Michelin defender LTX ms2
Discussion in 'Wheels & Tires' started by Pudge, Aug 8, 2017.
  1. Oct 18, 2017 at 3:45 PM
    Pudge
    Pudge [OP] Super Secret Elite Member #7
    CT
    2015 Blue Ribbon Platinum
  2. Oct 19, 2017 at 8:10 PM
    Pudge
    CT
    Look what the ups man dropped while I was at work...these are a true 33, current stock tires look tiny. Will probably get them installed next week. No huge rush, I just had to jump a deal.
    I've been saving money for these, and waiting for a deal like this since I got the truck a year ago. I hate to replace tires that still have plenty of miles left on them, but these are just going to be so much safer and better. I don't log a lot if miles in my truck so I expect this to be 6-8 year investment.
  3. Oct 20, 2017 at 3:54 PM
    Pudge
    CT
    I had some free time this evening so I went and had the tires mounted. No pics cuz it got dark, I'll post some tomorrow. First impression from my 10 minute drive home is that these ride much better than the OEM tires, even at the 40 psi they put in them. They are softer and the truck grips better. Inclement weather conditions to be determined.
  4. Oct 20, 2017 at 4:17 PM
    AxelsHumanDad
    AxelsHumanDad Get off my lawn.
    KAIG, NW of The Frozen Tundra
    2015 CM Platinum
    Some suspension tweaks
    My guess is they won't disappoint :thumbsup:
  5. Oct 20, 2017 at 9:46 PM
    JMB
    Chesapeake, VA
    2013 Super White Tundra DC
    I don't know if the size that you got is the LT series, but mine are. Get the inflation around 35 to 40 and the ride and wear is great. Mine are load range E, so for towing or an unusual load I go up to 60. E rated tires are designed for 80 psi at max payload, but for normal driving go to the inflation that works, see the chalk test thread. Best tires ever, now you can stop saving money for tires and spend it on more mods, or hookers and blow, or home improvement...whatever, but you won't need new tires for many years.
  6. Oct 21, 2017 at 9:16 AM
    Pudge
    CT
    These fill out the wheelwells much better. What a difference an inch makes. I'm at 38 PSI front and back, chalk test shows I may need a couple more PSI up front.
  7. Oct 21, 2017 at 10:06 AM
    AxelsHumanDad
    2015 CM Platinum
    Nice! now put some wheel spacers on there :thumbsup:
    I've got the 275 55's with spacers on mine.
    Pudge[QUOTED][OP] likes this.
  8. Oct 21, 2017 at 8:24 PM
    Pudge
    CT
    Logged a few more miles today. Very quiet on the highway. Really smooth ride and I'm still at 40 PSI. I went to a farm today and had to drive up a hill, just dry grass, which is very slippery. I had no issues and ironically my buddy was in front of me in his tundra and he said his stock tires slipped. He has a 16 limited, he ordered these tires by the time we were off the hayride with the kids.
    ColoradoTJ, AxelsHumanDad and JMB like this.
  9. Oct 22, 2017 at 2:23 AM
    CMB
    CMB New Member
    Cecil County MD.
    2010 Tundra DC 4X4 SR5
    Not nearly enough room here!
    We've used Michelin's LTX AT2's for several years. Prolly try Defenders next.
    ColoradoTJ likes this.
  10. Oct 22, 2017 at 4:19 PM
    mgh-pa
    mgh-pa Perpetually a New Member.
    2016 Tundra DC SR5
    Let us know how your mpg is after the switch. Thanks!
    brabus likes this.
  11. Oct 22, 2017 at 4:50 PM
    Pudge
    CT
    I reset my mpg on the computer so we'll see. There are a few factors here though.
    1. I went up from a 32" to 33" tire, I think that makes the odo off by about 3%
    2. I'm in New England and it's going to be getting cold here. MPG go down when it's cold, also the gas mix will be changing over to a winter blend soon, which also causes worse MPG, as well as letting the car warm up longer.
    I will compare to last winter when I averaged 13mpg, this summer I got 14.5. I'll be sure to keep this post updated with those numbers.
  12. Oct 24, 2017 at 10:33 AM
    Pudge
    CT
    Drove 20 minutes on highway today. They are as quiet or quieter than the OEM tires.
    Hit some rain on the way home bit not enough to really soak the roads.
    AxelsHumanDad likes this.
  13. Oct 24, 2017 at 10:45 AM
    Patriot
    Patriot Member
    Western NC, “Boondocks”
    Best all around tire I have ever owned. Yesterday coming back from the mountains in a deluge of hard rain my truck handled like it was on a rail. You won't be disappointed.
    Pudge[OP] and AxelsHumanDad like this.
  14. Oct 24, 2017 at 12:14 PM
    DocC22
    DocC22 New Member
    2017 1794 TRD
    Good to hear about the Defenders. The LTX AT2s have been a huge disappointment for me. 6 flats in less than a year and they look like someone went at them with a knife. I drive 85% highway, but do drive gravel roads the other 15%. I thought them being E rated would make them be more resistant to gravel etc. My guess is the Defenders wouldn't be a good fit for my situation. I've always been a Michelin fan, but the AT2s have me second guessing that.
  15. Oct 24, 2017 at 12:24 PM
    AxelsHumanDad
    2015 CM Platinum
    I had the AT2s on one of my short-term trucks, I thought they sucked. Huge disappointment compared to the MS2/Defenders.
    Patriot likes this.
  16. Oct 24, 2017 at 6:53 PM
    brabus
    brabus New Member
    How is your mileage with them? I have 285/55r20 now in bfg ko2 and the limeade is abismal. Those would rub without a level won't they? Looks good!
  17. Oct 25, 2017 at 3:26 PM
    Pudge
    CT
    Had heavy rain today. Lots of large puddles. No slipping or hydroplaning (I was only going about 40 mph though). I even turned off all the nannies and tried to break it loose and had very minimal success doing so.
    kstateskier, AxelsHumanDad and brabus like this.
  18. Oct 25, 2017 at 3:54 PM
    AxelsHumanDad
    2015 CM Platinum
    Nice! Are you still running 40psi? How do you like the ride?
    I'm at 35 front and 34 rear, but I've got firmer suspension than most and I tried to tame the ride a little bit.
  19. Oct 25, 2017 at 4:02 PM
    #49
    Pudge
    CT
    I'm down to 38 front and rear. I think I'll go down to 36 in the back tomorrow and see how they feel and do another chalk test once the rain stops.
  20. Oct 25, 2017 at 7:09 PM
    #50
    skid
    skid New Member
    What is the wheel offset?
    I believe these are 20x9 Mint's. Are they the +12 offset?
  21. Oct 25, 2017 at 11:29 PM
    #51
    Patriot
    Patriot Member
    That is correct, +12 offset (not a fan of wheel spacers at all) and the flares help keep the road "fling" on the side of truck paint to a minimum.
  22. Oct 26, 2017 at 5:13 PM
    #52
    skid
    skid New Member
    Thanks. I was worried a +12 would be too much. But after seeing your pics I am sold. BTW. I am in Pilot Mountain, NC.
  23. Oct 26, 2017 at 11:28 PM
    #53
    Patriot
    Patriot Member
    Welcome neighbor! PM me if I can help you with any other questions.
  24. Oct 27, 2017 at 3:16 AM
    #54
    Stumpjumper
    Stumpjumper Not a new member
    Fate, Tx
    2017 Tundra TSS 4x4
    Yep, tight tread. In sand you don't want a tire that digs. Long ago I ran Buckshot MTs. In sand they called them "gravediggers"
    JMB[QUOTED] likes this.
  25. Oct 27, 2017 at 8:03 PM
    #55
    Pudge
    CT
    I sold my old tires on Craigslist today. Shop wanted me to pay them $8 to dispose of them. Figured I'd give it a shot at selling them since they had decent tread left. The guy who bought them was really nice and was so happy to get tires with decent tread for cheap, his were bald. I was asking 200, he offered 150 when he saw them, I told him you load them into the bed of your TUNDRA and you can have them for 100. He had a rock warrior with 20" wheels cuz someone stole his wheels.
    1015K9, htw_hawaii, Patriot and 3 others like this.
  26. Oct 27, 2017 at 8:12 PM
    #56
    I have the AT2 tires on my truck, and they are loud, pick up bigger rocks and fling them where you don’t want them to go, and do not ride as well. Not sure if you experience the same.
    The defenders are my next stop. I’m not as concerned with wear, if I can get 40k out of a set I will be clicking my heals.
    SouthBoundSteve likes this.
  27. Oct 27, 2017 at 8:17 PM
    #57
    Pudge
    CT
    I'm sure that diesel eats tires, plus all the towing.
    In my research on the defenders I was shocked at all the negative reviews of the AT's. Now I know why all these guys with PROs ditch theirs.
  28. Oct 27, 2017 at 8:18 PM
    #58
    Kindness payed forward is always repaid 10 fold. That was pretty awesome of you to do that.
    When selling stuff in my city, if it is a military, police, firefighter personnel, they get a hefty discount.
  29. Oct 27, 2017 at 8:23 PM
    #59
    Yes, they tear tires up quick. Now with some diesels at 925 lbs ft of torque....
    What really reads them up is DD them with no load. The tires spin a lot. I can spin my tires with 1000 lbs of tongue weight if I get on the throttle.
    The AT2 work well in snow and all around Offroad performance. I can see I will have to get my good ol’ siping tool out for this winter on these tires already.
  30. Oct 27, 2017 at 8:27 PM
    #60
    Pudge
    CT
    The guy was so nice and thankful even at $150. Begged me 3 days ago to hold them til today for him. Said he'd call me at 830, he called at 830, I live about half way through his almost 2 hour commute to work. I just couldn't take full price from the guy. I'm lucky enough to be able to afford to upgrade tires before old tires were shot. I believe in paying it forward too.
