May have found my truck...advice?
Discussion in '2nd Gen Tundras (2007-2013)' started by mastergunnera8, Jun 17, 2019.
  1. Jun 17, 2019 at 7:13 PM
    mastergunnera8
    mastergunnera8 [OP] New Member
    Northern Virginia
    Greetings all...First Tundra hunting...Trying to stay under 14ish...would love 4WD, but they arent easy to find...Gave up on Tacomas...found a 08, 2WD, DC, 4.7, frame checks out and bed is good, super clean and ok first owner, but second owner kept great service intervals and checks. miles..well 152k...I havent had a V8 truck in forever..driving it I cant tell if its the exhaust, or if its the rear end making noise? Man the truck is super nice looking, and Im pretty anal..any advice? ...oh, the price is at 12K...
  2. Jun 17, 2019 at 7:14 PM
    markg
    markg New Member
    Mark
    NC
    2007 TRD
    Welcome from NC
    mastergunnera8[OP] likes this.
  3. Jun 17, 2019 at 8:05 PM
    Black@Blue19
    Black@Blue19 Old Salt
    Ken
    SE Texas
    See if you can run it to a service at Toyota and have them check it out.
  4. Jun 17, 2019 at 8:11 PM
    mastergunnera8
    Northern Virginia
    They had the yota dealer next door check out the bed and frame and they said it was solid, good to go...I could probably pay them to run through it..or an indy..does the price seem out of line?
  5. Jun 17, 2019 at 8:26 PM
    Black@Blue19
    Ken
    SE Texas
    Spending a hundred now is cheaper than some mega bucks in a four weeks? If it checks out and as clean as it seems I reckon.? Price compare as many as you can find and see what is what. Like pricing comparable for houses?? Best of luck.
  6. Jun 17, 2019 at 8:36 PM
    Trooper2
    JR
    Houston, TX (Suburban South)
    Welcome! if it is a 4.7 then it has a timing belt, a costly maintenance item. The 4.6 and 5.7 have chains.
  7. Jun 19, 2019 at 5:03 PM
    mastergunnera8
    Northern Virginia
    Had it checked out by a local indy mechanic and they gave it a passing grade..needs brakes in 6 months or so, rear end making a little noise, but not too bad..Ill change out the fluid and see how it goes..what is the best to put in it?
