Michelin defender LTX ms2
Discussion in 'Wheels & Tires' started by Pudge, Aug 8, 2017.
  1. Feb 3, 2018 at 1:03 AM
    #91
    Kmiller002
    Kmiller002 New Member
    2016 Tundra Platinum Blazing Blue Pearl
    Just want to put my 2 cents on it for anyone thinking about buying...by far the best all around tire I’ve had. Been through multiple M/Ts and A/Ts on multiple tundras. I was a little hesitant to pull the trigger just because I wasn’t too sure on the look of them, not being an agressive looking tire, but through all the reviews I read and heard about I went with them and am sure glad I did. We’ve had a lot of rain and snow in WA the last couple months and they’ve performed way better than I even expected. The few trails I’ve been on they have performed excellent as well. So if you’re considering them...DO IT.
  2. Feb 3, 2018 at 3:15 AM
    #92
    Broncobroke
    Broncobroke Super White Power
    Charlie
    Piedmont, NC
    2017 White Tundra 1794
    I had 3 to 4 sets on my last Tundra. Typically got 70,000 miles out of them. Have 27,000 on the new Tundra picked up in late August. I can't wait to change.
  3. Feb 3, 2018 at 6:01 AM
    #93
    AxelsHumanDad
    AxelsHumanDad Get off my lawn.
    KAIG, NW of The Frozen Tundra
    2015 CM Platinum
    Some suspension tweaks
    I'm browsing right now... I want to keep the same tire but jump up in size with a leveled front end. Top row is whats on the truck now.
    SouthBoundSteve likes this.
  4. Feb 10, 2018 at 11:05 AM
    #94
    sk8142
    sk8142 New Member
    Shawn
    WA
    2014 Black Tundra TRD
    Bilstein 5100 F&R - Front middle setting w/2 CB shims Toytec rear shackles @ 1" setting Method NV 18x9 +25 Bronze 295/70/18 Nitto Ridge Grappler Retrofit headlights with Morimoto DS2 4.0, Apollo 3.0 shrouds, switchbacks Prodigy P3 brake controller
    FYI - Just placed an order through Costco for some 275/70/18 load range E Defenders. They have a sale going on right now that includes 70.00 off (no mail in rebate stuff) plus 1 cent installation per tire. :O
  5. Feb 12, 2018 at 11:23 AM
    #95
    Wynnded
    Wynnded What MPG...
    Rockies
    Souped up truck
    I went into my nearest CostCo yesterday and did the same thing. Only they said that the Defenders didn't have a high enough speed rating for my truck and had to go with the Michelin LTX M/S2, for warranty reasons. We looked them up and the tread pattern is the same. The "warranty" issue apparently came into play because the Defender has a speed rated T=118mph, and the M/S2 has a rating of H=130mph, and their info said that the H rating was needed for this vehicle (Aren't they speed limited to 112mph? I can't remember). Dunno, sounds fishy to me, but this morning I'm looking at the specs for the two tires and they're only subtly different.
    Defender
    LTX M/S2
    Am I missing something else obvious? I know that a higher speed rated tire is going to be more costly, but other than that....
  6. Feb 12, 2018 at 2:05 PM
    #96
    Patriot
    Patriot Member
    Western NC, “Boondocks”
  7. Feb 12, 2018 at 3:45 PM
    #97
    Darth Tundra
    Curt
    17 CM TRD Black
    Just bought a set from Costco for the Misses Explorer....on sale...mounted and balanced for $665.00
  8. Feb 12, 2018 at 3:51 PM
    #98
    ChucklesToy
    ChucklesToy Retired
    Chuck
    Georgetown , TX
    2024 Honda Ridgeline Black Edition
    Discount Tire never said anything about speed rating to me, but I do remember that the LTX M/S2 is the older version...had it on 2 previous trucks.
  9. Feb 18, 2018 at 8:03 AM
    #99
    Wynnded
    Wynnded What MPG...
    Rockies
    Souped up truck
    Got my tires mounted and balanced yesterday, then promptly put them back into storage for summer use. (I run studded snows in the winter.)
  10. Feb 18, 2018 at 10:05 AM
    #100
    Pudge
    Pudge [OP] Super Secret Elite Member #7
    CT
    2015 Blue Ribbon Platinum
    6 inches of snow today. No problem in 2WD. really loving these tires
  11. Feb 19, 2018 at 8:04 PM
    #101
    sk8142
    sk8142 New Member
    Shawn
    WA
    Well I made the change. I went from 295/70/18 Ridge Grapplers on Method NV305's that weighed ~100 lbs a piece to OEM SR5 wheels powdercoated black with TRD Pro center caps and 275/70/18 Michelin Defenders LRE tires that weight ~85 lbs each. This switch made sense as my truck is primarily used for towing my travel trailer. So far I love the switch. Acceleration and braking performance has been restored and the tires are practically silent on the road. My wife likes the lower ride height too. :)
    Old and new setup
  12. Feb 19, 2018 at 8:15 PM
    #102
    Rngr188
    Rngr188 Ranked the best new member of all time
    Chad
    Harrison AR
    2020 1794 MGM TRD OR
    I had the Michelin M/S (before the M/S2) on my 5.3L Envoy Denali and loved them. My Uncle had the same tires on his Tahoe for 10 years, he tried to get 100k miles out of them but one got a knot on the interstate around 98k. Here's a pic of front and rear passenger on his Tahoe at 93k.
  13. Feb 20, 2018 at 4:47 AM
    #103
    Patriot
    Patriot Member
    Wise move, Michelin nailed it with this truck tire, you will like the mileage wear as well. Personally I loath singing loud tires. :thumbsup:
  14. Mar 8, 2018 at 5:50 AM
    #104
    Pudge
    CT
    Was up to the skids in wet unplowed snow. Had to drop my daughter at my mom's before work. No problem
  15. Mar 8, 2018 at 6:30 AM
    #105
    Patriot
    Patriot Member
    Yep, been running Michelin’s for years...very happy with my Defenders 285/60/20 in 10 ply.
    AxelsHumanDad and Pudge[OP] like this.
  16. Mar 8, 2018 at 12:39 PM
    #106
    Broncobroke
    Charlie
    Piedmont, NC
    My next set of tires. Can't wait.
    Pudge[OP] and AxelsHumanDad like this.
  17. Mar 28, 2018 at 12:51 PM
    #107
    Pudge
    CT
    I was going to ask you if you got them yet. You'll be a happy camper!
  18. Mar 28, 2018 at 4:03 PM
    #108
    Pudge
    CT
    You'll be happy you pulled the trigger early, I sure am I did before the winter. Good luck with the move!
  19. Mar 28, 2018 at 4:53 PM
    #109
    Wynnded
    Wynnded What MPG...
    Rockies
    Souped up truck
    I put mine on last week, they sure are nice and quiet. They didn't get the front ones balanced proper though, so I moved them to the back until I can get back to Costco with them.
  20. Apr 1, 2018 at 10:30 AM
    #110
    Pudge
    CT
    @SouthBoundSteve did you get these in and mounted?
    I hope not. I'm so pissed. Tire pressure light was on, all looked good... I look on the inside of the tires and two of mine had delaminated and the belt is visible. I didn't hit anything. Looking closer at the others I see issues as well. These are the worst tires in the world.
    April fool's. They're still bad ass and I still love them.
    landphil, JMB and SouthBoundSteve like this.
  21. Apr 4, 2018 at 9:19 PM
    #111
    landphil
    Phil
    BC, Canada
    ‘08 TRD doublecab
    Damn - three days too late but you still got me. And I’ve never even owned a set. Yet.
    Maybe a bit strange since these and their predecessors have long been my top pick for an on-road light truck tire. Then again, on road and light truck never did fit much in the same sentence for me, until recently.
    Pudge[QUOTED][OP] likes this.
  22. Apr 14, 2018 at 6:16 PM
    #112
    Pudge
    CT
    I still love these tires. No issues, recently rotated at 5k miles.
    AxelsHumanDad and Wynnded like this.
  23. Apr 14, 2018 at 9:48 PM
    #113
    Wynnded
    Wynnded What MPG...
    Rockies
    Souped up truck
    Digging mine as well. Finally got them all balanced, local boys at Costco needed some practice it seems.
  24. Aug 15, 2018 at 7:25 PM
    #114
    Pudge
    CT
    I'm still loving these tires. Haven't noticed at changes in performance or noise as I put more miles on. Don't notice any noticeable wear.
    I need to have found a sweet spot between 30 and 32 psi.
    My buddy just got some based on my experience and is loving them. Winter is coming and I have no worries at all. Other than dedicated snow tires they're the best I've had in the winter months.
    How you liking yours @SouthBoundSteve
  25. Sep 4, 2018 at 9:27 AM
    #115
    TundraLaw
    TundraLaw New Member
    Northern Nevada
    24 GMC Sierra At4x AEV
    That looks great, and exactly what I'm about to do. Was on Method Roosts on Cooper St maxx 275/70/18. Going to put the stock TRD OR wheels back on with either Defenders or the new Cooper Discoverer XLT.
    Any suggestions, or thoughts about the defenders? I have an Icon Stage 2 on right now (2.5 up front and 1.5 in the rear)
  26. Sep 4, 2018 at 12:11 PM
    #116
    Tacogrande
    Tacogrande New Member
    Jeremy
    2016 SR5 dbl. cab long bed gray
    Husky weatherbeaters,short antenna,window deflectors
    I have the ltx ms2 but they don't say defender. Different tire?
    Pudge[OP] likes this.
  27. Sep 4, 2018 at 12:51 PM
    #117
    Pudge
    CT
    I'll have to go see if mine say defender
    The defenders replaced a tire called the LTX MS2. So you may have those?
  28. Sep 4, 2018 at 1:00 PM
    #118
    TitoBaggins
    TitoBaggins New Member
    2016 TRD Pro
    I had the Cooper AT3 LTX installed recently. They are holding up well in the rain. Haven't had a chance for snow yet, but we'll see in a few more months.
  29. Sep 4, 2018 at 1:02 PM
    #119
    TundraLaw
    Northern Nevada
    oh very nice. Could you post a pic with those on?
  30. Sep 4, 2018 at 2:03 PM
    #120
    Wynnded
    Wynnded What MPG...
    Rockies
    Souped up truck
    When I bought mine at CostCo, the fella asked if I Tow/Haul. When I answered in the affirmative, he said that I should be running what's now on my truck, they say LTX M/S². So that's what I had mounted up. Price, warranty and all the fine print was the same....so. Maybe there's a slightly different load rating? :confused:
