Maxtrac no cut 6 inch lift
Discussion in 'Suspension' started by Mikebam240, Apr 28, 2018.
  1. Apr 28, 2018 at 12:55 PM
    Mikebam240
    Mikebam240 [OP] New Member
    2011 Toyota tundra double cab 4x4
    I have been trying to find reviews on the maxtrac 6 inch no cut lift and can find none. My question is does this leave my front driveshaft at a bad angle without cutting the rear cross member or do they have that figured out?
  2. Apr 28, 2018 at 1:03 PM
    Yzed608
    Yzed608 New Member
    Wisconsin
    Maxtrac has a 6" no cut lift but is for 2WD only, as it uses the spindles for lift. This will not work on 4WD truck.
  3. Apr 28, 2018 at 1:05 PM
    I freaked out when I bought my truck it has a rough country 6 inch lift and rear crossmember is not cut at all according to Rough Country it's an older version
  4. Apr 28, 2018 at 1:07 PM
    Mikebam240
  5. Apr 28, 2018 at 1:12 PM
    Yzed608
    Yzed608 New Member
    Wisconsin
    I stand corrected, I didn't know that existed. Sorry
  6. Apr 28, 2018 at 1:13 PM
    Mikebam240
    I think they're relatively new is why there are no reviews
  7. Apr 28, 2018 at 1:45 PM
    Mikebam240
    Is the front driveshaft on that in a bad angle or is it ok?
  8. Apr 28, 2018 at 1:50 PM
    It's ok, I have triple checked this kit even checked the instructions, it shows to cut both ends of the RCM, but it's not, called RC they told me it's a older version
    Mnorris1206 and Berdine like this.
  9. May 29, 2018 at 8:21 PM
    nammer
    nammer New Member
    Sarasota, Florida
    curious if anybody has tried this maxtrac 6'' lift?
  10. Jun 2, 2018 at 4:14 PM
    Big J
    Big J New Member
    2020 4x4 crewmax
    Subscribed as not cut lifts are a nice option :)
  11. Jun 2, 2018 at 4:44 PM
    Berdine
    Berdine Voodoo Sport
    Binghamton, NY
    2020 VooDoo Blue Trd Sport
    I'm curious too, I know rough country revamped their lift kits due to bad CV angles and problems. That's why all their new kits have to cut the frame to drop the front diff.
    1BadTundra and Mikebam240[OP] like this.
  12. Jun 2, 2018 at 6:14 PM
    Big J
    Big J New Member
    2020 4x4 crewmax
    Berdine and Mikebam240[OP] like this.
  13. Jun 2, 2018 at 7:18 PM
    nammer
    nammer New Member
    Sarasota, Florida
    Where do we see the differences between old and new versions because I checked the rough country website and didn’t see them cutting it
  14. Jun 2, 2018 at 7:38 PM
    Berdine
    Binghamton, NY
    I think it's for 2016s and newer are cut
  15. Jun 2, 2018 at 9:12 PM
    Big J
    Big J New Member
    2020 4x4 crewmax
    Ha! That was always to one “pro” of rough country to me. Not having to cut crossmembers. Lol
    Berdine likes this.
  16. Aug 25, 2018 at 6:42 PM
    nammer
    nammer New Member
    Sarasota, Florida
  17. Aug 25, 2018 at 6:48 PM
    LEKS
    LEKS Truck name “Sancha”
    Makaha
    2013 Rockwarrior Supercharged
    There’s a reason RC stopped doing this. Anytime you’re going that high you need relieve those front angles. Only way to do this is cut the crossmember, there’s no way around that.
  18. Oct 22, 2018 at 7:55 PM
    nammer
    nammer New Member
    Sarasota, Florida
    i got the lift and installed it if anybody has any questions
  19. Oct 22, 2018 at 8:38 PM
    charliebison
    charliebison New Member
    Can you post some details/pics on how they effectively achieved the lift without cutting the crossmember? How do you like it?
  20. Oct 22, 2018 at 8:39 PM
    Big J
    Big J New Member
    2020 4x4 crewmax
    ^ this. Lol :thumbsup: CV angle pics, upper control arms, etc. and more pics. :D
    How does it ride? Was it really no cutting and just bolt on.
  21. Oct 23, 2018 at 4:00 AM
    nammer
    nammer New Member
    Sarasota, Florida
    as far as the lift it's an incoil spacer and a top plate spacer, and the crossmember wasn't cut for the differential drop, so yea cv angles aren't amazing, but hopefully it'll be fine in the long run, i'm never offroad, i love the lift, but as much as I would love any other lift just because i'm sitting high and love the look. rides fine imo, again i'm never offroad,
    Big J likes this.
  22. Oct 23, 2018 at 4:02 AM
    nammer
    nammer New Member
    Sarasota, Florida
    i think it rides like stock, but i'm only on pavement, there was maybe about 1 inch off the lower part of the cam tabs that I had to trim because there was a bend it in for the subframe to fit, but it was anticipated and in the instructions
    Big J[QUOTED] likes this.
  23. Oct 23, 2018 at 4:03 AM
    nammer
    nammer New Member
    Sarasota, Florida
    i had a 7 inch lift on my tacoma prerunner and I had way more problems with vibrations than this, I don't notice any vibrations at any speed
  24. Oct 23, 2018 at 6:05 AM
    nammer
    nammer New Member
    Sarasota, Florida
    Some pics let me know if you guys want to see anything else
    Big J likes this.
  25. Oct 23, 2018 at 6:18 AM
    Big J
    Big J New Member
    2020 4x4 crewmax
    Great pics thanks!
    That does look any worse than some of the 3” coil lift and spacer cv angles from what I can tell by the pics. Not bad!
    Any backspacing wheel requirements?
    Would other 6” coils work instead of the spacers?
    Berdine likes this.
  26. Oct 23, 2018 at 9:40 AM
    nammer
    nammer New Member
    Sarasota, Florida
    I'm running the stock 20'' limited wheels, and plenty of space from the wheel to spindle, i'm pretty sure i'll clear 35's, i'll update next week, and i don't see why any other coilovers wouldn't work? same idea, just prob better ride
    Big J likes this.
  27. Oct 23, 2018 at 9:42 AM
    Big J
    Big J New Member
    2020 4x4 crewmax
    Was exactly my thought as well. Stock offsets will probably give you the least headache. Keep us posted. Loving your build so far :thumbsup:
  28. Oct 23, 2018 at 6:13 PM
    charliebison
    Can you send a pic or two of the crossmember and skid plate that the site shows comes with the kit? Thanks.
  29. Oct 23, 2018 at 6:50 PM
    Berdine
    Binghamton, NY
    Yeah those angles look the same as my 3/2 lift. Wonder if a regular diff drop was installed, if not, maybe help the angles even more
    Big J likes this.
  30. Oct 23, 2018 at 8:20 PM
    nammer
    nammer New Member
    Sarasota, Florida
    I didn’t install the skid plate yet but it’s def thicker and heavier than stock, the diff mounts were removed and bolted to the new subframe
    Mattco808, Berdine and Big J like this.
