Magnuson Update Kit
Discussion in 'Performance and Tuning' started by Speedkills119, Aug 17, 2019.
  1. Aug 17, 2019 at 6:51 AM
    Speedkills119
    Speedkills119 [OP] Shenanigator
    Ryan
    2017 Silver Tundra 1794
    Mostly Stock Procomp 4" lift Prospeed cold air intake Bakflip bed cover HID head and fog lights 2000W JL Audio build Magnuson supercharger w/ Sniv Pulley AR Headers/full exhaust Auburn Limited Slip Prospeed fuel system w/ 1000cc injectors Dual 450 in tank fuel pump 2nd pump on a Hobbs boost reference switch Lexus RCF throttle body Prospeed catch can system TRD sway bar Prospeed Flex Fuel Tune Dirt Logic coil-over and shocks VR forged wheels CalTracs Nitto 420V 305/50R18
    I recently installed the SC and mine has some differences from a friend that did his about a year ago. They are both 2017 FFE engines. He’s had an issue with a “skip” at about 3/4 throttle. Based on the seat dyno the power is about the same.
    Here are the differences between his and mine.
    His has the Bullydog tuner mine has the HPTuner.
    His has stock injectors mine has new larger injectors that came with my kit.
    His has a pressure switch they call a VSV bypass. Mine does not and removes the relay.
    We talked to Magnuson about the differences and found out there is an update kit available under warranty. The kit upgrades the injectors, removes the Bullydog tuner for the HPTuners. It also removes the pressure switch. We installed it last night and the “skip” problem he had is gone.
    I wouldn’t say run out update if you aren’t having issues but there has to be a reason they’re updating it under warranty also.
    Gungho, ryanwgregg and airosey like this.
  2. Aug 17, 2019 at 8:21 AM
    dirtydeeds
    Keith
    USA
    more than I can list here
    Magnusson finally fixed it. That’s rad.
    Gungho and ryanwgregg like this.
  3. Aug 19, 2019 at 8:17 PM
    Gungho
    Gungho New Member
    Michael
    2019 Tundra TRD Pro
    I called them and they said they already have a 19 tundra that they are working on. My bet is end of this year or mid next year. Stay subscribed to their email and for sure it will come soon.
    dirtydeeds and MR TRD PRO like this.
  4. Aug 19, 2019 at 8:28 PM
    Danimal86
    Daniel
    Sacramento, CA
    2017 White Tundra SR5
    I wonder if it's still carb legal
    dirtydeeds likes this.
  5. Aug 20, 2019 at 5:43 AM
    Speedkills119
    Ryan
    I don't see why it wouldn't be. The kit I just installed is CARB legal and the update brings previous versions up to the spec of the current kit.
  6. Aug 20, 2019 at 6:39 AM
    LT75
    LT75 Seasoned Pro
    Saint Charles, IL
    No mods yet
    They told me the same thing back in June when I was trying to get it installed on my 2019 pre-delivery
