Manny's Vicarious Adventures
Discussion in '2.5 Gen Builds (2014-2021)' started by Black Wolf, May 16, 2015.
  1. Oct 25, 2015 at 8:51 PM
    #391
    Black Wolf [OP] Chillin' in Alamosa
    Dirtier
    TruckyTruck[QUOTED] likes this.
  2. Oct 25, 2015 at 9:34 PM
    #392
    csuviper
    Broomfield, CO
    2019 TRD Sport CM 5.7L 4X4
    Im liking this
  3. Oct 26, 2015 at 7:36 AM
    #393
    TruckyTruck
    TruckyTruck Dumbest Username
    Gary
    Matt can have his original post for his build, but the rest of his sand box belongs to us now! :bananadead::poking::proposetoast:
  4. Oct 26, 2015 at 4:34 PM
    #394
  5. Oct 28, 2015 at 6:42 PM
    #395
    Some un-official "mods" that I use when cold weather hunting:
    CAM00523.jpg Keen light weight waterproof/ -40 degree boots w/RedFeather 30" inchers
    CAM00524.jpg Ditto
    CAM00528.jpg Lil' Fiskars, sharp as hell
    CAM00527.jpg ToyTec ARB camp chair, Bullet proof, only $50
    CAM00525.jpg Ditto
    CAM00526.jpg Ditto
  6. Dec 2, 2015 at 6:26 PM
    #396
    Got bored so i plasti-dipped my white PIAA fog light covers. Build is pretty much on hiatus for anything serious until spring. I'll probably plasti-dip my license plates if I get too bored.
  7. Dec 3, 2015 at 5:47 AM
    #397
    csuviper
    Broomfield, CO
    Garage heater helps out a lot :)
    Similar to what I have
    Black Wolf[OP] likes this.
  8. Dec 3, 2015 at 5:50 AM
    #398
    csuviper
    Broomfield, CO
  9. Dec 3, 2015 at 5:11 PM
    #399
    I left out that I get a little lazy during winter. Other than the occasional show shoeing weekends, it's pretty much NFL, NCAA football, and killing brewski's. (oh, and saving up $ for more goodies)
    zcarpenter92 likes this.
  10. Dec 11, 2015 at 8:27 AM
    #400
    TruckLife900
    TruckLife900 I'd rather B hunting
    2013 White SR5
    Nice truck Matt! I've got some ideas churning after reading thru the build... just need some cash now :rolleyes:
  11. Dec 11, 2015 at 5:14 PM
    #401
    Thanks. We have the same problem. The money tree needs to bear more fruit. I'm blaming it on climate change or stupidity: upload_2015-12-11_18-13-4.jpg (China and India are excused from Obama's "world greening effort". The worst polluters on the planet. All is good. If we could only fix the climate, no more terrorists.
  12. Dec 14, 2015 at 2:41 PM
    #402
    I think there is a Toyota Prius Dealership in that picture somewhere. This pic is apparently not far from where they process the heavy metals used in the Prius batteries to help make it "green".
  13. Jan 17, 2016 at 6:06 PM
    #403
    Update on my OME set up 4 months later. I'm very satisfied so far. Some people have mentioned a hard/stiff ride with the OME coil overs. I was fortunate that I live 30 minutes from ToyTec. I was able to drive up to their front door , literally. After the ToyTec guru's looked at my Tundra, it was determined that the best route to go was with the heavy duty coils for the 4.6L for the best ride. I had the Ranch Hand grille guard which was about 110 lbs plus the weight differential between the 5.7L & the 4.6L to compensate for. Both coil overs were $635 assembled +tax. I paid another $400+ for install which included alignment by @LOTSOFTOYS and Jace's acute knowledge, (there was a stripped bolt issue ). Turns out that ToyTec knows what they are doing. I am not experiencing any too stiff/soft issues with the OME's. I couldn't be any happier with the setup. I take my truck to some pretty fracked up places. (Be more than happy to show you.) The difference is amazing compared to the TRD coil overs that I upgraded via Sean. I do know that the OME shocks are unique in the sense that they are 3 stage valved. Not as good as rebuildable remote reservoir shocks of course. If you are on a budget and want a decent upgrade without paying up the nose, the OME's are very decent mid-range value with proper setup. The OME setup is not a bad way to go. IMHO. The rear OME NitroChargers have also made a difference over the rear TRD Bilsteins by far. I may consider a remote reservoir setup for the rear at some point. I might want to mention that the new ToyTec Boss rear shocks were available at the time I purchased my OME rears. ToyTec still recommended me to go with the matching rear OME's. Price was not a factor since the OME rears cost the same as the new Boss rear shocks. I also mentioned that at some point I wanted to upgrade my rear springs. "Should I go with Deavers or ARB Dakars?" Once again the ToyTec guys said to go with the Dakars, only because the Dakars would truly complement what I already have. I will do the Dakar spring upgrade and at the same time get the SPC uca's to finish everything off this spring. Jace will do that too.
    TruckyTruck likes this.
  14. Jan 17, 2016 at 6:21 PM
    #404
    LOTSOFTOYS
    LOTSOFTOYS Toyota Whisperer
    Jace
    Mile high
    2005 Tundra DBL cab
    Once you get the Dakars and ucas, your truck will be set up
  15. Jan 17, 2016 at 6:26 PM
    #405
    Everything will come from ToyTec. Dakars are about $530 and if I remember right the SPC's are about $550. I'll push for a 10% discount from ToyTec since I build them up a lot here, for good reason. (Oh, and Stevenson West T.Com discount , heh heh)
  16. Jan 23, 2016 at 6:15 PM
    #406
    Was 60 degrees today so I decided to detail my Tundra, mainly to get rid of the Mag Chloride (MgCl2) that is used here to de-ice roads. Mag Chloride is not near as bad as salt (NaCl). Both are halides and very soluble in water. MgCl2 is not near as bad as salt but you still need to get it off your truck asap before corrosion kicks in. I wanted to point out some issues that I have with my Weather Tech liners. I forgot to take before pics but I'll try to explain my miss-givings with them.
    CAM00555.jpg As you can see, WTechs are designed to drain off any excess liquid out the door sill which is fine if it is just water. If you happen to live in cold climates were salt/MgCl2 is used, it can easily be brought in by your shoes/boots. This "could" be problematic over time. (As in eating away metal.) I'm not sure how long the WTechs have been in my truck but looked brand new when I bought my Tundra a year and a half ago. I wish I would have taken a before pic before I cleaned the crud off. You couldn't see "Tundra" on the door sill protectors with the white crusty MgCl2 that had built up over only a week or so with the "melt off".
    CAM00554.jpg This shot was taken after I wiped a bunch of crud off that had drained off the liners. Was actually pretty nasty looking. I just happened to take a gander at this area and realized that this could be an issue, especially if you never look there. Salt could easily corrode the metal over time. That's why I prefer a floor mat that traps liquid over a "liner" that doesn't. IMHO. The excess actually drains all the way out over the door sill and down below onto the side of the truck and onto my steps. This is only an observation. May not be a big deal for most of you but is to me. My Tundra was well taken care of before I got it and I intend to do the same thing.
    CAM00556.jpg Today was the "I hate chrome day"
    CAM00558.jpg Came out good. Not bad for an 07. Did an overall look around and found no leaks. Valve covers, oil pan, transmission pan, water pump seals good to go. Nothing abnormal underneath either.
    TruckyTruck and Sci-Fi like this.
  17. Jan 24, 2016 at 8:23 AM
    #407
    I forgot about the scuff plates. Good point.
  18. Jan 29, 2016 at 8:43 PM
    #408
    treborh 1941
    treborh 1941 New Member
    Tundra 5.7 V8
    Stock from factory
  19. Feb 7, 2016 at 11:01 AM
    #409
    Picked up a pair nifty magnetic leds at Walmart this morning for $4.97. The magnets appear to be strong enough and they came with lithium batteries. I suppose if you are a real cheap skate you could buy several pairs and do a poor mans light (lite) bar. Oh, wait..... Rock lights too!!!! :homer: :
  20. Feb 7, 2016 at 1:44 PM
    #410
    bobeast
    bobeast really old member
    Bob
    Hollister, CA
    2008 DC
    matluth, you're costing me a fortune. Great idea on the under-hood lights. I'm all over that.
  21. Feb 7, 2016 at 3:17 PM
    #411
    Update: Pics of my aftermarket installer with almost 1year (on Feb 23) of experience and a convenient place to store the lights until you need them:
  22. Feb 7, 2016 at 3:26 PM
    #412
    Super Bowl is starting with the USMC/NAVY F-18 Super Hornets Blue Angel fly by. All is good!!!!!!!!!!!!!! OOOOOOOOOOOHHHHH Rah!!!!!!!!! #1 Offense Vs #1 Defense : 9-2 for the #1Defense in the
    Super Bowl. Not too late to change your bet. Go Bronks!!! (Cam won't be easy to stop. If Bronks can't stop him ???????????
  23. Feb 7, 2016 at 5:11 PM
    #413
    Figures that Toyota's Super Bowl commercial is a Prius with dudes and they stop at an organic market. WTF?
    zcarpenter92 and Sci-Fi like this.
  24. Feb 7, 2016 at 9:13 PM
    #414
    zcarpenter92
    Zach
    NE Colorado
    2008 Desert Sand 5.7L DC
    In sig
    They should've done one with the Tacoma and Tundra. It didn't seem like there were many good SB commercials this year, or at least none that touched the "God Made a Farmer" commercial from a few years ago.
  25. Feb 8, 2016 at 6:09 AM
    #415
    monkeypuppybaby. sheesh At least Lady Gagme nailed the national anthem. That performance by her was not bad at all.
  26. Feb 8, 2016 at 6:37 AM
    #416
    csuviper
    Broomfield, CO
  27. Feb 8, 2016 at 8:08 PM
    #417
    bobeast
    Bob
    Hollister, CA
    2008 DC
    Nice. Do you happen to have any brand or model info for those? I looked on Walmart's site and could not find anything similar.
  28. Feb 8, 2016 at 8:16 PM
    #418
    You know, I tossed out the blister pack they came in. I'll stop by Walmart after work tomorrow and pick a a couple more pairs and post a pic for you.
  29. Feb 8, 2016 at 8:20 PM
    #419
    bobeast
    Bob
    Hollister, CA
    2008 DC
    Awesome. I spent a ridiculous amount of time trying to find something comparable.
  30. Feb 8, 2016 at 8:22 PM
    #420
    csuviper
    Broomfield, CO
    I like the free ones that harbor freight has some times. They are cheap at reg price too. Have a hook and magnet. [​IMG]
    Sci-Fi likes this.
