Messed up my transmission: A warning to everybody!
Discussion in '1st Gen Tundras (2000-2006)' started by Norcalyotaman, Dec 26, 2022.
  1. Jul 30, 2023 at 3:40 PM
    Norcalyotaman
    Norcalyotaman [OP] New Member
    2005 Tundra Double Cab SR5
    Here’s the direction of flow. Hot fluid exits the transmission and goes into the radiator. It then exits the radiator and goes to the cooler up front. Then goes from the cooler back to the transmission. I did exactly what you are talking about. I popped a line off coming from the cooler and put it into a gallon jug that I had marked for 2 quarts. I would have someone fire up the truck and fill the jug to 2 quarts. Then shut off the truck and add 2 quarts. Repeat until it looks clean. Then I added an extra half quart and did the full level check procedure. Drained out most of that extra half quart.
    noahrexion, JasonC. and AresEsMaLo like this.
  2. Jul 30, 2023 at 4:32 PM
    AresEsMaLo
    AresEsMaLo New Member
    Michael
    CA
    06 Grey Tundra Access Cab TRD 4x4
    Thank you everyone. I know I was probably not as clear as I could have been. My goal is to do a complete atf replacement. I think this last post explains it. Thank you @Norcalyotaman
    2mchfun likes this.
  3. Jul 30, 2023 at 4:42 PM
    Norcalyotaman
  4. Jul 30, 2023 at 4:46 PM
    AresEsMaLo
    Michael
    CA
    @shifty` thats good to know I’ll be watching the fluid to make sure the fluids don’t mix
  5. Jul 30, 2023 at 5:14 PM
    It's more a warning about the condition of the radiator. Those two "nipples" at the base of the radiator ... if the seal for those nipples goes bad you start to mix coolant with your transmission fluid.
    For your sealed transmission, you'll want to use WS fluid. Don't grab your favorite ATF off the shelf.
    2mchfun likes this.
  6. Jul 31, 2023 at 2:47 AM
    w666
    w666 D. None of the above
    Maryland
    04 Access Cab SR5 V8 4WD
    This ^^^^
    I hope you used Toyota WS fluid. If not, you've had great practice so you can do it again
    shifty` and 2mchfun like this.
  7. Jul 31, 2023 at 8:46 AM
    AresEsMaLo
    Michael
    CA
    Good to know. I will watch out for this.
    I did go with the Toyota WS. This forum and a bunch of other sources have me convinced to go with OEM parts on my truck.
    shifty`[QUOTED] likes this.
  8. Jul 31, 2023 at 9:05 AM
    There are some OEM parts exceptions, so I don't want you to think we're, like, "ALL OEM ALWAYS!" because we're not all that hardcore. Hell, there's this thread that'll give you non-OEM parts options people had luck with.
    Really, transmission is probably one of the only fluids where I'd tell you to go WS, with the sealed transmissions. I'm not sure on the earlier model (2000-2004) trucks that don't have a sealed trans.
  9. Jul 31, 2023 at 11:09 AM
    bmf4069
    Beau
    TX
    02 AC sr5 4wd v8
    Dex III for the 4 spd trucks.
  10. Jul 31, 2023 at 11:15 AM
    w666
    Maryland
    2004 calls for T-IV
  11. Jul 31, 2023 at 11:16 AM
    I think DexIV is backwards compatible (all Dex are supposed to be), or was there a thread to hash back through all that?
  12. Jul 31, 2023 at 11:26 AM
    bmf4069
    Beau
    TX
    02 AC sr5 4wd v8
    04s don't count. That's the weird year that nobody understands.
    FirstGenVol likes this.
  13. Jul 31, 2023 at 11:27 AM
    bmf4069
    Beau
    TX
    02 AC sr5 4wd v8
    PHM and marbles argued back and forth a few years ago about it. I don't remember where it was though.
    TX-TRD1stGEN and FirstGenVol like this.
  14. Aug 3, 2023 at 9:36 AM
    AresEsMaLo
    Michael
    CA
    Thank you @Norcalyotaman. This info was spot on! Completed a total ATF fluid and and filter change last night. Old stuff seems to have been at least a half quart low and maybe as much as 3/4 quart and it was pretty dark. It did not stink much so I think it did not burn up completely.
    One thing I found in this process is that the pan had no magnets. I think I saw them on the Toyota parts page. Is this essential that I have them? I have some neodymium magnets but I was hesitant to put something inside the transmission if it was not OEM.
    Does anyone have any thoughts on the how essential these are?
    FrenchToasty likes this.
  15. Aug 6, 2023 at 12:10 PM
    Norcalyotaman
    Glad it worked out! I’m trying to remember but I think mine had magnets. But it was a while ago so I’m not totally sure.
  16. Aug 23, 2023 at 10:28 AM
    wandering_boy
    wandering_boy Junior Tech Wizard
    California
    2005 AC SR5 TRD
    Don't let a kid out smart you.
    Well shit. I'm at just about 170k and my trans started doing this. I was maybe just going to replace the valve body and flush everything with some OE fluid. Do you all think its worth pulling the whole thing apart and having someone look at it? I've never had any trans codes and up until this started it generally always behaved. I reset the adaptation and it has helped a lot but it still happens from time to time. Probably helps that I take the same amount of space to stop as a semi.
  17. Aug 23, 2023 at 5:49 PM
    Norcalyotaman
    When I talked to a reputable local trans shop he basically said not worth tearing apart. Said that when you tear it apart you pretty much have to put all new stuff in. Can’t really “inspect it” and that would cost almost as much as a new unit. Plus he has seen mixed results with aftermarket parts. I was tempted to do something like the “zip kit” that replaces some worn parts on the valve body and is suppose to up the line pressure. Might be worth a try and isn’t that expensive. I ended up finding a low mileage one on Craigslist for a couple hundred and knock on wood it’s working perfectly.
    TheBrit likes this.
  18. Sep 7, 2023 at 4:08 PM
    AresEsMaLo
    Michael
    CA
    Not sure if you did anything yet but mine is a month in a running great. You may want to top off the ATF just to see if it is low. If it runs ok, do a fluid swap asap.
  19. Sep 7, 2023 at 5:08 PM
    #49
    TheBrit
    TheBrit Wrinkly member
    Mark
    2013 Double Cab Tundra 2WD stuckinthemud
    Yeah, I'm also kinda thinking that a rebuild isn't the greatest of ideas, my (later model) Tundra is back at the shop for a third time now.
    Diagnosis, worn valve body, just under 250k on the clock, hardly unreasonable mileage for it.
    First time he drilled out the valve body and replaced valves as well as doing all the important bits in the guts of the transmission. Didn't run too good after a short while so went back and (despite a solenoid D code) was told it was low on fluid caused by a duff gasket causing a leak at the pan's mating surface. Got it back, ran reasonably well despite that permanent solenoid D code but then it started some rough shifting and chucked a solenoid C code as well.
    Called the shop and he seems to think that the valve body is still losing pressure - thank the Lord for 12 month warranties! Original cost to me $3k, shop thinks he's got a valve body from a younger truck that he's going to put in there, I don't think he's going to make any money on this one!
    More of a pain in the butt is having the truck out of commission for so long this year, the Frontier the shop sold me was cheap and cheerful but it's a bit small for me as a work truck.
