Mayo or butter on the outside of your grilled cheese?
Discussion in 'Off-Topic Discussion' started by Hightide, Jun 16, 2022.
Mayo or butter
  1. Mayo
    24 vote(s)
    17.4%
  2. Butter
    92 vote(s)
    66.7%
  3. I don’t eat grilled cheese because I’m an animal
    6 vote(s)
    4.3%
  4. OR… Mayo/butter combo
    8 vote(s)
    5.8%
  5. Clarified butter
    2 vote(s)
    1.4%
  6. duck confit
    2 vote(s)
    1.4%
  7. Plate welded steel is Damascus
    4 vote(s)
    2.9%
  1. Jun 30, 2022 at 1:28 PM
    #151
    Wixo
    Wixo The Best Member
    Mawr
    RGV
    5.7L 4x4 CrewMax SB
    Tint
    1st part made me gag
    Second sounds good af
  2. Jul 1, 2022 at 1:37 PM
    #152
    RainMan_PNW
    Casey
    Clark County, WA
    2021 Lunar Rock TRD Pro CM
    Mayo is just egg and oil with some lemon juice. They use egg “wash” on all kinds of baked goods to give a golden crust. When using mayo to cook with, it’s the same thing.
    But hey - I know a lot of people not willing to step out of their comfort zone when it comes to trying new foods. No skin off my back…they are the ones missing out on new things
  3. Jul 1, 2022 at 2:12 PM
    #153
    Wixo
    Mawr
    RGV
    5.7L 4x4 CrewMax SB
    Tint
    I know what mayo is, unfortunately most of it out there isn't just egg and oil with some lemon juice. Not saying my problem is with Mayo per sé, but the thought of mayo on certain foods is unappetizing to me, even more so when I know its probably egg like substance and cancer causing canola, vegetable or seed oil.
    RainMan_PNW[QUOTED] likes this.
  4. Jul 1, 2022 at 3:19 PM
    #154
    Kur
    Kur New Member
    Mesa, AZ
    08, 5.7, Double Cab Tundra, White
    literal poison
  5. Jul 1, 2022 at 3:20 PM
    #155
    Kur
    Kur New Member
    Mesa, AZ
    That's not damascus. That is pattern welded. Not the same thing.
  6. Jul 1, 2022 at 3:30 PM
    #156
    Kur
    Kur New Member
    Mesa, AZ
    I don't eat bread anymore. After many years of research it has become increasingly obvious to me that humans are obligate carnivores and that the consumption of plants, specifically wheat, soy, corn, sugar, and vegetable/seed oils, are the root cause of almost all modern diseases.
    There is a reason that heart disease and diabetes used to be incredibly rare and only took off and became common once people stopped eating saturated animal fats and started eating vegetable oils and margarine instead.
    That being said, back in my ignorant days when I used to eat grilled cheese sandwiches all the time, real mayo (made with eggs, bacon grease, and vinegar) is the obviously superior coating to achieve the maximum crispiness and flavor.
    RainMan_PNW likes this.
  7. Jul 1, 2022 at 4:32 PM
    #157
    OHwendTrd
    OHwendTrd Aging Member
    Josh
    21 SR5 3UR-FE
    ATF Cooler, FRAC, RCI Skid
    Voted for butter. But I'm intrigued now to try mayo.
  8. Jul 1, 2022 at 4:46 PM
    #158
    Hightide
    Hightide [OP] SSEM #88 - 3MW - ASCM #2 RGBA#Q
    chadington von banks
    Abalama
    Magic School Bus
    Only because you don’t know.
    Cpl_Punishment and GODZILLA like this.
  9. Jul 1, 2022 at 4:47 PM
    #159
    Hightide
    Abalama
    Magic School Bus
    Something tells me your gag reflex isn’t that sensitive.
  10. Jul 1, 2022 at 4:47 PM
    #160
    Hightide
    Abalama
    Magic School Bus
    This.
  11. Jul 1, 2022 at 4:48 PM
    #161
    Hightide
    Abalama
    Magic School Bus
    Try again
  12. Jul 1, 2022 at 6:37 PM
    #162
    Wixo
    Mawr
    RGV
    5.7L 4x4 CrewMax SB
    Tint
    It isn’t, but mayo has has been ruined for me outside of burgers and sandwiches.
  13. Jul 1, 2022 at 7:27 PM
    #163
    Kur
    Kur New Member
    Mesa, AZ
    Don't have to. That is clearly pattern welded steel. You can clearly see the repeating pattern.
    Actual damascus steel has no repeating pattern. It isn't made by welding two different steels together. It is a single type of steel that creates its own non repeating swirls and lines, that resemble the surface of water, through the crystallization of the specific alloy of steel during the cooling process after being melted in a crucible. Real damascus steel has properties that make it both harder and more durable than a pattern welded steel, and can also be sharpened to a finer edge.
    True damascus steel hasn't been made for a few hundred years as it is a lost art. There are only a tiny handful of modern smiths who have had any success recreating real damascus steel. And that knife is very clearly NOT damascus.
    Of course i am being more technical than most people. The word "damascus" has been used to refer to pattern welded steel since the 70s. But that's just marketing wank. It isn't really damascus steel. It just resembles it at a superficial level.
  14. Jul 1, 2022 at 8:48 PM
    #164
    Hightide
    Abalama
    Magic School Bus
    If it’s now called Damascus, then it’s Damascus.
    Maybe you can discuss this with the maker… @gosolo
    The steels used in Damascus steel are often a mix of a high carbon steel and a steel with nickel alloying. The former gives it excellent hardness and the latter gives it toughness that resists brittle fracture and some corrosion resistance.
    Damascus steel, also known as Damascened steel and sometimes watered steel, now commonly refers to two types of steel used in custom knife and sword making, pattern-weld (giving the appearance of original damascus steel) and wootz (true damascus, a steel of legendary sharpness and strength whose method of forging has been lost to time). Both types of Damascened steel show complex patterns on the surface, which are the result of internal structural elements in the steel. These patterns are the result of the unique forging methods used for the creation of Damascened steel; skilled swordsmiths can manipulate the patterns to mimic the complex designs found in the surface of the original, ancient damascus steel. Recent research into the structure and composition of true damascus steel by a Dresden scientist has revealed that the almost mythical sharpness and strength of the steel was a result of carbon nanotubes and carbide nanowires present in the structure of the forged metal--the secret of which forging method was lost around 1800 A.D.
    gosolo likes this.
  15. Jul 1, 2022 at 8:55 PM
    #165
    Kur
    Kur New Member
    Mesa, AZ
    No thanks. Just because somebody decided to apply the name to a modern steel doesn't mean that's what it is. If I decided to randomly start calling my Tundra a Ferrari, that doesn't mean my Tundra is now a Ferrari. It is still a Toyota. Even if I paint it Ferrari red and put a Ferrari badge on it.
    As I said, calling modern pattern welded steels "damascus" is just a marketing ploy to trick ignorant customers into thinking the knife they are buying is more special than it really is.
  16. Jul 1, 2022 at 9:05 PM
    #166
    18" TRD Off Road Wheels
    Completely different context to a single individual wanting to call something by the wrong name. It is the actual definition of the term.
    It has always been called plate/hammer welded damascus steel, and with the loss of wootz steel there is no longer a need to differentiate.
    Cpl_Punishment and Hightide[OP] like this.
  17. Jul 1, 2022 at 9:05 PM
    #167
    Hightide
    Abalama
    Magic School Bus
    Thanks for the dumb, irrelevant and incorrect analogy.
    Sure are lots of ignorant customers and knife makers according to you.
    Pretty much every knife maker currently in business.
    your toyrrari is not industry standard.
  18. Jul 1, 2022 at 9:05 PM
    #168
    Hightide
    Abalama
    Magic School Bus
    But his Damascus is cooler.:rofl:
  19. Jul 1, 2022 at 9:10 PM
    #169
    The rarity of it is neat, but modern steel surpasses it.
    Hightide[QUOTED][OP] likes this.
  20. Jul 1, 2022 at 9:14 PM
    #170
  21. Jul 1, 2022 at 9:25 PM
    #171
    RainMan_PNW
    Casey
    Clark County, WA
    I’m just hungry for a grilled cheese
  22. Jul 1, 2022 at 9:26 PM
    #172
    Kur
    Kur New Member
    Mesa, AZ
    Dictionaries are hardly a good source of information. All they do is track the usage of words and attempt a common meaning. They are not the absolute authority on what words are real words or what words actually mean. For example, the dictionary definition of "feminism" is "the belief in social, economic, and political equality of the sexes". But we all know that isn't what feminism really is.
    the dictionary also says that an example of an orbit is like a planet around the sun. But that isn't true either. Planets don't orbit the sun, they orbit a center of mass separate from the sun, called the barycenter.
    These are examples of how the dictionary is not the authority on what words mean, but rather a collection of how words are commonly used, whether right or wrong.
    And no, pattern welded steel has not "always" been called damascus steel. That has just become the common word used for it since it was falsely popularized in the 70s.
    And yes, there absolutely is a need to differentiate between the two things. Just because the original technique of manufacturing damascus steel was lost, doesn't mean that the steel no longer exists, or can never exist again, or is somehow now the same thing as the cheap, modern, knock-offs. They are still very different things.
    Besides, as I already pointed out, there are a handfull of modern smiths who have "cracked the code" so to speak and created actual damascus steel in their furnaces. Carbon nanotubes and all. So there is still a chance of true damascus steel making a come-back.
  23. Jul 1, 2022 at 9:28 PM
    #173
    Azblue
    The Dirty T ( ^_^)_且
    Yeah, but you'll probably just fuck it up by putting a tomato on it
  24. Jul 1, 2022 at 9:30 PM
    #174
    Tripleconpanna
    2021 TRD PRO CM; 2008 SR5 CM
    I thought Damascus was a pattern on bed sheets you could buy at Macy's
    :notsure:
  25. Jul 1, 2022 at 9:31 PM
    #175
    It won't make a comeback because it's inferior to modern steel, and for those that want the aesthetics a plate/hammer welded damascus steel will be far more cost effective and just as good. What made damascus great was its comparison to the iron blades of the time. It's nothing special compared to modern steels.
    Hightide[OP] likes this.
  26. Jul 1, 2022 at 9:36 PM
    #176
    Hightide
    Abalama
    Magic School Bus
    That stuff on the sheets did not come from macys.
  27. Jul 1, 2022 at 9:37 PM
    #177
    Hightide
    Abalama
    Magic School Bus
    I say go with mayo.
    less drivel.
  28. Jul 1, 2022 at 9:37 PM
    #178
    RainMan_PNW
    Casey
    Clark County, WA
    It might be good for spreading butter and mayo though…
  29. Jul 1, 2022 at 9:38 PM
    #179
    Hightide
    Abalama
    Magic School Bus
    Grilled cheese are good, but don’t go using inferior modern steel to cut those things.
  30. Jul 1, 2022 at 9:39 PM
    #180
    Kur
    Kur New Member
    Mesa, AZ
    That is only true in the case of very expensive and high end modern steels.
    True damascus actually was pretty special, and not just compared to iron blades, but compared to steel blades as well. By the way, carbon spring steel has been around for 1000 years at least in Europe. It isn't a modern invention.
    True damascus was not only tough, it was hard and corrosion resistant. It also was able to achieve a sharper edge and retain that edge for much longer than other steels. This is because of its unique structure which included carbon nanotubes, which are some of the strongest structures known to man.
    And keep in mind, if we really do figure out the formula and the technique to create true damascus steel, and manufacture it with modern equipment in a controlled environment, removing impurities and perfecting the alloy, it would be that much better than historical damascus steel. And I would bet it would then even rival the modern high end steels in certain applications.
