Media Center
Discussion in 'Home Improvement' started by BB Stacker, Sep 2, 2017.
  1. Sep 2, 2017 at 8:13 PM
    BB Stacker
    BB Stacker [OP] New Member
    So. Cal
    2016 White 1794 TRD 4X4
    Sway Bar, TRD Catback Exhaust, Morimoto LED fog lamps, running boards, paracord wrapped oh-shit handles, Bak-Flip bed cover.
    I have this media cabinet that has been driving me crazy since I have lived in this house. It has been way too hot outside to do any thing useful out there so i decided to tackle this project. Every time I had to change something on the network it was a PIA. So I went to Fry's and picked up a two CAT 6e patch panels and RJ-45 connectors, and RJ-45 boots to keep everything nice and neat.
    Before:
    During:
    After:
    My OCD is so much better now.....
    T-Rex266 and 4x4_Angel like this.
  2. Sep 2, 2017 at 9:10 PM
    Areith762
    Areith762 Go Avs!!!
    39.944182, -104.760113
    2017 Blazing Blue 5.7L CM SR5 4X4
    DAP Tune, Katskin interior leather, ESP rear under seat storage, door sill protector, door edge protector, TRD Pro shift knob, heated seats, all weather Tundra floor mats, driver side a-frame handle, Tundra trucks center console emblem, clear bra protection, Bushwacker fender flares, paint match front bumper caps, paint match rear bumper caps, paint match mirror caps, ProComp 3/1 lift, 20" Fuel wheels, 33-11.50/R20 Falcon tires, black TRD Pro badge's, black Tundra tailgate badge insert, TRD Pro headlights, Recon smoked tail lights, Recon smoked 3rd brake light, Roll N Lock tonneau cover, Line-X bed liner, Tundra bed mat, Cobra led remote alarm/remote start, N-fab tube steps, factory match window tint, TRD Pro grille -paint matched, paint matched hood bulge, TRD dual exhaust, Black out exhaust tips, led interior lights, led plate lights, Spyder smoked fog lights, TRD Cold Air Intake
    Almost time to upgrade that 6141 modem. Already outdated. And hopefully, that drop amplifier isn't just feeding your modem. That will raise your transmit levels and distort the signal. If there is no other coax lines hooked up to your modems service provider, there should be more than enough signal to power that modem. Otherwise, something is really wrong with your cable feed. Besides that, good job. Very clean.
  3. Sep 2, 2017 at 9:13 PM
    jlee
    jlee New Member Vendor
    jerry
    Bay area CA
    2016 TRD Off Road on 35's supercharged and Kings and A 2002 SAS'ed supercharged Tacoma on 37's Linked front and rear
    Oh one or two.
    Looks better then mine lol
    T-Rex266 likes this.
  4. Sep 2, 2017 at 9:27 PM
    Areith762
    Areith762 Go Avs!!!
    I didn't have a whole lot of time to clean it up, but I left it better than I found it.
    PermaFrostTRD likes this.
  5. Sep 2, 2017 at 9:35 PM
    BB Stacker
    So. Cal
    What would be a good replacement for the 6141?
    When I first moved into this house 13 years ago I was having connectivity issues. The Cable guy came by and provided me with the amplifier. I get 53 MB down load speeds so I am content. Would you suggest taking the amplifier out of the data stream and see if I get get a good data transfer rate?
  6. Sep 2, 2017 at 9:53 PM
    Areith762
    Areith762 Go Avs!!!
    Well, that modem only has 4 downstream channels, so realistically it's max download speed would only be about 100 Mbps. If you are paying for more than that, you will not get it with that modem. I would look for a modem with 24 or 32 downstream channels and 4 upstream if you want one that will last awhile and capable of higher download speeds and bandwidth.
    As far as the amp goes, that could have been a bandaid fix to a larger problem. Not only would that amp boost cable signal, but it would boost noise too if that is present. I couldn't tell you to take it out unless I knew your signal levels. If you are a Comcast subscriber, I can tell you your levels. Otherwise, you would have to log into your modem and look at the connection specs. You can do that on a hardwired pc by opening your internet browser and typing 192.168.100.1 in the address bar. You may need to login depending on the make. If it is Motorola, i think the admin is admin, and the password is Motorola. Once in there, you will be looking for the downstream receive power, downstream snr, and upstream power. Downstream power ideally should be between -8 Dbmv and +8 Dbmv, SNR above 35 Dbmv, and upstream below 54 Dbmv on all channels. I don't like the upstream getting into the 50's at all. Around 40 is ideal.
    PMG likes this.
  7. Sep 2, 2017 at 10:00 PM
    Areith762
    Areith762 Go Avs!!!
    Also, that amp is boosting your downstream signal up by 15 Dbmv... so for example, if you are seeing your downstream receive levels at +12 Dbmv (way too high, and distorted at the modem), taking that amp out will drop your levels to -3 Dbmv, right where it should be, in the "sweet spot" between -8 and +8.
  8. Sep 3, 2017 at 4:31 AM
    MT Madman
    MT Madman Just an ordinary guy
    Hawk Point MO
    2020 Silver Platinum
    TRD dual exhaust TRD Rear Sway Bar SnugTop Hi-Liner
    Ahhh, rural living and living with DSL at 1.5 download.
    AxelsHumanDad likes this.
  9. Sep 3, 2017 at 5:13 AM
    Areith762
    Areith762 Go Avs!!!
  10. Sep 3, 2017 at 11:07 AM
    BB Stacker
    So. Cal
    I disconnected the amplifier and here are the results. Leave it out?
    I do appreciate your help.
  11. Sep 3, 2017 at 12:16 PM
    Areith762
    Areith762 Go Avs!!!
    Yes, I would leave it out. You are right in the middle of where you should be signal wise. The amp would distort your signal, which your modem will not like. Your modem may drop those distorted frequencies and look for non distorted frequencies. If they are all distorted, it would be a non stop process. Your signal quality and upstream transmits looks good too. Also, your modem is locked onto 8 downstream channels, so realistically it can do up to 200 Mbps download speeds. I wouldn't worry too much about swapping your modem out yet unless your cable provider advises you to or you upgrade your speeds. However, that modem is on Comcasts end of life list in the system I work in...
    Bob likes this.
  12. Sep 3, 2017 at 1:02 PM
    BB Stacker
    So. Cal
    Areith,
    Thanks for your help. I am now getting 57.36 Mbps download speed, 5.74 Mbps, with a 13 ms Ping. This is a nice improvement!
  13. Sep 4, 2017 at 4:23 AM
    MT Madman
    Hawk Point MO
    Back atcha
  14. Sep 4, 2017 at 6:30 AM
    Tundra_mike89
    Tundra_mike89 New Member
    Michael
    South Texas
    2016 TUNDRA CM 4x4
    Toytec boss coilovers Toytec shackles Total chaos uca's Method wheels Nitto ridge grapplers
    Is my wifi fast? Idk anything about this
  15. Sep 4, 2017 at 6:41 AM
    smslavin
    smslavin New Member
    Hudson Valley
    2016 Tundra CrewMax SR5
    Some stuff
    oh man i could totally use your help. comcast drags in our neighborhood.
    dude! how in the hell? who do i need to call and what do i need to ask for?
    when i've got the vpn on, it slows a little but not noticeably.
  16. Sep 4, 2017 at 7:33 PM
    Areith762
    Areith762 Go Avs!!!
    If you are on a 2.4 GHz network, then not bad. You can't expect much more than that on 2.4. If on a 5 GHz network, then that depends on what speeds you are paying for.
  17. Sep 4, 2017 at 7:39 PM
    Areith762
    Areith762 Go Avs!!!
    If that is all you are getting for internet speeds, I wouldn't expect a VPN connection to slow that down much. You would still be limited to your VPN's server speeds. How are you connected to the internet (WiFi, hardwire) and what internet speed package do you subscribe to?
  18. Sep 4, 2017 at 7:43 PM
    birdman076
    birdman076 Bird, bird, bird...bird is the word
    Chuck
    Montana
    2015 Brown Tundra Crew Max Limited
    Airbox with K&N Filter, 2" lift on 33's, Alpine iLX-F309 head unit, Pull out bed tool boxes, brown with black trim, rims, etc, black leather interior, matching topper. Muffler delete (too loud..) 62k miles!!!
    Smexy
    Areith762 likes this.
  19. Sep 4, 2017 at 7:51 PM
    Areith762
    Areith762 Go Avs!!!
    Nice upload. I am still doing ok on my download while being on a different floor of the house and only 2 of 4 WiFi signal bars.
    birdman076 likes this.
  20. Sep 5, 2017 at 8:03 AM
    smslavin
    smslavin New Member
    Hudson Valley
    Some stuff
    All I can do in my house is WiFi. It's an old house (1940s) with lots of brick, plaster and small rooms. There's only one cable drop. In the basement. So, the router and the cable modem are down there. I need to see if I can get Comcast to swap out my modem for a new one. The one I'm currently using is almost 5 years old.
    Router is a Linksys WRT1200AC flashed for NordVPN. I have two TPLink RE450s running as well. One on the main floor and one upstairs. I'm considering adding another one or maybe some Powerline kits. Connection speed in the basement is double what you get anywhere else in the house.
    Not sure what plan we're on but I haven't changed it since moving into this house 4 years ago.
  21. Sep 5, 2017 at 10:07 AM
    Mike Tread lightly.
    south carolina
    18 u Rack is installed.(excuse the mess inside) . all internet equipment is on hand ready for me. Just making up my mind on who I'm going to use for home dvr 16 cameras. e9a2b3d0fe8eef58a2e8674952371786_4ae6b34681b68bd516daf636f1ca1ef789ead668.jpg883119bf70cae9f0d2b65ad5b1ac4d35_8af1cff6cfabe7e1d4876015d47462a3097491b6.jpg644e0c47f8aa97c32e7c3c5f082a342f_82d5d5ab115daa3c8efbd8080e299000f9d5447e.jpg
  22. Sep 5, 2017 at 11:45 AM
    Areith762
    Areith762 Go Avs!!!
    I have had good success with these...
    https://www.bestbuy.com/site/netgea...int-and-adapter-white/4760605.p?skuId=4760605
    These are probably cheaper on Amazon...
    smslavin[QUOTED] likes this.
  23. Sep 5, 2017 at 12:07 PM
    kurtwp
    kurtwp What
    Kurt
    Charlotte, NC
    2016 Tundra Limited TRD 4x4 Off Road DC
    My entire network in Ubiquiti
    Since we appear to be sizing our pipes here is my.
    Kurt
  24. Oct 7, 2017 at 6:29 AM
    Outbound
    Aaron
    Northern Alberta
    Holy shit you guys are getting some screaming fast speeds. Are you all on fibreoptic?
    Here's what I'm getting and it's above average for most people in the area:
  25. Oct 9, 2017 at 7:04 AM
    kurtwp
    kurtwp What
    Kurt
    Charlotte, NC
    Yes the run into my NID is fiber. Then from the fiber it jumps to Ehternet into my house.
    Kurt
    Outbound likes this.
