Maple Syrup: Season 3
Discussion in 'Off-Topic Discussion' started by Pudge, Feb 5, 2019.
  1. Mar 26, 2019 at 4:01 PM
    #241
    buffaluphagus
    buffaluphagus —————————————
    How does this season compare to last?
    jewsNbrews likes this.
  2. Mar 26, 2019 at 4:09 PM
    #242
    Toyotoholic
    Toyotoholic -4Life-
    Jmz
    17' MGM
    Pro suspension, sways
    @Pudge do you still need help this year? I think I might be able to lend a few hours next weekend. (April 6-7).
  3. Mar 26, 2019 at 5:05 PM
    #243
    Pudge
    Pudge [OP] Super Secret Elite Member #7
    CT
    2015 Blue Ribbon Platinum
    Last year I made about 80 gallons of syrup. This year may be close to that. The issue with this year has just been I have taken on twice the workload and it really could have been more productive than it was. All in all itll be similar production to last year.
    Sunnier and jewsNbrews like this.
  4. Mar 26, 2019 at 5:06 PM
    #244
    Pudge
    CT
    Thanks buddy but I think I will be pretty much shut down this weekend... other than filtering and bottling syrup which I just do a little at a time once the season winds down. I really appreciate the offer.
  5. Mar 26, 2019 at 5:59 PM
    #245
    skidds
    skidds New Member
    MA
    2018 CM Platinum - Black
    sounds like you should have a Tundra meetup next season and put everyone to work!
    I would be happy to get my daughter from UConn and come help
  6. Mar 27, 2019 at 12:06 AM
    #246
    Sunnier
    Sunny
    San Diego, CA
    I'm sorry, Sean. Hang in there, Friend. :)
  7. Mar 27, 2019 at 9:51 AM
    #247
    Pudge
    CT
    Boiling away since 9 this morning. Got through a couple hundred gallons of sap ...of the 800 that is waiting to be cooked down. Trees are probably dripping like crazy right now. It's about 50° and sunny after a cold night. Perfect conditions but I can't go get it til I cook a bunch of what I have. On the bright side I have made about 4 gallons of syrup today
    Leo's first, Sunnier, JMB and 5 others like this.
  8. Mar 27, 2019 at 10:02 AM
    #248
    Pudge
    CT
    This os the front pan also called the syrup pan. Theres a thermometer in there that shows the temp of the syrup or soon to be syrup. Generally syrup is at the right viscosity at 7° above boiling temp of water, so around 219°. Some days it can be higher, today its about 221°. That's when I know to open the valve and start taking syrup out of the pans. As its pouring out I test it with the hydrometer which has a red line to indicate that it is indeed syrup. Pic of hydrometer and test cup which is coated in maple sugar, I love picking that off and tasting the goodness.
  9. Mar 27, 2019 at 10:08 AM
    #249
    Pudge
    CT
    This is the back pan, also know as the flue pan. You can kind of see the "flues" , the pan is essentially corrugated so it has a lot of surface area. Each flue is 8"deep and an inch wide and the flames and heat go through them on the way up the smoke stack. The majority of the cooking gets done here. If that pan was stretched out flat it would be 14 feet wide.
  10. Mar 27, 2019 at 10:09 AM
    #250
    Pudge
    CT
    So close!
  11. Mar 27, 2019 at 10:13 AM
    #251
    Pudge
    CT
    There is a steady flow of sap that comes from this stainless tank, through copper pipe and into the evaporator. I control how fast it comes in with a valve. I try to keep about an inch of liquid in the pans and have to constantly adjust valves to keep it right. I pump sap from the truck tank up to that stainless tank which is called a head tank or gravity feed tank
  12. Mar 27, 2019 at 10:19 AM
    #252
    jewsNbrews
    Jewiston Idaho
    2019 TRD PRO
    Bolt on
    That's so cool! Wish I was closer to help and visually see the process in action.
    Major and Pudge[OP] like this.
  13. Mar 27, 2019 at 10:20 AM
    #253
    TXMiamiFan
    Jose
    2016 White Crew Max TRD
    Is this the part of the process where you sit back with a beer and watch the magic happen?
  14. Mar 27, 2019 at 11:19 AM
    #254
    Pudge
    CT
    If you've got 2 guys running the evaporator then yup that's the time. Best part of the whole process. Unfortunately when you're all alone there too much to keep track up so not much sitting. I definitely need to simplify things here so I can have more time for that!
    driverdog, Migraine, Sunnier and 2 others like this.
  15. Mar 27, 2019 at 11:28 AM
    #255
    AZTundra
    Paul
    Phoenix, AZ
    Anxiously awaiting the sign up list for this. :thumbsup:
  16. Mar 27, 2019 at 11:59 AM
    #256
    dlos
    dlos Truckin'
    2019 Cement Off-Road
    Mods Mods Mods....
    I'm in, waaaaayyyyy at the back of the line, but in...
    jewsNbrews and silverhack like this.
  17. Mar 29, 2019 at 8:14 AM
    #257
    Pudge
    CT
    Out for what is likely the final day of sap collection. At least it's a good flow. Pretty much every bucket has looked like this.
    jewsNbrews, Sunnier, iHacker and 5 others like this.
  18. Mar 29, 2019 at 2:52 PM
    #258
    Pudge
    CT
    Ended up getting about 500 gallons today. This is very likely the last day of sap collection for the year. There is about 800 stored up at the sugar house and I really, really hope my brother boils it tonight and this weekend. I worked hard to get all that sap and I have to work all weekend and can't cook it. Its supposed to warm up quite a bit this weekend and will be very upset if the sap spoils, it's a lot of work to go get. He says he will boil it so I really hope he actually does.
  19. Apr 7, 2019 at 10:09 PM
    #259
    Pudge
    CT
    Well the season is done and over. Weather for too warm, buds started to form on the trees and the sap turned from sweet to it so sweet. So We stopped collecting sap last weekend and i got the last of it cooked Tuesday. Ended up right around 80 gallons. Just need to filter and bottle some. My brother was supposed to do some this weekend as I was booked up with stuff with my daughter, then she ended up getting sick so the weekend was a wash anyway. So a few weeks of filtering and bottling and I should be able to start taking orders.
    I do need a day to go pull the taps out and take my buckets home so I can start cleaning stuff.
  20. Apr 7, 2019 at 11:26 PM
    #260
    Boosted4runner
    Boosted4runner Join the NRA please.
    WA
    2015 DC MGM TRD Tundra, Kings, 5.7, 2018 front end
    Resi Kings, 35” Trail Grapplers on 18” Methods, ICON Delta Upper Arms, Front-Runner bed rack, Yakima SkyBox16, 2018 honeycomb grill, 2018 LED headlights, plastidipped bumper covers
    You sound like a busy man!
    That’s a lot of Fing work! lol
  21. Apr 15, 2019 at 1:15 AM
    #261
    Major
    Major TTC #0181
    Josh
    NC
    2017 CM Attitude Black Platinum
    Stock.
    Congrats on grinding it out! I wish I was a little closer to CT, I'd love to chip in and see the process, alot of work but sounds like fun. I'm in for an order for sure, I can't wait!!
    Pudge[OP] and jewsNbrews like this.
  22. Apr 15, 2019 at 8:53 AM
    #262
    RoujePN
    RoujePN New Member
    2019 Platinum CM 4x4 5.7L 1G3
    ^^What they say^^ Props to Sean!!:militarypress:
  23. Apr 24, 2019 at 4:37 PM
    #263
    Pudge
    CT
    I feel awful that I haven't updated this thread and haven't sent ant syrup out yet.
    My brother was supposed to make up for screwing the season by bottling the last 2 weeks, well he didn't and I haven't had time.
    He was also supposed to go take down the buckets from the trees and never did that either. So I did yesterday before they rusted out and got ruined. The metal buckets would cost at least $10 a pop to replace so I wasnt waiting for him anymore. I started cleaning them out today. This is about 1/3 of the buckets soaking, next is bleach, then power wash. Clean up sucks but someone has to do it.
    He says he will bottle this weekend, promises me that he will. If he doesnt then I will go next week and pack up all the finishing and bottling equipment and set it up in my garage. That's about a 4 hour process just moving and setting up. But having it at my house will allow me to bottle everything in a couple days. Everything is at the sugar house, aka my brothers barn now and bottling there is very tough for me because as the syrup is heating up you can not leave it, and heating can take 2-4 hours. At least at my house I could do other things as it heats and filters and check it now and then. When I do it there it's just a lot of sitting around.
    I apologize to everyone who is waiting and appreciate your patience. As it is, with him dropping the ball a few times I figure to have lost about 10 gallons of syrup from non productivity, which is a $1500 loss of revenue. I just hope to be able to serve my repeat customers and save my reputation and hopefully next year will go smoother.
    *edit* by return customers I mean 2 local stores and farm stands. I should be able to fill every tundras.com order whether you've ordered in the past or not :)
    OR18TRD, T-Rex266, Watt maker and 2 others like this.
  24. Apr 24, 2019 at 5:01 PM
    #264
    jewsNbrews
    Jewiston Idaho
    2019 TRD PRO
    Bolt on
    That's a bummer dude. Hopefully you can look back at it and realize it's a hobby and supposed to be fun and not a business venture. Reap the rewards that you get from the hard work this year and not focus on the what could have been scenarios. Remember your health and stress levels are more important than our orders. Wish I was closer as I would totally help out.
  25. Apr 24, 2019 at 5:04 PM
    #265
    AZTundra
    Paul
    Phoenix, AZ
    @Pudge That looks like some serious work to accomplish the end result. I haven't tried any in the past, but am hoping to this season (as long as you have enough to go around). If I wasn't so far away I'd offer to come and assist with whatever you needed, but from AZ it's a bit of a haul. Sorry to hear about the lost revenue - maybe bump up the cost a bit, even $1 or $2 per bottle would go a long way and I'm sure it wouldn't cause anyone not to purchase.
    Migraine and Pudge[OP] like this.
  26. Apr 24, 2019 at 5:05 PM
    #266
    TXMiamiFan
    Jose
    No pressure Sean. As others have said it’s a hobby. So don’t kill yourself over it. We will appreciate whatever you end up doing.
  27. Apr 24, 2019 at 5:07 PM
    #267
    JMB
    Chesapeake, VA
    2013 Super White Tundra DC
    Yeah take care of business like you need to. I have super mega advance alert set for this thread, so I'll see your order up post one hour before you post it.
  28. Apr 24, 2019 at 5:11 PM
    #268
    Squatting Pigeon
    Holden
    North Texas
    4Runner | GR Corolla
    You know we're all in support of you @Pudge! Do your best and it will be the best, that's all that matters. Hopefully the rest of the process goes smoothly for you sir.
    :cheers:
  29. Apr 24, 2019 at 6:48 PM
    #269
    Pudge
    CT
    Thanks everyone. I hope to keep my pricing thesame, with a possible slight up charge on the quarts. Will update as soon as I have some to ship.
  30. Apr 25, 2019 at 8:08 PM
    #270
    RoujePN
    RoujePN New Member
    ^^Ditto^^ Sean. Do what you need to, we understand everything you have gone through this year.. water leak included... Anyways let us know how we can help, hell just recycle the buckets and collectively we can certainly fund a new set of those fresh for next season. Sorry us newcomers appears we missed this seasons batch, but surely will be back in line for 2020. Cheers brother!!
    Migraine likes this.
