Master cylinder issues
Discussion in '1st Gen Tundras (2000-2006)' started by masterpia, Mar 30, 2025.
  1. Mar 30, 2025 at 12:14 AM
    masterpia
    masterpia [OP] New Member
    2006 Tundra
    I have a 2006 Tundra double cab. It has disc brakes in the front and drums in the rear. It also has ABS. My problem is I can't seem to find the correct master cylinder and power booster. Any help would be great. Can they be rebuilt? Can I get rid of the ABS and use a regular MC and Booster? Any suggestions? I've only had this truck for about 3 months.
  2. Mar 30, 2025 at 5:51 AM
    NickB_01TRD
    Nick
    KY
    01 Tundra V8 4X4 AC SR5 TRD
    Post up pics of your setup. You may have the rare complicated unicorn master cylinder.
  3. Mar 30, 2025 at 1:56 PM
    rouxster70
    rouxster70 New Member
    04ac2wdv65spd
    Go to Toyota dealer website, several that are good. Put your vin into site. or
    I call auto nation in chandler and talk with their parts folks. They will usually give you a part number
  4. Mar 30, 2025 at 2:52 PM
    Fragman
    Fragman New Member
    TX
    2006 Tundra DC SR5 2WD V8
    If you have a doohickey between the brake fluid reservoir and the booster, you have the famous 'unicorn' master cylinder. That said, someone managed to repair the 'unicorn' part that is the common failing part. Take a look at this and read a few before and after for context. Post 185 has a pic of the unicorn version. Maybe that will help before dropping $1k on replacements. Generally speaking, if you have the 2006 DC, have ABS and don't have VSC, you have the unicorn system.
    https://www.tundras.com/threads/im-at-my-wits-end-master-cylinder-issues.39933/page-7#post-3836678
  5. Mar 30, 2025 at 3:22 PM
    masterpia[OP] likes this.
  6. Apr 3, 2025 at 1:25 AM
    masterpia
    2006 Tundra
    Thank you. I'll do that.
    Just my luck a "unicorn"!
