**MASSIVE GROUP BUY (FOG LIGHTS, LIGHT BARS, AND MORE)** eledobleu **CLOSED**
Discussion in 'Lighting' started by eledobleu, Feb 11, 2019.
  1. Feb 11, 2019 at 6:30 PM
    eledobleu
    eledobleu [OP] retrofitwholesale.com
    Orlando, FL
    Koito Bi-LED Retrofit
    Hello everyone! As many of you know I recently lost my son in 2018. Because of this I am no longer doing retrofits. However, because I am a dealer for The Retrofit Source, I can still offer my fellow Tundra members great discounts on a lot of products. After receiving so many emails and messages, I have decided to hold group buys on specific products of up to 20% off, and also continue the 10% off Tundras.com member discount on all products on the website. The website has been updated with some of Morimoto’s newest products and is still being added with new products (retrofitwholesale.com). All orders will come with TRS’s standard warranty.
    First, I would like to start with the Morimoto XB LED Fog Lights for 07-13 and 14-19 Tundra models.
    10+ MEMBERS NEEDED FOR ALL GROUP BUY's
    20% + FREE Shipping to Continental United States
    HOW TO PURCHASE:
    Click the following links below to go directly to the purchase page on RetrofitWholesale.com. During checkout, use coupon code "groupbuy20" Coupon is restricted to 1 item per order. So if you want to order more than 1, you must do separate transactions.
    If you don't see an email confirmation after purchase, please check your Spam Folder.
    END DATE:
    TO GIVE PEOPLE PLENTY OF TIME TO PURCHASE, THIS GROUP BUY WILL LAST UNTIL SUNDAY @ MIDNIGHT 3/11/2019 Eastern Time. Please note fog lights will not begin shipping until after 10 orders have been placed.
    PURCHASE LINKS:
    XB FOGS TYPE T (14-19) TOYOTA (OVAL): MORIMOTO XB LED FOG LIGHTS - Retrofit Wholesale Note: (2018- 2019 Sport and Platinum models come standard with LED fog lights. Only order this if you have SR, SR5 and Limited models)
    XB FOGS TYPE T2 (07-13) TOYOTA (ROUND): MORIMOTO XB LED FOG LIGHTS - Retrofit Wholesale
    RULES FOR ALL GROUPBUYS:
    1. You must be a forum member.
    2. During checkout, you must include your forum username (SEE EXAMPLE). Any orders without verified forum usernames will be canceled and refunded before or after group buy has closed
    WARRANTY:
    Fog lights comes with a 10 year warranty!
    Please read Warranty Details: Warranty - Retrofit Wholesale
    SPECS
    • Light Source: 3x Philips Luxeon-T
    • LED Optics: Kuria-2 Projector Fog Lens
    • Intensity: 2400 Lumens (1200 per fog light)
    • Kelvin Rating: 5500K (pure white)
    • Input Socket: Sealed H11 Male
    • Weather Rated: IP67 Waterproof
    • Lens Material: High Impact Polycarb (UV-Resistant)
    • Shell / Heat Sink: Powder Coated Cast Aluminum
    PICTURES:
    XB FOG LIGHT INSTALL GUIDE
    XB FOGS ARE DIRECT Plug N Play
    Gen 2
    1. You need to go through the wheel well liner. Once you remove it, you will have access to the fogs.
    2. Disconnect the fog lights connector.
    3. Theres 1 Plastic retainer that holds the fog light in place. Use a flat head screw driver to unlock it. Remove the fog light by pushing foward and out.
    4. Get your new XB fogs. The fog lights are NOT L/R Oriented.
    5. Check the connectors polar pattern. Its reversed compared to standard connectors. Insert the wires into the blank connector noting the proper orientation of the Positive and Negative wires. (Be careful as once you lock it in the connector, its extremely difficult to remove).
    6. Slide the XB fogs in its place and use the plastic retainer to lock it in place.
    7. Connect the Fog Lights to OEM connector.
    Gen 3
    3. Disconnect the fog lights connector.
    2. There are two slots and 1 screw that holds the stock in place. Remove the scew and slide the stock fog light.
    3. Get your new XB fogs. The fog lights are L/R Oriented. Look on the back of the lights to locate the L/R letters to know which side. R= Passenger, L=Driver.
    4. Check the connectors polar pattern. Its reversed compared to standard connectors. Insert the wires into the blank connector noting the proper orientaion of the Positive and Negative wires. (Be careful as once you lock it in the connector, its extremely difficult to remove).
    5. Slide the XB fogs in its place and either use the new screw that came with the fogs or re-use the old. Its a tighter fit as the tabs on the XB are thicker. Tighten the screw down.
    6. Connect the Fog Lights to OEM connector.
    AIMING
    Since everyone has different heights on their truck, I cant give you a specific way to aim them. Best way is before removing your old fogs, drive back 10-15ft from a wall or ground and use tape to mark where your lights are.
    The XB fogs are projector base LED's so the light will be more focused. Start by aiming them to the stock levels. Drive around without headlights on (parking lights off) so you can see where the spread is.
    Spread should be about 4-10 ft in front of your truck depending on your headlights.
    For those with retrofits, you want the XB fogs to end right at the beginning for your main HID or LED projector beam spread.
    For those with stock halogen reflectors (with or without hid or led upgrades in reflector housings), you want the beam to end towards the middle of the main headlights beam spread.
    Raise and lower to get your optimum desired height.
    Hope this helps guys
    CementGen3, mlucas555 and Vr0ck like this.
  2. Feb 11, 2019 at 6:30 PM
    eledobleu
    Orlando, FL
    Profile LED Light Bars
    Now available are Profile’s LED Light Bars. These Light Bars are all RGB and can be controlled using your phone if you purchase the optional XB Bluetooth Controller.
    15% GROUP BUY 10+ Members.
    Coupon Code: “rgbar15”
    ORDER PAGE (https://retrofitwholesale.com/product/profile-performance-rgbar-8/)
    SPECS:
    · LIGHT BAR: 1x Profile RGBAR in sizes of 8″, 9.5″, 20″, 26″, 32″ and 42″
    · BRACKETS: 2x Powdercoated L Mounts
    · HARDWARE: Hex mounting screws w/ key
    · WIRING: DT06 Male 12V +/- Input
    · WARRANTY: 3 Years
    PICTURES:
    [​IMG] [​IMG]
    mlucas555 and TRD15559 like this.
  3. Feb 11, 2019 at 7:10 PM
    eledobleu
    Orlando, FL
    *** MORE PRODUCTS WILL BE ADDED TO THIS THREAD INCLUDING; LED WHEEL LIGHTING, TAIL LIGHTS, LED BULBS and MORE....!***
    mlucas555, Phantastic81 and BigGreek like this.
  4. Feb 11, 2019 at 7:12 PM
    the_midwesterner
    the_midwesterner New Member
    Luis
    None, yet....
    Posting in here for the morimoto headlights when available. Already have the OEM LEDs and dig them, but if these are that much better then I want a pair.
    Berdine and 831Tun like this.
  5. Feb 11, 2019 at 7:34 PM
    Major
    Major TTC #0181
    Josh
    NC
    2017 CM Attitude Black Platinum
    Stock.
    In for updates. Is the LED lights comparable to what I would pay in a basic retrofit?
    OAN, my deepest condolences for the loss of your child. Prayers up.
  6. Feb 11, 2019 at 7:37 PM
    MotoTundra
    MotoTundra The Ocho
    Don
    I think the Morimoto XB headlights will be sick.
  7. Feb 11, 2019 at 7:44 PM
    eledobleu
    Orlando, FL
    Thank you! :amen:
    From my understanding, the light output will be on par with Morimoto Projector retrofits. Also these headlight swill have roughly a 5 year warranty. Updates will be posted about the Headlights as I receive them.
  8. Feb 11, 2019 at 7:50 PM
    white_sherpa
    white_sherpa New Member
    Phoenix, AZ
    2014 Tundra SR5-Magnuson Supercharged- Custom Tune by DynoComp
    I would be interested in these!
  9. Feb 11, 2019 at 7:55 PM
    FoghornTX
    FoghornTX Proud American and Infidel since 1968
    Ft Worth, Texas
    2022 Camry XSE (Black w/blackout package)
    Them damned "soon to be released" Morimoto headlights.
    Just take every damned cent that I have, damnit.
    Stormtrooper81, Vr0ck and MotoTundra like this.
  10. Feb 11, 2019 at 8:18 PM
    Theyfzman
    Theyfzman New Member
    Pa
    08 TRD
    Condolences to you and your family. I lost my son a few years back not easy !!!
    Can you get any discount on the OEM sequoia leds retro sells ?
    Stormtrooper81, Y0TA PR0 and TheBeast like this.
  11. Feb 11, 2019 at 8:22 PM
    TheBeast The Beach
    sorry for your loss and +1 on the OEM 2018 Sequoia for us gen 2 Tundras unless TRS has plans to release gen 2 headlights like the 14+
  12. Feb 11, 2019 at 8:31 PM
    eledobleu
    Orlando, FL
    Thank you! Although I wish this on no one, Its a relief to know someone else shares my pain :amen:.
    To answer your question, unfortunately not at the moment but there's a high change Morimoto is also working on an XB Headlight assembly for Gen 2 Tundras and Sequoia models. If any news arises I will let everyone know!
    Kiddnapped Tundra likes this.
  13. Feb 11, 2019 at 8:51 PM
    TheBeast The Beach
    that would be awesome. so many of us gen 2 with no LEDs :(
  14. Feb 11, 2019 at 8:57 PM
    Y0TA PR0
    Y0TA PR0 Dirt biking & fishing
    Rafael
    2017 TRD PRO
    My condolences to you guys and family.
  15. Feb 11, 2019 at 9:10 PM
    Pudge
    CT
    2015 Blue Ribbon Platinum
    It's been a while but its good to see you back after your family's tragedy. I hope that things will be on track this time around and there are no hard feelings after everything that went down when you left last year. Best of luck to you in the future here.
  16. Feb 12, 2019 at 5:45 AM
    eledobleu
    Orlando, FL
    Thanks buddy I really appreciate it. No heart feelings at all. I'm just glad to be able to help my fellow Tundra owners again.
  17. Feb 12, 2019 at 5:53 AM
    Condolences to both of your families.
    Markman and BigGreek like this.
  18. Feb 12, 2019 at 7:04 AM
    eledobleu
    Orlando, FL
    Thank you! :amen:
  19. Feb 13, 2019 at 11:34 AM
    eledobleu
    Orlando, FL
    XB Headlights have been moved to a seperate thread.
  20. Feb 14, 2019 at 6:10 AM
    Theyfzman
    Pa
    08 TRD
    Thank you !!!!
  21. Feb 14, 2019 at 8:04 AM
    Firemedic1428
    Firemedic1428 New Member
    2022 Blueprint Platinum CM
    Contemplating these Morimoto fogs or the Baja Squadron Rs. I know they are completely different. I do have these Morimotos on my wife's Forester XT Touring and they match the factory HIDs perfectly and have a great beam pattern.
  22. Feb 14, 2019 at 9:20 AM
    phabej
    phabej New Member
    NO LONGER HAVE A TUNDRA... Waiting
    i'd be interested but how much brighter are these XB FOGS TYPE T (14-19) compared to the stock ones? Does anyone have any photo comparisons?
    Stormtrooper81 likes this.
  23. Feb 14, 2019 at 11:59 AM
    eledobleu
    Orlando, FL
    Are you referring to the stock halogen or stock LED fogs 2018-2019?. If halogen, theres a comparison in the first group buy for this I did in 2017. I will locate it and post it here.
  24. Feb 14, 2019 at 12:15 PM
    SullyMoto19
    SullyMoto19 New Member
    Tyler
    Houston, Texas
    2017 Magnetic Gray SR5 5.7 4X4
    8" ReadyLift w/ ReadyLift and Bilstein Adjustable Coilovers w/ Reservoirs, 3" PA Body Lift, Fox 2.0 Shocks, 24x14 RBP Atomics (custom powdercoat Gloss Black), 40x15.5r24 RBP Repulsor, Relentless Fabrication Stealth bumper, N-Fab side steps, Bedlined/Paintmatched Honeycomb Grill, 2019 LED Headlights, 4 Backlit RBG Cubes, 16 RGB PlashLight Rocklights, 5% Tint & Brow, 2 10" Kicker CVT Subs with Kicker Amp in custom sealed box, Husky all weather floor mats, LED White interior bulbs
    Just purchased and installed 4 of the 3x3 cubes.. love them. I may look into this lightbar if I don't go the soundbar route!
  25. Feb 14, 2019 at 2:26 PM
    nowayout
    nowayout New Member
    NY
    17 CM
    Good to see you back. I have no idea of the pain you must be going through.
  26. Feb 14, 2019 at 3:41 PM
    eledobleu
    Orlando, FL
    Thanks! :amen:
  27. Feb 15, 2019 at 6:19 AM
    phabej
    phabej New Member
    LED, I have LED setup on the 2018 Sport.
  28. Feb 15, 2019 at 10:38 AM
    eledobleu
    Orlando, FL
    The oem led fog lights are good. I would suggest staying with those. The morimoto led fog lights are a better option for people with stock halogen fogs.
  29. Feb 15, 2019 at 11:13 AM
    phabej
    phabej New Member
    Thanks.. :)
  30. Feb 15, 2019 at 4:14 PM
    eledobleu
    Orlando, FL
    No problem buddy!
