powering the cigarette power. I would avoid cutting the harness off the vehicle harness, simply tap into the power and ground wire using these...
    ALEDECO 12 Pack Low Voltage T Type Wire Connectors 2 Pin Solderless No Wire Stripping Required for Mid-span Branching in Wires Connection Fits 20/22 AWG Cable Wires https://www.amazon.com/dp/B07MTB7VRP/ref=cm_sw_r_cp_api_i_ISTUDb1VA3XJZ
  6. Oct 31, 2019 at 6:33 AM
    phabej
    Washington
    2018 Platnium
    the only reason I don't want to tap the existing cigarette power is i want a constant on. In case I want to charge my phone, tablet or battery pack i don't have to put my key in.
    I may have to find a fuse that has constant power or find a tap that is constant though. I'll look into the ALEDECO..
  7. Oct 31, 2019 at 6:34 AM
    Zebruaj
    Zebruaj New Member
    MN
    08 CM SR5
    Like ^^ said, tap it into your cig lighter for quick and easy/lazy install. Or any 12v source of your liking. I recall most of those USB plugs I've used over the year had a glass fuse built inline anyways.
  8. Oct 31, 2019 at 6:35 AM
    phabej
    Washington
    2018 Platnium
    yea this one has a glass inline.
  9. Oct 31, 2019 at 7:50 AM
    Jrharvey02
    Kinda risky to want to be charging stuff while your truck is off. There isn’t much constant power inside the truck. My cig lighters stay powered on for 30 min after truck is shut off, but I think they did away with that in 2010...might as well run a power wire directly to your battery if you’re set on 24/7 power.
  10. Oct 31, 2019 at 2:05 PM
    phabej
    Washington
    2018 Platnium
    Yes, you're correct, a bit risky. I also realized that this unit LIGHTS UP cyan when it's got power! LOL Can't leave on with the car like that. So i'm going this route, https://www.tundras.com/threads/usb-always-on.6671/#post-99319. I'll just use connectors and re-use the OE plug. Easy and less risky.
  11. Oct 31, 2019 at 5:56 PM
    xj2202009
    xj2202009 New Member
    x
    Lutz, Fl
    2017 tundra sr double cab v8 5.7L black 4x2
    looking to replace factory Radio with a pioneer avix588bhs
    Two phones plugged in at the same time can pull 3 amps and overload a factory circuit, I would rather tap directly from the battery, use a 12 awg, wire,there's a rubber niple right by the brake boost for running wires into the cabin.
  12. Oct 31, 2019 at 6:25 PM
    Jrharvey02
    When a switch has a 3rd wire and lights up like yours, it’s usually meant to be wired for it to light up when your headlights come on at night time. This is very easily done by tapping into a neighboring switch, as it will have 3 wires going into it, a ground, a power and one wire that only gets power when your turn on your lights-that’s the one you use. Use a volt tester to figure out which wire has no voltage when lights are off and voltage when lights are on.
Thread Status:
