Map light replacement
Discussion in 'Lighting' started by stoshu73, Aug 4, 2018.
  1. Aug 4, 2018 at 2:51 PM
    stoshu73
    stoshu73 [OP] New Member
    Scott
    has anyone else have issues replacing the map lights? I have no clue how they go back in! Im dumbfounded!
  2. Aug 4, 2018 at 3:19 PM
    Baja Mike
    Baja Mike Baja Aficionado
    South Bay, Ca.
    2016 Tundra TRD 4x4 SR5 white
    LED interior lights, Baja Designs foglights, Baja Designs S8 hood bulge light bar, LED bed lights, Baja Designs S8 amber bar in bumper on Rago Fab mounts, AMP Research bedstep, Switch Pros sp-9100, tinted door windows
    Are you replacing them with LED bulbs?
    SouthBoundSteve likes this.
  3. Aug 4, 2018 at 3:19 PM
    Baja Mike
    South Bay, Ca.
    JINX!
  4. Aug 4, 2018 at 3:33 PM
    stoshu73
    Scott
    Yes I was GTR lighting leds
  5. Aug 4, 2018 at 3:39 PM
    Sas
    Sas Humor is everywhere
    OKC, OK
    '17 SR5 CM TSS 4WD MGM 5.7 FF
    Lost track after #1.
    EDIT: LOL, I promise I wasn't being a smartass here. I think I was thinking of the vanity lights when I wrote this.
    They just pop right in. If they don't turn on when you tap them to the leads then flip them over. Make sure the LED's are facing out of course.
  6. Aug 4, 2018 at 3:49 PM
    Sas
    OKC, OK
  7. Aug 4, 2018 at 3:50 PM
    Sas
    OKC, OK
    If it's not turning on then start your truck to reset the light timer.
  8. Aug 5, 2019 at 10:01 AM
    SkiCoach
    SkiCoach New Member
    Shane
    2017 Tundra CrewMax
    Gator Roll cover and wireless charger
    OK, I can use some help. while changing the bulb to LED I pushed up to hard and now the two prong socket is spread apart and up. I am guessing I need to take the whole console down? This suck, so far not impressed with the FyreFlys LED bulbs.
  9. Oct 7, 2019 at 8:30 PM
    deepblu89
    deepblu89 New Member
    2018 Barcelona Red Tundra
    I think I just did the exact same thing, also with FyreFlys LEDs. Did you figure this out?
  10. Oct 9, 2019 at 1:39 PM
    SkiCoach
    SkiCoach New Member
    Shane
    2017 Tundra CrewMax
    deepblu89 I followed the video in the this tread and took the map lite console down. you can see where the copper gets dislodged from the mounting pin. I pushed it back on the pin then inserted the LED bulb. You should test it before going through the reassembly process. Getting the reflectors in place was not an easy task either. Hope this helps.
  11. Oct 16, 2019 at 6:12 PM
    Diverpaul
    Diverpaul TRD ROXX
    Paul
    2016 White Tundra TRD Pro
    Fab Four front/rear bumpers, Warn VR12S
    That socket is so cheesy and easy to dislodge, its a joke...
    Ericsopa likes this.
  12. Oct 17, 2019 at 3:07 PM
    deepblu89
    yes it is... I managed to pull it back into place with a Leatherman well enough for it to work. It isn't normal but until I feel like performing major surgery on it, it'll do...
  13. Oct 19, 2019 at 3:52 PM
    Toyotafan97
    Toyotafan97 New Member
    Cody
    2013 Tundra TSS
    The previous owner had a bad LED bulb that I tried to change out. The prongs were bent all out of shape and I dislodged the socket while trying to get them shaped right... looped a piece of wire around one side to hold the prong in place, got the bulb to fit what felt like normal and got a few flickers. Still not working. Any tips on what i should do next?
  14. Nov 9, 2019 at 11:33 AM
    Pariverpirate
    Pariverpirate New Member
    Rich
    2015 Tundra TRD Off Road
    Non yet
    Just did the same damn thing ! Also blew the fuse and dont have a replacement. Off to walmart I go. Have to go get the new tires at 4:30 anyways.
  15. Nov 11, 2019 at 5:49 AM
    deepblu89
    Your guess is as good as mine with this stuff. I fought with it with the pliers on a Leatherman and was able to get mine into position well enough that everything works. If I manually press the lens cover to turn the light on and off it flickers so I know I don't have it completely right. It works well enough when I open and close the door though. If yours is too far gone to be rigged in place it might mean needing to have to buy replacement parts.
  16. Nov 11, 2019 at 6:16 AM
    Ericsopa
    Ericsopa Old man and the sea
    Sockets are flimsy. Only way to fix it right is to drop the overhead. Not difficult but a PITA. Even then, same thing might happen if you have to replace the bulbs again.
  17. Mar 21, 2021 at 9:26 PM
    dxchao23
    dxchao23 New Member
    mine broke off. anyone know how to repair it? can i solder it back? or are there replacement part? tia
  18. Mar 21, 2021 at 9:40 PM
    18-YOTA
    18-YOTA New Member
    2018 SR5
    Leveled Vleds Gator cover SCS wheels 275/70/18 toya at3
    I experienced this same thing. What I did was pull console down and glued housing back to console. Put some electrical tape on that as insurance. Then compared prongs to other side and bent them back to what looked normal. It’s hard to explain but once you take console down it will make more sense.. those tabs are so cheap. Good luck it’s a common issue. There should be more threads on it just search around. But best advise is to take console off and look on backside
    legiz and Steelerjax like this.
  19. Mar 21, 2021 at 11:05 PM
    dxchao23
    dxchao23 New Member
    is there a video on how to take it down? thx
  20. Mar 22, 2021 at 4:55 AM
    18-YOTA
    18-YOTA New Member
    2018 SR5
    There probably is. Utilize magnify glass in upper right corner to search. You can search forum a lot of your answers will be in this forum you just have to search for them. I don’t have one handy
  21. Mar 22, 2021 at 11:36 AM
    GhostCat
    GhostCat New Member
    Same thing happened to me....I pulled it out just enough for it to engage and start working but I'm afraid as I travel bumpy dirt roads, it's going to stop working or flicker like crazy.....Very annoying
    Also, I did not reinstall the reflector panels, I just left them off....
  22. Mar 22, 2021 at 12:01 PM
    dxchao23
    dxchao23 New Member
    mine actually broke off..i’m going to solder it and see if i can get it to work
  23. Mar 31, 2021 at 12:10 PM
    GhostCat
    GhostCat New Member
    OK, this is getting frustrating.....my lights keeps flickering if it comes on at all.....Is there not some kind of Electrical conducive "SHIM" we could add to fatten up the male connector and maintain the electrical connection?
