MattGecko LED Bed & Hood light kits
Discussion in '2.5 Gen Tundra Parts Marketplace (2014-2021)' started by mattgecko, Feb 8, 2017.
  1. May 1, 2020 at 9:23 PM
    #301
    SouthWestGA
    SouthWestGA New Member
    @mattgecko
    Do you make kits for 2nd gen tundras?
  2. May 1, 2020 at 9:30 PM
    #302
    texasrho83
    texasrho83 Old Member
    Charles
    Conroe TX
    2016 DC MGM 4x4
    See build link
    Yes, just posi-tap into the cargo light power wire.
    indymanjoe[QUOTED] likes this.
  3. May 2, 2020 at 7:05 AM
    #303
    mattgecko
    mattgecko [OP] The LED Light Guy... MattGeckoLEDs.com
    South San Jose, CA
    2011 Tacoma, Off road, super charged 4x4
    Yes 2nd gen would be the same kit but without the tie down rails to mount the lights to the light doesn't spread as evenly.
  4. Jun 10, 2020 at 12:17 PM
    #304
    pnw.tundra
    pnw.tundra PNW Tundra
    Paul
    PDX
    2022 TRD Pro | Prev 2020 Tundra aka Blue Whale
    I will order the bed kit and hood light once I get my rails installed!
    HulkSmurf14 and mattgecko[OP] like this.
  5. Jun 19, 2020 at 6:00 PM
    #305
    kuokoa
    kuokoa New Member
    Kailua Kona, HI
    2015 Tundra Crewmax BRM
    could you DM me the install instructions? i am a 0/10 on electrical skills :bananadead:
  6. Jun 19, 2020 at 8:42 PM
    #306
    mattgecko
    South San Jose, CA
    PM sent.
  7. Jun 22, 2020 at 1:11 PM
    #307
    shawn474
    shawn474 Lego connoisseur
    MoCo, Maryland
    Just wanted to thank Matt publicly. He has top notch customer service and bailed me out on multiple occasions. Last week I was removing the rails and dropped one tearing the light strip. He was prompt in his response and worked with me for a best possible solution. Placed the order Friday and it came in the mail today. Thanks again - they don’t get much better than this.
  8. Jun 23, 2020 at 6:41 AM
    #308
    HulkSmurf14
    2014 Tundra Limited
    Tastefully enhanced...
    Awesome kit, period. Like stated above and throughout, Matt is the best example on how customer service should be handed out! Very clear directions and a well thought out product. Thank you Matt!
    Warm white bed lights (only 2 strips due to drop in bed liner bulkhead)...
    All lights on...
    Red topper lights with a disconnect for removing topper...
    JayLo707, mattgecko[OP] and WFD473 like this.
  9. Jul 8, 2020 at 11:52 AM
    #309
    jpine707
    jpine707 New Member
    San Jose, CA
    2017 Limited CM 4x4 MGM
    Ordered the bed and hood light kits. Delivery was quick. Took my time with the installation. I did have a few questions on the install and Matt was very quick to respond (within hours). Overall the installation went well.
    Good product that adds nice visibility and functionality to the bed and hood.
  10. Jul 8, 2020 at 11:59 AM
    #310
    pnw.tundra
    Paul
    PDX
    Nice. I still need to order mine. So many mods to get done!
    HulkSmurf14 likes this.
  11. Jul 10, 2020 at 7:24 AM
    #311
    Bakershack
    Kelly
    Spanish Fort, AL
    2020 SSM 1794 4x4
    Matt, I am planning to get these and tie them into the wiring for my existing OEM bed lights (that were a disappointment to say the least). As an electrical engineer, I am a little OCD about these things though. Can you tell me the current draw or power requirements for the bed lights (5 1/2' bed)? Also, can I adjust the brightness with an inline resistor without damaging the LEDs? I know some LEDs are more sensitive to the supplied voltage than others.
  12. Jul 10, 2020 at 1:31 PM
    #312
    mattgecko
    South San Jose, CA
    Yes a resistor or dimmer can be used, the LEDs are dimmable. They accept 12 volts DC and Amp draw is under 3 Amps.
  13. Jul 10, 2020 at 6:22 PM
    #313
    Bakershack
    Kelly
    Spanish Fort, AL
    2020 SSM 1794 4x4
    Thanks!
  14. Jul 11, 2020 at 6:14 PM
    #314
    7dgoat
    7dgoat Member
    NJ
    2025 Terra Platinum Off-road
  15. Jul 16, 2020 at 11:48 AM
    #315
    Inquiringone
    Ter
    NorCal 408
    Not many yet, mostly stock.
    Thanks Matt. You made this an easy mod. :popcorn::popcorn::popcorn:
    mattgecko[OP] likes this.
  16. Jul 26, 2020 at 10:43 PM
    #316
    Tundyfundy
    Bay Area, CA
    Magnetic Grey DC SR5 4x4 2016
    SUSPENSION: Bilstein 6112 coilover (1.9") w/ Powder Coated Springs and Spring Perch (TRD Red), JBA Upper Control Arms, Bilstein 5160's w/Billet Aluminium Reservoir Brackets, +2 Coachbuilder Shackles, Diff Drop Kit, Carrier Bearing Drop Kit, Brakeline Extensions, ABS Extension, Poly Bushings for Leafs, Coachbuilder Shims (2 Each Side), Coachbuilder Bumpstop Extensions, TRD Rear Sway Bar, TRD Front Sway Bar, Air Lift 5000 airbags w jounce bumpers, Daystar Airbag Cradles WHEELS AND TIRES: BF Goodrich KO2's 275/70/r18, BORA wheel spacers 1.25", TRD Wheel Caps,TRD Valve Stem Caps, Spare Tire Lock PERFORMANCE: Bullydog GT Tuner(Performance Tune), TRD Intake, TRD Dual Exhaust (with Modified Exhaust Hangers for Levelling Tail Pipe),TRD Brake Pads, TRD Oil Cap (US), TRD Radiator Cap, TRD Oil Filter, Optima Yellow Top Battery,GP Battery Distribution Blocks, StopTech Slotted Cryo Treated Rotors, Goodridge G-Stop Steel Braided Brake Line Kit PROTECTION: PNP Engineering Type 4 Rock Sliders (With Full Dimple Plate) ,ADD Stealth Fighter Rear Bumper w Red/Blk Shackles and Custom Stomp Pad, TRD Skid Plate with ReadyLift Spacer Kit, Victory 4x4 LCA Skid Plates, JOMAX ABS Sensor Armor, Rear Diff Breather Mod, ARK splash guards INTERIOR: Husky Liners X-Act (Front and Full Coverage Rear and Front Weather Beater Trans Hump), Interior LED Bulbs, WheelSkins Genuine Leather Steering Wheel Cover(EuroPerf), Clazzio Genuine Leather Seat Covers(BLK/DRK GRYwith custom stitching and embroidered headrests), Clazzio Seat Heaters (Front and Rear), Entune Startup Screen MOD, Entune Off Screen Mod, Tinted Windows with Windshield Visor, AJT Key Fobs,Eagle Claws Floor Mat Clips, Bodyglove Visor Organizer,Custom Door Cup Inserts, Glass Break Sensor,AJT Radio Knobs, Custom Dior Cup Inserts EXTERIOR: Full Debadge, LED Brake Light Bulbs, LED Rear Turns, LED Reverse, LED Plate Lights, LED Cargo Lights, LED Third Brake Lights, LED Front Marker Lights, LED Fog Light Bulbs, Lamin-X Fog Light Covers (Amber),2018 OEM LED Headlights, iHacker harness, VLED Universal Puddle Lights, VLED Interior Footwell Lighting (Front and Rear),VLED Extreme Amber Fornt Turns, NSV Knight Rider Light bar, Baja Designs Sport Squadron Pods in Rear Bumper (Driving/wide), Painted Red Tow-hooks, Bed Rail System, Blind Spot Mirrors, Hitch-safe, Tail-gate lock, EAG Raptor Grille, Custom Grille Badge,Full Vinyl Wrap (Matte Black/Matte Pine Green Mettalic), Charvonia Designs Tie Bed Tie-Downs, Bull Ring Bed Rail Anchors, Line-X, Tundra Bed Mat, Bakflip F1 Bed Cover SOUND: Noico 80Mil Sound Deadening and Noico 170 Mil Thermal Insulation (All 4 Doors, Roof, Floors, Rear Panel, Dash). Hertz Uno K170's Component Speakers (Front Doors with Upgraded Sail Panels), Hertz Uno K170 Coaxial Speakers (Rear Doors), JBL C1-075ct Tweeters (Total 4) in Side Dash and Center Speaker, JBL Stadium 5 Amp w/Remote Bass Adjustment Knob and Amp Rack, 12" Infinity Reference Subwoofer in Custom Enclosure w/ “TUNDRA” Logo, Fast Rings Foam Speaker Rings System(4 Doors), Fix 86 DSP
    How do the soft top camper lights attach?
  17. Jul 27, 2020 at 10:26 AM
    #317
    mattgecko
    South San Jose, CA
    The light strips attach to the two upper supports.
    Hurricane likes this.
  18. Aug 11, 2020 at 9:47 AM
    #318
    Charvonia Design
    Charvonia Design Enthusiast-Owned Small Business Vendor
    Keith
    Huntersville, NC
    2024 Tacoma TRD OffRoad Bronze Oxide
    Would your Tacoma Softopper light kit work on a Tundra? I don't have bed rails so I can't use your bed lights.
  19. Aug 11, 2020 at 9:49 AM
    #319
    mattgecko
    South San Jose, CA
    I can make a Tundra Soft Topper light strips kit (without the bed lights). I'll PM you info shortly.
  20. Aug 13, 2020 at 10:54 PM
    #320
    OnespeedTRD
    OnespeedTRD New Member
    Don
    San Diego
    2020 Tundra Limited TRD Off-Road
    275/70r18 Cooper AT3 XLT on SCS Ray 10s, Eibach Coilovers, DD 12" Exhaust, AJT Blackout Kit, Truxedo Pro X15, paint match/chrome delete.
    Think I'm going to order a hood and bed kit. I assume the hood kit just wires right to the battery, but how do you power the bed lights?
    Would this require running power all the way to the hood or do you tap in to power in the bed? I actually prefer a manual switch so not looking to tap into any existing switched power.
  21. Aug 14, 2020 at 7:00 AM
    #321
    mattgecko
    South San Jose, CA
    I'll PM you the install instructions for your review. Both kits wire to the battery and have switches to activate the lights.
  22. Aug 19, 2020 at 6:41 PM
    #322
    fusion94
    fusion94 Just some dude...
    Tony
    Half Moon Bay, California
    2015 Barcelona Red Tundra CM SR5 5.7L 4x4
    Emailed matt wrt instructions, why is this just not downloadable ?
  23. Aug 20, 2020 at 8:28 AM
    #323
    mattgecko
    South San Jose, CA
    Email sent.
  24. Aug 22, 2020 at 3:31 PM
    #324
    grichg
    grichg New Member
    rich
    Hey Matt, Ordered a SnugTop Hi Liner and looking to get some of your lights and my bed is 6.5'. Can you recommend what yoiu think is best, thanks
  25. Aug 22, 2020 at 3:57 PM
    #325
    mattgecko
    South San Jose, CA
    Tundra long bed camper LED light kit. For carpeted shell you would just need to add the "hook" side of Velcro to the back of my lights. I'll PM you info.
    grichg[QUOTED] likes this.
  26. Aug 24, 2020 at 10:24 AM
    #326
    Tigereye
    Tigereye New Member
    Eric
    2019 SSM Limited
    bed liner, diamondback se, level kit, nitto ridge grapplers,tufskinz letters, grab handle
    Ordered a set of warm white bed lights.
  27. Oct 2, 2020 at 8:47 AM
    #327
    shapinoweno
    shapinoweno New Member
    2014 Tundra Platinum crewmax 4x4
    can you pm me the info as well? i have a softtopper on order and this light kit looks perfect
  28. Oct 2, 2020 at 10:54 AM
    #328
    timsp8
    NY
    Ordered the hood lights last sat. Came in on fri. Took less than an hour to install. Most of it was trying to run the wire under a piece by the windshield. I couldn’t get my hands in there, so my wife tried then was determined and that took awhile.
    It’s a good kit that works well.
    WFD473 and mattgecko[OP] like this.
  29. Oct 5, 2020 at 4:04 AM
    #329
    Tigereye
    Tigereye New Member
    Eric
    2019 SSM Limited
    I finally installed the bed light kit. The instructions were easy to follow and the lights look great. Thanks Matt.
  30. Oct 17, 2020 at 7:53 AM
    #330
    fbingha
    fbingha New Member
    Bakersfield, CA
    Interested in getting this but want the lights to come on automatically when the tailgate is down. Any pointers on a switch for that ability?
