Max Payload issue - help
Discussion in 'Towing & Hauling' started by Jesusquintana, May 7, 2018.
  1. Dec 20, 2019 at 12:55 PM
    #121
    GhostOfGaspar
    GhostOfGaspar New Member
    2017 TRD Off Road
    Howdy, I just finished reading this thread and wanted to make sure I had my safety ducks in a row. I own a 2017 5.7 v8 CM 4x4 Off Road. My sticker gives me 1270 payload.
    My wife and I are looking at purchasing a Travel Trailer somewhere in the 3500-4000lb dry range. For the sake of this exercise, let's say 4000lbs. My wife and I combine at 415lbs. My dogs combine at 45. We add 300 lbs of gear into the truck. We add 1000lbs of gear, water, etc into the trailer. This puts the payload in the truck at 760 (well under limit) and trailer total at 5k. If I understand correctly, I need to add the tongue weight (9-14% of trailer weight) to the payload. 9% would be 450lbs, putting the payload at 1210lbs (still good, but only 60lbs under). 14% would be 700lbs, putting the payload at 1460lbs (190lbs over). Is this correct so far?
    I understand that to calculate this correctly, particularly with the tongue weight, I would need to get everything on a scale.
    My understanding is that a weight distribution hitch can help alleviate the amount of the payload? Is this correct? Or does it just shift some of the weight from the rear axle to the front axle? Does loading the trailer weight more towards the back help alleviate the payload?
    I know I can always take that 300 lbs of gear in the truck and load it into the trailer, but maybe that load of gear is a person? Just want to make sure I have my head wrapped around the math of this whole thing.
    Any help would be greatly appreciated. Thanks kindly in advance from a newbie to towing.
    WolfPac_Outdoors likes this.
  2. Dec 21, 2019 at 10:56 PM
    #122
    j2007
    j2007 New Member
    VA
    2017 DC Bronze Limited TRD
    Full Debadge, TRD Antisway, Platinum Grille, Baja Designs Squadron Sport Fogs, Morimoto MLED Headlight Retros, Tekonsha P3 Trailer Brake Controller with dash mount, Front Tint, Tyger Tonneau Cover, Anytime Fogs, FRAC, Fortin Evo One Remote Start, 12 Volt Bed Power Socket
    You seem to be thinking it through correctly. A weight distribution hitch will shift some weight to the front axle of the truck, and some to the trailer axles. What shifts to the truck’s front wheels won’t help your payload (but does help steering and braking), but what goes to the trailer axles does help payload. The trailer weight you’re looking at is reasonable. I have a similar truck and trailer to yours and spent time setting up my weight distribution hitch and weighing the whole rig on a cat scale to get it balanced where I wanted it. It tows great and I am right around max payload.
  3. Feb 9, 2020 at 7:49 AM
    #123
    Devi8
    Devi8 New Member
    Dave
    2017 crewmax limited
    Iron cross steps, weather techs, rain/big guards, access cover, tracrac with cantilever
    I thought SAE J2807 is a towing standard not a payload standard.
    Truck has a GVWR of 7200lbs load your trailer and go to the scale now you know how much weight you have on the truck, by proxy you'll see weight on drive and steer Axel's.
    Answer to OPs questions, upgrade to a 3/4 1 ton or take two cars.
    I have a 33ft MPG cruiser with a Propride hitch, my numbers are in with the wife, dog and kids are in the Sienna.
    Atomic City Tundra likes this.
  4. Feb 9, 2020 at 7:53 AM
    #124
    Atomic City Tundra
    Devin
    New Mexico
    2013 Tundra 5.7FFV CM 4X4
    Bingo. People make the assumption frequently that the two 150 lb occupants are allowed in the payload. That is wrong. You still can't be over GVWR. Your GVWR is what it is. There is no addition of extra weight because of the SAE standard.
  5. Feb 9, 2020 at 8:02 AM
    #125
    hogpiolet
    hogpiolet New Member
    Jimmie
    2018 tundra Platnium
    none
    I saw on a you tube video before I bought mine that that something in the numbers were wrong because Toyota already factors in if you have a cm you will have 4 people then add the payload! Seems weird I will look for it
  6. Feb 9, 2020 at 8:21 AM
    #126
    Devi8
    Devi8 New Member
    Dave
    You have 7200 gvwr that it. Your sticker can say 1300lbs payload but that when the truck left the manufacturer. Spray in Bed liners, tow straps, nerf bars etc all add weight and reduce available GVWR.
    When Toyota swapped to a 38 gallon tank in 17, payload was dropped another 78lbs
    And the guy that mentioned no law to break towing over, It's going to be a cival lawsuit much worse, you can't play stupid with lawyers that's called negligence
  7. Feb 23, 2020 at 4:11 PM
    #127
    Hatwsneezing
    Hatwsneezing New Member
    So using a tundra, what's a safe weight to pull with a family + gear?... 4-5000 lbs?
  8. Feb 23, 2020 at 4:16 PM
    #128
    Devi8
    Devi8 New Member
    Dave
    I've heard 75-85% of max rating is safe. Both tow capacity and payload. So it all depends on your truck
  9. Feb 23, 2020 at 4:18 PM
    #129
    Hatwsneezing
    I'm confused, isn't that why the OP purchased a new truck? Their trailer was 7+k? And that's what people have been stating on here... That it's not wise to two that much weight?
  10. Feb 23, 2020 at 5:35 PM
    #130
    Hatwsneezing
    Apologies for bumping an old Post.... But what did you mean by "The money I put out per year in RV cost, Insurance,Maintenance," i thought it would end up being cheaper then hotels lol are you including the cost of the rv itself? Probably just being blind to the notion.
  11. Feb 23, 2020 at 7:04 PM
    #131
    LML 3500HD
    Considering what you can get with an AIRB&B selections, something to think about.
    Average RV cost 30-40K in what our Tundras can pull safely. Some of my co-workers have 50-75K RV's due to pulling with 1 tons. I don't pay off my RV's since I can write it off as a second home.
    So 250-400.00 per month RV cost if going new.
    Insurance (at least in CO) is high. Looking at 500-1000.00 per year
    Tires every 3 years (500.00/3=166.00 per year)
    Registration varies per state. Mine is around 200.00 per year.
    Since you're in COS, you will know the places I'm talking about:
    Fountain KOA 65-80.00 per night after all fees.
    Fun Valley Campground (this is bad ass) 65.00 per night.
    Cheyenne Mountain State park 41.00 per night + 8.00 day pass= 49.00 unless you have the Aspen leaf pass.
    I'm going to go middle of the road on all costs.
    RV=300.00 per month
    Insurance= 45.00 per month
    Maintenance=60.00 per month (this includes tires, brakes, registration, propane, batteries, everything) I think that cost is very low from reality.
    So now we have a monthly estimated cost of 405.00 per month. This also doesn't include those nice 3000W+ generators that run 2000-2600.00 if dispersed camping is your thing.
    Now lets take a vacation down to Fun Valley RV park by Pagosa Springs, CO. 7 days= 455.00+405.00 for RV. 860.00. 122.85 per day cost.
    Here is a 3 bed condo in Pagosa for the same time period for 113.00 per night.
    Now for me, I will most likely always have a trailer behind me, so fuel economy towing will be the same either way I go, except I can't take the rock crawler if I take the toy hauler/RV.
    RV'n can be a lot of fun, and mine saved the families butt when we were homeless for a bit between homes.
  12. Feb 23, 2020 at 7:07 PM
    #132
    LML 3500HD
  13. Feb 23, 2020 at 8:13 PM
    #133
    Hatwsneezing
    Well just talk me out of it why don't you haha
  14. Feb 23, 2020 at 8:40 PM
    #134
    LML 3500HD
    Sorry. There are a lot of benefits as well that a Hotel or AIRBnB can't help with either.
    For instance, my wife is a rock hound. She should've been a geologist. Carlsbad caverns in Carlsbad, NM was always on her short list of things to do. If you look at any of the reviews on hotels in the area, bed bugs are the least of your worries. We hooked up the RV, went south with the Tundra and had a blast. Surprisingly we didn't get any bed bugs..
    Unfortunately, this road in northern NM was the demise of my front diff.
    Don't forget about RV storage unless you have a place for it on the property. Colorado Springs no longer allows to park RV's in the road.
    Hatwsneezing[QUOTED] likes this.
  15. Jul 27, 2021 at 9:49 AM
    #135
    Joybell
    Joybell New Member
    He'd have to throw all his gear behind the axles on his trailer to keep it off the tongue weight, and then sway merrily down the highway. My problem too. Bought a new horse trailer with an empty tongue weight of 800 lbs which is about normal for a well built horse trailer. Fine with the Tundra if I don't put my horse in the trailer - just about at the payload limit. Only later realized that all those ads showing a Tundra pulling a horse trailer that those trailers are the cheaply made ones with aluminum frame and a thin aluminum skin. End of the horse if you have an accident.
