Making the door luck alert louder???
Discussion in '2.5 Gen Tundras (2014-2021)' started by Scotty Dive, Mar 26, 2019.
  1. Mar 26, 2019 at 4:14 PM
    Scotty Dive
    Scotty Dive [OP] New Member
    Connecticut
    After I installed then tech12volts remote starter, it's more important for me to hear the exterior beeping of the doors lock. Has anyone found a way to make it louder or possibly use the horn?
  2. Mar 26, 2019 at 4:19 PM
    ninjajay
    Spoolston, TX
    2018 MGM 1794 TRD 4x4
    There's a setting for it, my aftermarket head unit allows it, but not sure if OEM has it. The max volume unfortunately isn't super loud
  3. Mar 26, 2019 at 4:23 PM
    Cement
    Cement ...
    2019 Cement Trundra TRD
    +1 what Jason said, and no the OEM doesn't give access to that setting. But if you have access to TechStream, or Carista (mobile phone app + $20 bluetooth OBD reader) you can change it to max. Still not very loud, but better.
  4. Mar 26, 2019 at 4:27 PM
    GlobalGuy
    GlobalGuy GlobalGuy
    Buffalo, NY
    2018 Silver TRD Double cab
    Good lock with that!
    Ericsopa and rmvcard0303 like this.
  5. Mar 27, 2019 at 7:25 AM
    Scotty Dive
    Connecticut
    I was hoping there was a modification where you can get the unit replaced with something louder or use the horn somehow. My guess is that using the scan tool to increase the volume wont solve my problem of not hearing the lock / unlock
  6. Mar 27, 2019 at 8:05 AM
    Cement
    Cement ...
    Changing the setting is worth a try Scotty. Cheap and easy enough to do with Carista. And you get to configure a host of other things as well, and end up with a code reader/clearer to boot.
  7. Mar 27, 2019 at 8:06 AM
    Danman34
    Danman34 New Member
    Danny
    2018 White Tundra TRD Sport
    The volume for the beeps is in the settings on the radio. Mines loud enough for me to hear inside the house for my remote start.
  8. Mar 27, 2019 at 8:54 AM
    Scotty Dive
    Connecticut
    Its a good point. Any links to what I need to purchase? Is it a separate c able and separate software? And, does this mean my existing odb reader wont work on the Tundra?
  9. Mar 27, 2019 at 9:18 AM
    Cement
    Cement ...
    Search the app store on your phone for "Carista". Just download it for now.
    Pick up one of these (probably even find it at a local auto parts store or big box retailer?):
    https://www.amazon.com/Carista-Blue...words=carista&qid=1553703292&s=gateway&sr=8-2
    Plug it in, pull up the app and follow the prompts/instructions. Took me 30 seconds to get connected and viewing/changing settings on my iPhone.
    Carista lets you read codes for free forever. But they want to charge a monthly or annual fee to change settings. However, you get a free month with purchase of their dongle (linked above). So I made all my changes and then let the free month expire. Now its just a code reader, unless I decide to buy later 'cause I want to tweak settings again.
    Your existing code reader should work just fine. When done with Carista's dongle, you can unplug it and plug back in your previous. For me, I've just left mine in (hidden, never see it). That way if I throw a code I can just pull up the app and check it out right away. And I don't have to try and keep track of the dongle.
  10. Mar 27, 2019 at 10:47 AM
    Scotty Dive
    Connecticut
    and this works on your 2019? I ask because I see on the Carsita website that it only supports 2nd Gen (2007+)
    Can anyone CONFIRM that Carsita allows external sound adjustment and not just interior?
  11. Mar 27, 2019 at 11:01 AM
    Cement
    Cement ...
    Confirmed: used successfully on my 2019 SR5 DC.
    Confirmed: my beep volume upon locking/unlocking from the FOB is configurable in Carista.
    This might help. Another member went thru the trouble of taking screenshot of all Carista can configure:
    https://www.tundras.com/threads/carista-options.20601/#post-482167
    Edit: Actually wait one. I'm not seeing the beep volume setting in that thread. Let me go look and take some shots direct from mine. Give me a few...
  12. Mar 27, 2019 at 11:20 AM
    Cement
    Cement ...
  13. Mar 27, 2019 at 11:30 AM
    Law323
    Law
    Baton Rouge, La
    2012 4.6 L MGM DC
    Door “luck” alert??
    Bet they have that on Amazon, comes with a four leaf clover and “kiss me, I’m irish” shirt :spending:
  14. Mar 27, 2019 at 11:34 AM
    15whtrd
    15whtrd Mr. Blonde
    I looked for that one before I think that is just for the radio beep.
    On my tuner from bully dog I can turn on and off either the beep or the horn for the alarm. I can’t remember which one it was, or both LOL.
  15. Mar 30, 2019 at 2:24 PM
    Scotty Dive
    Connecticut
    I bought a Carista and although it does have a setting for the unlock door alert it is no different than the toyota adjustment that can made via the settings. So, for anyone interested in making the door alert louder, the Carista, although convenient is not the solution
    jtwags likes this.
  16. Mar 30, 2019 at 4:26 PM
    muisejt
    muisejt New Member
    2017 Sunset Bronze 1794 Edition 4x4
    Auburn LSD, TRD rear sway bar, LED interior lights, Weathertech floormats, Fumoto valve
    I got a pop n lock, the clunk from the actuator is loader than the beep
  17. Mar 30, 2019 at 5:33 PM
    jtwags
    jtwags Concrete jungle
    League City, TX
    2018 Tundra CM
    Undercover Elite LX, Xact Contour
    Yes it can be adjusted from stock HU. Many settings can be changed from the head unit using settings and vehicle customization. The truck needs to be running but here are pics of what Toyota allows you to adjust. You can adjust lock/unlock volume too.
    20190330_192646.jpg 20190330_192659.jpg 20190330_192703.jpg 20190330_192708.jpg 20190330_192705.jpg
  18. Mar 30, 2019 at 5:45 PM
    Sas
    Sas Humor is everywhere
    OKC, OK
    '17 SR5 CM TSS 4WD MGM 5.7 FF
    Lost track after #1.
    I might buy the Techstream if I can change it to this:
  19. Apr 4, 2019 at 8:44 AM
    Scotty Dive
    Connecticut
    So i am back to Square one. Anyone have an option to increase the external Door Lock/Unlock alert? I am wondering if I can swap out the existing alert with something louder. anyone know?
  20. Apr 4, 2019 at 8:50 AM
    NomadicFrog
    NomadicFrog Took 5 yrs, finally got rid of "New Member" here
    Mark
    Flagstaff, Arizona
    2003 Tundra SR5 4x4 TRD Off-Road Access Cab
    First mod: Gaffer tape over door lock/unlock beeper
    As somebody who lives in an apartment complex and whose bedroom window is about 10 feet from a parking lot full of 30 cars, I'd love to suggest "just listen for the sound of the lock solenoids".
    First thing I did when I got my 1st gen was find the thing that beeps when I lock / unlock and shove a wad of gaffers tape in it to mute it.
    ...although hearing "beep beep mutherf*cker" at 5am might be funny, at least the first couple of times.
    Edit: My previous vehicle's system was: push once to lock (silently) and push twice to hear a confirmation beep. I thought that was fine - beep if you need it, but otherwise don't. Maybe that's the way they all are these days? Anyhow, my 1st gen beeps with one push, and I feel bad - it's maybe a few feet away from somebody's head on a pillow.
  21. Apr 4, 2019 at 10:01 AM
    Scotty Dive
    Connecticut
    I live on acres of land and it wont be bothering anyone in the wee hours of the night or morning.
    NomadicFrog likes this.
