MattGecko LED Bed & Hood light kits
Discussion in '2.5 Gen Tundra Parts Marketplace (2014-2021)' started by mattgecko, Feb 8, 2017.
  1. Jan 12, 2020 at 4:36 PM
    #271
    Rocman
    Rocman New Member
    Randall
    Reno, NV
    2019 Tundra Platinum
    I installed in a 2019 Platinum with a bed rug without any issue...works fine. The strips were attached to the bottom side of the tie down rails. On the middle rail however, behind the cab, i had to attach slightly off center of the rail cheating towards the open end of the bed. This was because the bed rug come all the way up to the bottom of the rail and attaching the strip to center of the rail bottom would have concealed the light strip. On my 2019 i already had a pre-drilled hole for the toggle switch. I only had to drill the small hole for the power wire. I cut a small opening in the rug to allow the toggle switch to be accessible. I was so pleased with the bed light that i ordered the hood light and just installed that too. The hood also has some pre drilled holes so i was able to fish the power wire through them to help conceal the wire. All done...works great. If you're thinking about doing both...bed and hood, there's a discount when buying both at the same time...just an fyi.
    mattgecko[OP] likes this.
  2. Jan 26, 2020 at 11:57 AM
    #272
    ackthresher
    ackthresher New Member
    Jamie
    2017 cement crew max tundra pro
    I’m thinking about the bed lights!going to look into!!!
  3. Mar 18, 2020 at 4:28 AM
    #273
    HulkSmurf14
    2014 Tundra Limited
    Tastefully enhanced...
    Are there photos of available to showcase other colors beyond the varying whites? Im interested to see how well red is lighting the bed up...for hunting season, etc...
  4. Mar 18, 2020 at 6:52 AM
    #274
    mattgecko
    mattgecko [OP] The LED Light Guy... MattGeckoLEDs.com
    South San Jose, CA
    2011 Tacoma, Off road, super charged 4x4
    Red
    UV / black light
    Green
    No pics of Blue yet
    WFD473 and HulkSmurf14[QUOTED] like this.
  5. Mar 19, 2020 at 2:47 PM
    #275
    HBdirtbag
    HBdirtbag New Member
    Walnut Creek, CA
    2017 limited cm
    after a year of these sitting in my office, finally got them installed today! Thanks matt!
    HulkSmurf14 and mattgecko[OP] like this.
  6. Mar 24, 2020 at 10:22 AM
    #276
    mattgecko
    South San Jose, CA
    HulkSmurf14 likes this.
  7. Mar 24, 2020 at 10:42 AM
    #277
    HulkSmurf14
    2014 Tundra Limited
    I have a drop-in plastic bed liner; yes I know, they aren't as good as anything else...but I'm not removing it or trading it for another option...ha! One thing I noticed though is the plastic liner comes up the front of the bed and interfaces with the bed rail setup the Tundras optioned...there is essentially, no place to stick the center LED strip in the front but only on the sides of the deck rail system...is there is way @mattgecko, that I could trade a LED segment (middle) for just a longer stretch of wiring so both driver and passenger sides can have light without me needing to splice anything and forgoing the middle led strip up near the cab? Or, how would you navigate such an instance? Does this make sense?!
  8. Mar 24, 2020 at 11:18 AM
    #278
    mattgecko
    South San Jose, CA
    Yes I can make you just the side light strips only both with long wire harness attached.
    Just drill a small hole at the end of each of the light strips at the rear of the truck and run the wire harnesses under the truck to the switch.
  9. Mar 26, 2020 at 9:10 AM
    #279
    Gotigergo
    Gotigergo New Member
    Matt, I have the under hood light kit for my 18 Tundra. I can't get the hood pin switch in place properly because there is what appears to be the headlight housing underneath the hole for the switch. Please advise.
  10. Mar 26, 2020 at 9:20 AM
    #280
    mattgecko
    South San Jose, CA
    Please bend the the lower connector so it sits vertical.
  11. Mar 26, 2020 at 5:58 PM
    #281
    Gotigergo
    Thanks! I figured that was the remedy but was afraid I'd break something. I got the bed lights installed a month ago and finally did the hood lights today. Excellent product!
    WFD473 and mattgecko[QUOTED][OP] like this.
  12. Mar 27, 2020 at 4:58 PM
    #282
    Ketchumj
    Ketchumj New Member
    South Texas
    2020 Tundra SR5 4x4 Double Cab
    2020 Tundra 4x4 SR5 Magnetic Grey – TSS Off Road Toytec Complete performance 3” Lift kit with Aluma Series 2.5 Coilovers, SDP Upper Control Arms, Black Rhino 18” Gauntlet Wheels - +12 Offset, Nitto Terra Grapplers – 295/70R18, Victory 4x4 strike Front Bumper, Fab Fours Premium Rear Bumper, Smittybilt X20 12k Winch
    Just ordered my set. I cant stop doing upgrades!!!!!
    Ely010606 and HulkSmurf14 like this.
  13. Apr 5, 2020 at 8:53 AM
    #283
    dwatts222
    dwatts222 New Member
    Daniel
    Just installed the bed lights. Highly recommend these for anyone that is on the fence. I thought about making my own set up, but @mattgecko takes all of the guess work out of it, and has customer service to match. Would highly recommend.
  14. Apr 13, 2020 at 6:27 PM
    #284
    Walkem
    Walkem New Member
    Canada
    2020 TRD Sport Premium CMax
    On a scale of 1-10 how hard is the install on this for someone that isn't electrically inclined lol.
  15. Apr 13, 2020 at 6:47 PM
    #285
    dwatts222
    Daniel
    @Walkem it’s no more than a 2 or 3 out of 10. The hardest part, in my opinion, is fitting the switch through the hole you drill in your bed liner. Otherwise, you are just connecting wires and tucking them away. If you have any questions ask @mattgecko —he is very responsive and provides printed directions.
    Ely010606 likes this.
  16. Apr 13, 2020 at 7:19 PM
    #286
    Walkem
    Walkem New Member
    Canada
    So where does this switch go?
  17. Apr 13, 2020 at 9:08 PM
    #287
    buckeyeinlv
    buckeyeinlv International Man of Mystery
    Brandon
    Henderson, NV
    2020 Army Green TRD Pro CrewMax
    OEM Power Tailgate Lock, Peragon Tonneau Cover, S&B Intake, Bora 1” Spacers, ceramic window tint. Interior: OCD Organizer, AJT Designs Cup Tray and Shift Trim, JDMCar Rubber inserts. Tires: 285/70R18 Old Truck: Base:2017 Inferno SR5 CM 4x4 Mods: Interior- OCD organizer, Proclip USA iPhone X Mount, Wireless center console charger, TRD shift knob. Exterior- Backflip G2 Tonneau Cover, Amp Research Powersteps and Bed Step, Pop and Lock tailgate lock, Ceramic window tint, Blackout emblems, TRD Pro Grille, Stubby antenna, Vinyl American flag TRD graphics, Color matched and bullet lined bumper ends, 18x9/+25 Method NV305 Bronze wheels Engine- Stock
    Interested in both the hood and bed sets. Could I please see the install instructions? Also, could a three way switch or the remote, switch between two colors (white, green) for the bed?
  18. Apr 13, 2020 at 9:13 PM
    #288
    buckeyeinlv
    Brandon
    Henderson, NV
    Where did you get those drop brackets for your rail system?
  19. Apr 14, 2020 at 6:20 AM
    #289
    dwatts222
    Daniel
    You drill a hole for the switch just left of your driver's side bed rail. But, you can really drill the hole anywhere there is dead space.
  20. Apr 14, 2020 at 7:06 AM
    #290
    mattgecko
    South San Jose, CA
    PM sent. Thanks!
    buckeyeinlv[QUOTED] likes this.
  21. Apr 14, 2020 at 8:11 AM
    #291
    Walkem
    Walkem New Member
    Canada
    Thanks brother, will be purchasing this down the road I'd imagine. New truck should be arriving today, have to do the necessities first. Such as floor liners, tint, and tonneau
  22. Apr 14, 2020 at 12:09 PM
    #292
    Tundra Fan
    Tundra Fan Got 17's?
    Toby
    Nor Cal (Placer Co.)
    They came with my Bakflip tonneau cover. They're are surprisingly stout, I was worried they were going to bend when using ratchet straps on they rails but they haven't.
    coTony and buckeyeinlv[QUOTED] like this.
  23. Apr 19, 2020 at 9:27 AM
    #293
    egibson606
    egibson606 New Member
    Eric
    Georgetown, ky
    2019 super white SR5 tundra
    Could you pm me the instructions for the hood kit? Might be making a purchase of them for another quarantine project.
  24. Apr 30, 2020 at 11:40 AM
    #294
    kingpin3919
    kingpin3919 New Member
    Bob
    2017 cement tundra TRD PRO
    Matt, could you PM me as well. I'm also interested, thanks.
  25. Apr 30, 2020 at 12:49 PM
    #295
    mattgecko
    South San Jose, CA
    PM sent.
  26. Apr 30, 2020 at 12:50 PM
    #296
    mattgecko
    South San Jose, CA
    I only sent the bed instructions out in advance, the hood lights installation requires no drilling.
  27. Apr 30, 2020 at 3:16 PM
    #297
    indymanjoe
    indymanjoe New Member
    Joe
    2017 Tundra
    I think i know the answer, can this be wired to the cargo light switch? If so will it need any relays etc..checked out your site,good job.
  28. Apr 30, 2020 at 3:55 PM
    #298
    Zero One Actual
    ATTENTION:
    I am doing a custom LED strip for a CVT awning that requires a certain wiring configuration. I contacted @mattgecko and he emailed me and called to discuss exactly what it is I needed and to ensure everything I needed and wanted was taken care of. I already have his under hood and truck bed kit and he is matching the LED light to those so at night everything is the same. Additionally, it will have a quick disconnect option for when my awning is not in use.
    Top notch customer service and super awesome dude.
    I will post pics when done.
  29. Apr 30, 2020 at 4:31 PM
    #299
    mattgecko
    South San Jose, CA
    Do to liability I don't provide any install instruction that tie into factory wiring.
    To answer your question, yes it can be done info can be found on the forum.
    Ketchumj likes this.
  30. May 1, 2020 at 6:52 PM
    #300
    Squatch
    Squatch New Member
    Kyle
    Blue led bed lights
    Rgross2112 and mattgecko[OP] like this.
