Max Tire Size - 2002 Tundra Access Cab 4x4 TRD with 1.5" lift
Discussion in '1st Gen Tundras (2000-2006)' started by Peterv, Feb 25, 2019.
  1. Feb 25, 2019 at 9:43 AM
    Peterv
    Peterv [OP] New Member
    Pete
    I just bought this truck, and it is in need of new tires. Tires on it are 265/75R16's. I have the receipt from ORW for the 1.5" lift, so that is documented.
    What size tires have you been able to put on your stock Tundra 4x4? Anyone with around a 2" lift that could answer the same question?
    Also, if I do upsize the tires, is there an easy method to correct the speedometer for the increased tire diameter?
  2. Feb 25, 2019 at 9:47 AM
    Professional Hand Model
    Hand Protectors
  3. Feb 26, 2019 at 6:17 AM
    TUNDRAIN520
    TUNDRAIN520 TUNDRAin520
    Travis
    Tucson, AZ
    2001 Extended Cab 4x4 SR5
    To the best that I can tell, and as referenced in the thread that Professional Hand Model referenced above, there are a lot of variables. I have an 01 AC 4x4 with a leveling kit (1.5 - 2-inch lift). I went with 16 inch Tacoma Wheels, 1.5 inch wheel spacers (to get the tires to clear the upper control arm), and 285/75/16 BFG All Terrain T/A KO2s. I put them on yesterday and have not experienced any rubbing as of yet. When parked, I can turn full lock and nothing is hitting. I really dig the look.
    In the same thread, another poster expressed that with the same configuration, he has trimmed the bumper and mud flaps and still has a lot of rubbing.
    It seems the safest tire size is 275/75/16.
    Just my 2 cents.
    Here is my rig.
  4. Feb 26, 2019 at 6:43 AM
    Hbjeff
    Hbjeff New Member
    Huntington Beach
    2010 DC 5.7 2wd
    Another vote for 285/75/16. My all time favorite tire, I believe it has the most perfect ratio of height, sidewall, and tread.
    Looks very proportional
  5. Feb 26, 2019 at 6:45 AM
    Darkness
    Darkness Allergic to white
    Luis
    All over SoCal
    The darkest
    It's really dark
  6. Feb 26, 2019 at 7:13 AM
    Casper421
    In the woods
    06 DC
    Darkness[QUOTED] likes this.
  7. Feb 26, 2019 at 2:10 PM
    Hand Protectors
    Glad its worked for you. Those are the best size tires for our trucks. 2000-02.
    I think your spacers are the key to no rubbing, as my rub is very slight. The truck turned like a tank pre bigger tires so I don’t cut it hard anyways.
    Any chance on putting up a different angle pic so we can see how the tires look with your 1.5” spacers?
  8. Feb 27, 2019 at 8:57 AM
    TUNDRAIN520
    Travis
    Tucson, AZ
    Ask.... and you shall receive... at least... more pics that is.
    The first 3 are drivers side at full lock to the right with the last showing the front clearance from inside the well, the next 2 show the passengers side at full lock to the right and the clearance at the rear of the tire from in the well, the next four attempt to show how far outside of the fender the tires are riding, the next show the spacing from the UCA with the tires straight, and lastly... just my fav pic of how they make my truck look.
    I want to clarify a couple of things - (1) I haven't really had much time to drive my rig since I installed the spacers, wheels, and tires, so it is possible that I just haven't experienced rubbing.... yet. I will keep you all posted. (2) I did run into a minor situation in which the front studs are shorter than the rear studs. This causes the lugs that hold the spacers in place to not bite as much of the stud as I am comfortable with. I am working on a fix (installing a bit longer stud). Again, I will keep you all posted. (3) I have no experience with wheel spacers. I did extensive research here and by talking to both of my longtime mechanics. to be honest, opinions were split down the middle. Of my 2 mechanics, one swears by them and the other is dead set against them. That seems to be the consensus here as well. The only real difference is that it seems that the people that hate them have never tried them and the people that love them have. It seems that the few horror stories I have found are of those who purchased the cheapest spacers they could find on eBay, and didn't follow the instructions that go with running spacers. I really really like the look of these OEM wheels with the BFG's... enough to try the spacers with the guidance of my mechanic.
  9. Mar 6, 2019 at 7:14 AM
    Poli169
    Poli169 New Member
    Apolinar
    2001 red tundra sr5
    I installed a Toytec lift kit and running bfgoodrich ta ko2 285/75/16 with no issues.
    Brown Bear likes this.
  10. Mar 6, 2019 at 8:06 AM
    FirstGenVol
    East TN
    2002 AC TRD 4x4 V8
    Looks good. Is that the Toytech BOSS kit? Can you please post some better pictures? I've pretty much decided on the same kit.
  11. Mar 6, 2019 at 6:14 PM
    Poli169
    Poli169 New Member
    Apolinar
    2001 red tundra sr5
    Yes it's the boss one I also got the upper control arms. Let me see if I have better pictures I will take new ones.
    FirstGenVol[QUOTED] likes this.
  12. Mar 6, 2019 at 6:21 PM
    FirstGenVol
    East TN
    2002 AC TRD 4x4 V8
    Thanks. Love the color! My 91 4Runner was the same color.
  13. Mar 6, 2019 at 8:22 PM
    Poli169
    Poli169 New Member
    Apolinar
    2001 red tundra sr5
    Thanks my wife picked it used to be grey but got it painted. I think my kit came with billstein shocks though I got it 3 years ago they changed them.
  14. Mar 8, 2019 at 3:44 AM
    kit
    kit New Member
    So I'll throw in my 2001 Tundra AC Rwd stock height running 285-70-17 BFG Kos w/ spacers not adapters, for 10yrs... I wouldn't tell others to do this, but just sharing what I did... I can only turn the steering wheeling 1 full cycle in forward/reverse... This setup rubs, and you have to be very mindful when approaching turns... I tested the waters with the biggest tires on stock height... Next, I'm putting 35's on my 2011 Tundra stock height...
  15. Apr 10, 2019 at 10:05 AM
    Need to know stuff
    Need to know stuff New Member
    2000 black Tundra TRD
    3 front 2 rear leveling
    I'm on 2 inch leveled 285/70r17
    Little bit of sawzall action though:D
