MEVOTECH UCA'S Same as SPC
Discussion in 'Suspension' started by kxed, Jan 18, 2020.
  1. Aug 28, 2020 at 12:36 PM
    #91
    Vr0ck
    Vr0ck New Member
    Virginia Beach, VA
    2016 5.7 MGM DC 4x4
    Toytec Boss C/O, Toytec Shackles, 5160s, nfab step bars, 8" BAMuffler, OVTune, AuxBeam LEDs, Vahalla protection plates
    Jumped on the band wagon as well and thought my chances were good seeing the product pics on the site showing greasable ball joints for both sides....ended up getting one of each.
    @The Patriot 1776 let us know if they address the part exchange for you.
  2. Sep 5, 2020 at 7:15 PM
    #92
    The Patriot 1776
    The Patriot 1776 Asskick Fabrication: Shit Is Sick!
    Great State Of TEXAS
    '16 TSS CM 4x4
    They sent another UCA and it too had a no grease zerk. This one came in the normal box inside of a bigger box. The bigger box had no damage but the normal box inside was hammered to shit. I’m sending it back and keeping the set they originally sent. They said they have no control over which one you receive and that they’re equal, for all intents and purposes.
    Vr0ck likes this.
  3. Sep 5, 2020 at 9:05 PM
    #93
    SnowB0und
    SnowB0und New Member
    2013 SR5
    I’m going to order a set if anyone wants swap arms that way we can get the same ones. I just don’t want one of each on my truck.
    The Patriot 1776 likes this.
  4. Sep 6, 2020 at 5:10 AM
    #94
    The Patriot 1776
    '16 TSS CM 4x4
    If you get one (part # ending in 3) with a grease zerk, I’ll swap ya.
  5. Sep 12, 2020 at 7:14 AM
    #95
    CaptainGrumpus
    CaptainGrumpus The Mailman
    Maine
    2018 Inferno Tundra TRD
    Would it be worth it to spend the extra $120 on the JBA set?
  6. Sep 15, 2020 at 7:22 AM
    #96
    Mctodd
    Mctodd New Member
    Todd
    Nor Cal
    2003 SR5 4wd TRD
    F. Fabtech Dirt Logic 2.5, Icon 1.5 Add a Leaf pack, BFG KO2s 285/75/17, 1.25 Spydertrax, SPC UCAs.
    Anybody picked these up recently?
    Looks like the cost may have dropped a little. I'm looking to replace by UCAs and was headed for some SPCs or JBAs until i stumbled on this. I'd be hoping for the greasable BJs but it sounds like kind of a crap shoot.
    Can anybody weigh in on the SPC vs JBAs (not a huge fan of the color but they seem pretty solid and affordable
  7. Sep 15, 2020 at 6:25 PM
    #97
    The Patriot 1776
    '16 TSS CM 4x4
    I’ve installed both and prefer the adjustable of the SPC over the JBA.
    Mctodd likes this.
  8. Sep 16, 2020 at 7:16 AM
    #98
    Mctodd
    Mctodd New Member
    Todd
    Nor Cal
    2003 SR5 4wd TRD
    thanks @thepatriot1776, I think i've decided to go the SPC route for the same reason. I was hoping to jump on these Mevotechs but I can't find them anywhere, everyone seems to be sold out of the ones to fit first gen Tundras.
    Anybody speculate if/when a place like Rock Auto might restock...or was it more likely a one time sell off thing?
  9. Sep 23, 2020 at 4:22 PM
    #99
    arbucklejon1
    arbucklejon1 New Member
    2006 RC LB V8 4x4
    They're back today for first gen. Just checked
  10. Sep 23, 2020 at 4:25 PM
    #100
    arbucklejon1
    2006 RC LB V8 4x4
    Make that only 1 available. Tried adding 2 to the cart, didn't work
    Mctodd likes this.
  11. Sep 23, 2020 at 10:34 PM
    #101
    Mctodd
    Mctodd New Member
    Todd
    Nor Cal
    2003 SR5 4wd TRD
    Thanks for the heads up...i got pretty excited and went to look it up and saw there was only one, F!
    arbucklejon1 likes this.
  12. Sep 28, 2020 at 11:32 AM
    #102
    The Patriot 1776
    '16 TSS CM 4x4
    I installed these the same way I installed 2 sets on Tacoma’s but I’m now thinking it may be different on the Tundra. The Tacos have a completely different type bushing that’s almost like a heim joint encased in rubber. For those that installed the SPC/Mevotech UCA did you use the big factory washers against the nut and bolt head then the 2 supplied washers between the frame and bushing of the UCA? In this order:
    Bolt
    Factory washer
    Bushing
    Washer
    Frame
    Washer
    Bushing
    Factory washer
    Nut
    That’s what I did but I read that on the Tundras you don’t reuse the big concave factory washers and DONT need one between the bushing and frame. You just use the new washers on the outside of the bushings, in this order:
    Bolt
    Washer
    Bushing
    Frame
    Bushing
    Washer
    Nut
    Can anyone confirm which is correct for the Tundra?
    Thanks!
  13. Sep 28, 2020 at 12:42 PM
    #103
    Squatting Pigeon
    Holden
    North Texas
    4Runner | GR Corolla
    I don’t have firsthand experience with the mevo/Spc but I helped @Larmand with his Total Chaos ones and they had 4 washers total each side. One for each side of the bushing on both holes.
    Interesting it’s not the same way for these.
  14. Sep 28, 2020 at 4:37 PM
    #104
    The Patriot 1776
    '16 TSS CM 4x4
    All the UCA’s are installed different. Thanks anyways.
  15. Sep 28, 2020 at 5:54 PM
    #105
    Squatting Pigeon
    Holden
    North Texas
    The bushings are all of a similar if not identical design though.
    You're welcome.
    Black Wolf and T-Rex266 like this.
  16. Sep 29, 2020 at 7:13 AM
    #106
    The Patriot 1776
    '16 TSS CM 4x4
    I removed them & redid the washers like the other set of directions say. Took me <1 hour to do both this time, by myself. I originally researched this because I can't figure out a wicked popping in my front end that I thought was maybe the UCA's. It's actually the front shocks going to full extension & banging when topping out. Thanks.
  17. Sep 29, 2020 at 11:13 AM
    #107
    The Patriot 1776
    '16 TSS CM 4x4
    Just SPC's from a Tacoma to a Tundra are completely different bushings. They don't resemble each other at all.
    Tacoma
    Tundra
  18. Sep 29, 2020 at 4:11 PM
    #108
    Squatting Pigeon
    Holden
    North Texas
    Wait are you asking about Tacomas?
  19. Sep 29, 2020 at 4:14 PM
    #109
    You asked a question, someone replied and u replied with a knee jerk reaction. Good luck.
    Squatting Pigeon and Black Wolf like this.
  20. Sep 29, 2020 at 4:25 PM
    #110
    Two totally different trucks.....
    Squatting Pigeon likes this.
  21. Sep 29, 2020 at 4:28 PM
    #111
    :monocle:
  22. Sep 29, 2020 at 4:37 PM
    #112
    Hartsy8
    Hartsy8 Resident Hockey Guy
    Max
    2020 MGM 1794
    soooo... are the cheaper UCAs nice?! :p
  23. Sep 29, 2020 at 5:50 PM
    #113
    The Patriot 1776
    '16 TSS CM 4x4
    Ha! Wrong. He answered with “their almost all identical” and all I did was point out that they are, in fact, not “almost all identical”.
    How sweet of you to sweep in and stick up for him, though. Good job!
  24. Sep 29, 2020 at 5:54 PM
    #114
    Please read your quote and then see his response below. I can see you’ve been here just over a month, and you won’t last long.
    On a side note, I deleted your avatar with the political flag in the back.
  25. Sep 29, 2020 at 6:00 PM
    #115
    Squatting Pigeon
    Holden
    North Texas
  26. Sep 29, 2020 at 6:44 PM
    #116
  27. Sep 29, 2020 at 7:01 PM
    #117
    Outbound
    Aaron
    Northern Alberta
  28. Sep 29, 2020 at 7:15 PM
    #118
    Grumpy Uncle
    Pat
    CO
  29. Sep 30, 2020 at 12:11 AM
    #119
    MTRock likes this.
  30. Nov 14, 2020 at 5:24 PM
    #120
    Burdturger
    Burdturger New Member
    Was holding out to see what black Friday deals come up for UCAs but I think these from rock auto are hard to beat. Although the Ironman 4x4 set looks really nice but not sure if it's worth 150 more. You guys still happy with these?
    Vr0ck likes this.
