Max Payload issue - help
Discussion in 'Towing & Hauling' started by Jesusquintana, May 7, 2018.
  1. Apr 23, 2019 at 12:45 PM
    #61
    eRockAZ
    eRockAZ Toyota Tundra Enthusiast
    Mesa Arizona
    2018 White CM Sport
    I see mentions of wheel/tire weights as a factor in payload/hauling capacity.
    Not to sound daft... just genuinely curious... why would they be a factor? They're already "on the ground"... not "weighing down" the suspension, frame, body, etc.
    Don't do a lot of hauling, just occasional towing...
    Thanks!
  2. Apr 23, 2019 at 1:21 PM
    #62
    apwisher
    apwisher New Member
    Everett, WA
    2007 CM SR5/TRD 4x4 White
    canopy, TRD Sway, audio
    I thought that this was the crux of it? Have the other Makes adopted this? I thought that standard is what caused the discrepancy. I look at some of these trucks like the ranger, Colorado, etc, and the towing/payload rating for those things are absurd. I would never tow something that was more than double the weight of the tow vehicle. Anything untoward happens and you are just a passenger in the ensuing mess.
  3. Apr 23, 2019 at 1:29 PM
    #63
    Devcom
    Devcom Miles per Gallon? More like Smiles per Gallon!!
    2018 Blazing Blue Tundra Double Cab SR5 5.7L 4x4
    I find it really weird how Toyota figures out the payload my sticker has mine at 1510 pounds. The Crewmax has so much difference in payload compared to my Truck which is a double cab Sr5 Upgrade package 4x4 and I do not have the TRD Off Road package.
  4. Apr 23, 2019 at 1:31 PM
    #64
    Atomic City Tundra
    Devin
    New Mexico
    2013 Tundra 5.7FFV CM 4X4
    Correct. Airbags will technically DECREASE your payload. As you are now carrying the weight of the airbags, also.
    Your truck has a maximum GVWR for it's class - that's the max weight your truck is rated for while it is loaded. Then you have the curb weight of your truck, which is the weight of the truck unloaded. The payload is the difference between those two numbers. So, if you put bigger tires on, your curb weight goes up (your truck is heavier unloaded). So, your payload goes down. Putting those bigger tires on did nothing to increase the GVWR of the truck - it is what it is (it is fixed).
    ColoradoTJ likes this.
  5. Apr 23, 2019 at 1:33 PM
    #65
    Deuxlatch
    Deuxlatch AirBus
    Chris (Latch)
    Tomball, Tx./Lafayette, La.
    2010 Super White Tundra CM
    TRD Supercharger, TRD Big Brake kit, MotoMetal wheels, Undercover Tonneau with dual swing out saddle bag tool boxes.
    I'm of the old skool "better to have more horse than wagon" mentality. With that being said My tundra has the upgraded TRD 16" brake kit and 4.30 rear end. I had no problem pulling or stopping a 20' trailer with a 35 horse Kubota tractor and all it's implements (roughly 9000lbs) through the hill country of Texas. I think you will be alright just going to the beach a couple times a year if you add the weight distribution hitch and drive it with sense. Just load the heavy stuff in the rear of the trailer if you have to.
  6. Apr 23, 2019 at 1:48 PM
    #66
    Not even close.
    Come on down from MN, take a vacation to Colorado. I’ll load up my flatbed with 14k lbs and see if you can even get the trailer out of my back yard. If you do, I’ll personally give you 250.00 for your gas.
    I’ll even start calling the Tundra a 3/4 ton.
  7. Apr 23, 2019 at 1:49 PM
    #67
    abomb60
    abomb60 Maker of things
    Massachusetts
    2018 Tundra 1794 MGM
    I'm at 1185 lbs on the door sticker minus 142 on the modifications sticker so my cargo weight is a huge 1,043 lbs! That's for a 2018 1794 CM 4x4. I didn't buy it really for hauling or towing anything but I like the idea that I can if I need to (not like it would be anything big anyway ... maybe an ATV or something).
  8. Apr 23, 2019 at 2:01 PM
    #68
    Ynot_tonY
    Ynot_tonY Merciful
    Tony
    Baby mods doo doo doo doo doo doo
    Audio/Lift/Tires
    I thought that SAE J2807 added 250 lbs for the driver and one passenger as well as 100 lbs for the hitch weight? That should be taken into consideration with the payload talk correct?
  9. Apr 23, 2019 at 2:14 PM
    #69
    150 lbs x 2
    70 lbs for hitch equipment.
  10. Apr 23, 2019 at 2:22 PM
    #70
    Ynot_tonY
    Ynot_tonY Merciful
    Tony
    Audio/Lift/Tires
    I was off by 20lbs, I'll take it!
    Is there anyway we can put that into a sticky or something? People are thinking they may be over when in reality they may have several hundred pounds left to play with.
  11. Apr 23, 2019 at 2:25 PM
    #71
    I’ll add that to the towing guidelines. Good idea.
    Now what’s posted on your drivers door is the SAE J2807 rating after testing. So for instance, if your yellow sticker says the truck payload is 1300 lbs, this is what you can load. It’s not 1300 lbs plus 370 lbs.
    Atomic City Tundra and Sas like this.
  12. Apr 23, 2019 at 2:28 PM
    #72
    Ynot_tonY
    Ynot_tonY Merciful
    Tony
    Audio/Lift/Tires
  13. Apr 23, 2019 at 2:29 PM
    #73
    abomb60
    Massachusetts
    Edited so as not to confuse. See 2 comments up.
  14. Apr 23, 2019 at 2:32 PM
    #74
    See my revised comment.
    This could get people confused by posting the SAE J2807 requirements. Some might think there’s 370 lbs on the table when there in fact, is not.
  15. Apr 23, 2019 at 2:33 PM
    #75
    abomb60
    Massachusetts
    Thanks ... saw the revised comment after I posted. Still kinda silly that my 1/2 ton truck has a little over 200lbs cargo capacity than a 2-series. I'm thinking these numbers have to be extremely conservative ratings.
  16. Apr 23, 2019 at 2:46 PM
    #76
    careyrob
    careyrob In the field
    Carey
    Massachusetts
    2008 Crewmax TRD 4x4 Silver
    LRO 3/1 leveling lift 35x12.50's on 20x9's Hellwig rear sway bar B&M 70264 SuperCooler Transmission Cooler Firestone airbags Daystar cradles Air Lift WirelessONE Compressor System
    Part of the issue with the sticker rating is the stupid passenger car tires Toyota puts on their trucks.
    Put some Load Range "E" rubber on it with airbags, a trailer brake controller and a weight distribution hitch and you'll be fine.
    mley1 and Bigboitundra like this.
  17. Apr 23, 2019 at 2:49 PM
    #77
    Atomic City Tundra
    Devin
    New Mexico
    1,043 is such a low number for a truck. If I have my family with me - I think the 5 of us ring in at about 800 lbs - and when my kids grow, we will eclipse that number. I won't be able to take my family with me in my effing truck.
    ColoradoTJ and jtwags like this.
  18. Apr 23, 2019 at 2:52 PM
    #78
    abomb60
    Massachusetts
    Yeah it's very low. Mine in reality is a little bit higher as the factory running boards were removed (which i'm guessing is the bulk of the additional 142lbs added). Only other options on top of the 1794 are the TRD dual exhaust and hard tonneu cover.
  19. Apr 23, 2019 at 2:55 PM
    #79
    I will put the J2807 standards in the tow guide, but with some explanation.
    Personally, I find these numbers rather accurate. The Tundra is a great all around 1/2 ton truck. People need to remember the 1/2 ton part. Being safe in all situations is the key here. One might be able to pull XXX weight, but how does it stop, handle in emergencies, mechanical longevity? That’s were this standard came into play. So far, it’s helped the industry build better and safer trucks.
  20. Apr 23, 2019 at 2:56 PM
    #80
    Atomic City Tundra
    Devin
    New Mexico
    Give this guy a beer....STAT!
  21. Apr 23, 2019 at 2:57 PM
    #81
    To be fair...you are a rather big ol’ boy. 6’7” if I remember correctly?
  22. Apr 23, 2019 at 2:59 PM
    #82
    Atomic City Tundra
    Devin
    New Mexico
    Close. I am 6'8". But, I get your point. And "to be fair" always reminds of this:
    https://www.youtube.com/watch?v=E55t0lnp_8M
  23. Apr 23, 2019 at 3:00 PM
    #83
    abomb60
    Massachusetts
    And meanwhile I could be the test driver in the J2807 standards :)
  24. Apr 23, 2019 at 3:03 PM
    #84
    LMFAO.
    You sir are my hero today. Love Letterkenny. Maybe were that came from.
  25. Apr 23, 2019 at 3:05 PM
    #85
    Career goals!!! How fun would that be? Testing all trucks at the maximum payload.
    abomb60[QUOTED] likes this.
  26. Apr 23, 2019 at 6:30 PM
    #86
    tufftundy11
    tufftundy11 New Member
    2000 tundra limited
    King shocks, spc upper control arms
    I'll be in Colorado in July. I'll take you up on that even with 33.5" tires and no performance mods. I live in Missouri btw.
    gosolo and ColoradoTJ[QUOTED] like this.
  27. Apr 23, 2019 at 6:37 PM
    #87
    tufftundy11
    2000 tundra limited
    I just drove 90 with my 4" lifted Tundra crewmax with over 2000 lbs of concrete in the bed yesterday. The truck barely notices anything is back there. Plus an air compressor and bunch of tools.
    mley1 likes this.
  28. Apr 23, 2019 at 7:05 PM
    #88
    phabej
    phabej New Member
    Washington
    2018 Platnium
    1265-75=1190. Lol don't get a bed load of dirt or sand unless you want a broke-back tundra.
  29. Apr 23, 2019 at 7:28 PM
    #89
    abomb60
    Massachusetts
    I’m jealous!
  30. Apr 23, 2019 at 7:38 PM
    #90
    phabej
    phabej New Member
    Washington
    2018 Platnium
    Maybe sr5 sport can do more?
