Me want Tundra Thoughts on this one?
Discussion in 'New Member Introductions' started by Beadling, Nov 30, 2018.
  1. Dec 1, 2018 at 3:25 PM
    FlightSimGuy
    FlightSimGuy New Member
    2006 Tundra SR5 V8 DC
    ICON 2.5 shocks with King 14" 700lb coils, Camburg UCAs, ICON V2.0 rear shocks.
    Kinda want to say the same. :(
  2. Dec 1, 2018 at 3:40 PM
    Beadling
    Beadling [OP] New Member
    Should know soon!
    Too good to be true is the reason I wanted advice from the community here in the first place. I have some other listings that look promising also so not all eggs in this basket. When I weed some out I'll post the remaining here again. I will definitely be going over it as thoroughly as I know how, and definitely expect to find some kind of rust.. I'm willing and probably will open up to expanding the search to basically anywhere, geographically, to find rust free.
    Is there a good resource someone can point me to that would breakdown what things should be looked at closely? Specifics, timing belt is what mileage? Etc..
  3. Dec 1, 2018 at 3:46 PM
    tenntundra
    tenntundra 2013 SR5 crewmax Barcelona red
    Walter
    Tennessee
    2013 barcelona red sr5 crewmax TRD tundra
    3" suspension lift, BMF 20" wheels 305/55/20 nitto ridge grappler tires,painted RED bushwhacker fender flares,fold up tonneu cover,100 watt led fog lights,led interior lights,borla dual exhaust,tinted windows,window vent visors, Toyota hood protector,toyota step bars,spyder carbon fiber floor mats,k&n air filter,painted brake calipers red, installed red lug nuts on wheels remote start.
    Timing belt is 90,000 miles according to Toyota manual. My dealer told me 110,000 miles was fine.Be sure to change the water pump and anti-freeze also with the serpentine belt.check the transmission fluid and differential fluids also.change those if needed.
    Beadling[OP] likes this.
  4. Dec 1, 2018 at 3:59 PM
    Beadling
    Should know soon!
    Roger that. Are 1st gen transmissions "closed" systems like the 2008?
    Here are some screen shots of another candidate...
    **I am not actually 1 mile away.
    Also being in New Hampshire I would expect a level of rust.. everything I look for from here on out will be south, from salt free homes I think...
  5. Dec 1, 2018 at 4:05 PM
    BestGen
    BestGen New Member
    Paul
    Haunted Turnbull Canyon CA
    '05 RCLB, 2UZ-FE, 4wd / '88 4RNR XTE 22RE/W56/RF1A
    Fabtech 2.5" coilovers, BFG KO2 34/10.5/17, 17x7.5 TE wheels, add-a-leaves, 4.56 gears, Rhino-lined
    '05 and '06 have the better 5-spd. automatic. They also have a big jump in hp. :thumbsup:
  6. Dec 1, 2018 at 4:40 PM
    tenntundra
    Walter
    Tennessee
    The transmission fluid and filter can be changed . The 2004-2006 4.7 v8 are 271 hp
  7. Dec 1, 2018 at 5:51 PM
    Trooper2
    JR
    Houston, TX (Suburban South)
    Looks priced well, worth a look. If bed liner is drop-in plastic liner check for bed rust underneath, closer to the cab. This on all year models.
