Magnuson Supercharger
Discussion in 'Performance and Tuning' started by alpinepro4, Aug 7, 2020.
  1. Aug 7, 2020 at 3:29 PM
    alpinepro4
    alpinepro4 [OP] What is your MPG Today!
    Pat
    2017 TRD Pro Cement DC
    Baja Designs Squadron Sport Fog lights, ARE CX Series Topper, Alcan Springs , DAP Tune, Coach Builder +1 Shackles, Headlight Revolution Supernova V.4 LED bulbs, HR LED interior bulbs. General Grabber ATX 275/70/R18
    I finally made the decision to start saving for Magnuson SC. I have been wanting to install one the past three years. Finally going to make it happen, hopefully sometime next year.
    When buying the SC I want to buy with handheld tuner right? I assume the handheld tuner a Bully Dog? There Unichip option as well, that any better then BD? I assume you have to have one or the other for the SC to run correctly. Once the SC is installed do I need to change the oil every 5K now instead of 10K?
    Platinum714 and AZTundra like this.
  2. Aug 7, 2020 at 9:33 PM
    AZTundra
    Paul
    Phoenix, AZ
    Took me almost 3 years to finally get mine. Magnuson recently moved away from Bully Dog and went to using HP Tuners. I had mine installed in February 2020 and got the HP Tuners version. I change my oil every 5k which is required on the flex fuel engine.
    I have a lengthy thread I started here before buying the Magnuson which may help you out. https://www.tundras.com/threads/supercharging-the-right-way.54678/
    Here are a few pictures.
  3. Aug 15, 2020 at 10:42 AM
    BrandonL812
    BrandonL812 New Member
    Brandon
    2017 Sequoia LTD
    Rx350 retrofitted, Morimoto Led fogs. interior and exterior leds swap. TRD drop in filter. Carbon filter delete. Led DRL panels. TRD Shift knob.
