Master cylinder bench bleeding
Discussion in '1st Gen Tundras (2000-2006)' started by mudddbone, Nov 8, 2020.
  1. Nov 8, 2020 at 9:07 AM
    mudddbone
    mudddbone [OP] New Member
    Dave
    2006 Gold Tundra crew cab V8
    I purchased new master cylinder and while bench bleeding as soon as I poured the brake fluid into the reservoir it drains out the front weep hole. I performed step 1 in the instructions but I cannot proceed to step 2 because it won't hold fluid. Back story...I purchased 2 from advanced and returned them because they did the same thing, thought maybe it was a bad lot. I am on my third one, this one is Raybestos brand. Are the instructions missing a step?
    YardBird likes this.
  2. Nov 8, 2020 at 9:11 AM
    YardBird
    YardBird Native San Diegan
    Jonesy
    2005 RCLB
    It's very odd that two of these units were defective . . .
    I can't imagine what you could have done wrong in this situation.
    Keep us posted with your results.
  3. Nov 8, 2020 at 9:23 AM
    Darkness
    Darkness Allergic to white
    Luis
    All over SoCal
    The darkest
    It's really dark
    Weep hole you say? Is that the little hole at the very end? Maybe you have pushed the piston too far when bench bleeding. It doesn't need to go all the way in.
    When I did mine last year I did the bench bleed at a bit of an angle with a hose going from each port back to the reservoir. I didn't push the piston very far but after a few pumps no more air was seen.
  4. Nov 9, 2020 at 7:02 AM
    mudddbone
    Dave
    It is a little hole on the piston end. We never touched the piston though, took the cap off, put fluid in the reservoir and it came straight out the weep hole. it was the same on all of them. I have attached a picture. The first two it was at the 3 o'clock position (different manufacturer)
  5. Nov 9, 2020 at 7:45 AM
    pickeledpigsfeet
    pickeledpigsfeet New Member
    Sierra Foothills, Ca
    2019 Tundra/14 FJ/ 90 SASed xcab
    Kings & Icons
    It is missing the Cylinder Sub assembly. That hole feeds it.
    YardBird, Darkness and Sunnier like this.
  6. Nov 9, 2020 at 7:48 AM
    pickeledpigsfeet
    Kings & Icons
  7. Nov 9, 2020 at 10:13 AM
    Darkness
    Luis
    All over SoCal
    The darkest
    It's really dark
    Oh no, you have the painful one. Thats a horse of a different color.
  8. Oct 25, 2024 at 5:07 PM
    USERidiculousNAME
    USERidiculousNAME ToyTurd
    Josh
    New Orleans
    250K on Early 2004 tundra DC 4.7 v8, SR5, RWD, A/T, LSD, w/ABS,TOW, OFF ROAD, ZERO RUST FRAME, BILSTIEN 5100, AAL, 17" 265/70
    Backup camera, camper shell, double din stereo, amp, sub, blind spot cameras, modest lift, newer Tacoma rims, large AT tires, interior lighting upgrades, in bed, under hood, as well as leds in cab, blue foot well strips (night driving)or bright white strips if need to see, 3 additional white leds on ceiling front L/ R and center, toggle switch's and added accessory fuse box.
    So is the no answer, answer to bench bleed those 2 parts together then attach to booster? Or "bench" bleed it on vehicle using 3rd chamber?
  9. Oct 28, 2024 at 11:35 AM
    kentuckyMarksman
    kentuckyMarksman New Member
    2006 Tundra SR5 Double Cab - 4.7L V8 4x4
    The sub cylinder assembly is only available is you buy it with a new master cylinder and brake booster from Toyota. I dealt with this earlier this year. I bled it all together because that's how it comes from Toyota. I threaded some plastic nipples on the holes in the master cylinder, attached clear tubing to them, routed the tubing back up into the fluid reservoir, and pumped the rod (grabbed it with pliers) coming out of the back of the booster back and forth until all the air bubbles were out of the clear tubes. I then installed the whole assembly on my truck, reconnected the brake lines, and then bled the brakes after that.
    Radix likes this.
