Magnuson Magnum 2650
Discussion in 'Performance and Tuning' started by Fspmdt, Aug 8, 2023.
  1. Mar 30, 2024 at 6:26 PM
    #121
    Mdl
    Mdl Hey there...
    PNW, WA
    2007 TRD SC'd
    JBA Longtubes, Snivs 2.0 SC pulley, ASP crank overdrive pulley 6.71 in, DD Full 3inch dual exhaust, IPT valve body, Airbox mod, 4.5inch intake, Denso 750, 450 Walbro, W/M injection, GM 95mm TB, SABM, Camburg UCA, Icon shocks, Speedmaster LSD, Motive 5.29 Gears, Mickey Thompson Baja Legend EXP 35's, Solid Offroad engine and transmission mounts, DIY Traction Bars, Tuning by Snivspeedshop.com
    Also you may run a little richer, maybe .5-.8 more. I just backed off PE a little bit.
  2. Mar 30, 2024 at 10:51 PM
    #122
    VWTim
    VWTim Mid-Travel Crew
    Corvallis, OR
    This above... when boost referencing you'll need to tweak the tune a little bit.
  3. Mar 31, 2024 at 11:52 AM
    #123
    Fastzdriver
    Fastzdriver New Member
    Northern, VA
    2016 Tundra Crewmax TRD SC Magnuson TVS2650 @122k
    TRD Rear Sway Bars (2024) Rear Air Bags (2023) Magnuson TVS2650 Supercharger (2024) PowerTrax Grip Pro LSD (2024)
    Readings on the stock magnuson tune were actually better once I boost referenced the fuel pressure. Makes me wonder if it was designed to be run that way and it was just overlooked during installation.
    HulkSmurf14 and Ctaylor76 like this.
  4. Mar 31, 2024 at 12:00 PM
    #124
    Wynnded
    Wynnded What MPG...
    Rockies
    Souped up truck
    I've never noticed it mentioned in any of the instructions that I've read. :confused:
  5. Mar 31, 2024 at 12:04 PM
    #125
    VWTim
    Corvallis, OR
    Any chance you have some before and after datalogs? I'd love to see how it responds.
  6. Mar 31, 2024 at 12:34 PM
    #126
    Mdl
    Mdl Hey there...
    PNW, WA
    2007 TRD SC'd
    I believe it helped @ARES35 get his enrichment dialed in with more decent afr's.
    ARES35, Fastzdriver and Ctaylor76 like this.
  7. Mar 31, 2024 at 2:40 PM
    #127
    NatesNightMare
    NatesNightMare Is what it is
    Pinetop Az
    2018 Midnight black tundra S/C
    Pro comp 7", 35" tires, method wheels, brush guard, light bar, roof rack, pedal commander, magnuson 2650 supercharger
    Def not an overlook. It was never part of the installation process
    ARES35, Fastzdriver[QUOTED] and Mdl like this.
  8. Mar 31, 2024 at 5:47 PM
    #128
    Fastzdriver
    Northern, VA
    You're right. I just reviewed the instructions and it definitely specifically indicated connection to the boot barb. Just interesting that the numbers looked better after doing it from my logs.
  9. Mar 31, 2024 at 5:48 PM
    #129
    blenton
    blenton New Member
    Funny thing about the Whipple install.. the install instructions show the FPR referencing the intake pre-blower, but when I emailed them direct and asked about having it boost referenced, their reply was 'Yes, you definitely want it boost referenced'.
    ARES35, reywcms, Mdl and 2 others like this.
  10. Mar 31, 2024 at 5:49 PM
    #130
    Fastzdriver
    Northern, VA
    I do have logs from before and after, however no afr data yet as I still need my PSB-1 to arrive so I can install it and run another set of logs with that information as well before potentially retuning.
  11. Mar 31, 2024 at 6:38 PM
    #131
    NatesNightMare
    Pinetop Az
    Yeah I wanted to see how it was without it on the 76mm because on stock pulley not referenced I swear I was getting GREAT gas milage but when I put it back my afr never hit 10s so I BR again
    Fastzdriver[QUOTED] likes this.
  12. Mar 31, 2024 at 7:18 PM
    #132
    ARES35
    ARES35 New member for life
    Mile high
    Blown 2650 17 1794 Tundra 4x4 CM
    2650/750cc/76mm/SPD DP-DD exhaust/HP tuned
    I do have around 100 or so logs. Tried low pressure 50psi ffv non boost referenced and then referenced. Then 60 psi high pressure mode with jumper in relay box. Currently best combination is the high pressure mode jumper in the fuse box referenced. At the same time it was the hardest for me to tune. Had to dial in the MAF table alot for smooth fuel delivery to meet power enrichment values currently at 1.4/10.44. Also have throttle set to kick in at 30/28. Was at 25/20 but I was way to rich around 2500-3000 rpms when in throttle. I did have to eventually ramp down PE in lower regions from my flatline of 1.4..... I couldn't tune it so low out of closed loop to open loop without it injecting to much fuel. Tuning is an ongoing adventure. Just a weekend warrior tuner with a garage trying not to blow my shit up:hattip:
    Mdl[QUOTED], VWTim and helidave like this.
  13. Mar 31, 2024 at 7:29 PM
    #133
    Fastzdriver
    Northern, VA
    I'm going to hope @snivilous can keep me from blowing mine up when I move to the 76mm pulley :nuclear:
    Mdl and snivilous like this.
  14. Apr 3, 2024 at 3:25 PM
    #134
    NatesNightMare
    Pinetop Az
    His tune may help some to keep you out of the red but youll most likely have to get bigger injectors.
    Im hoping a tune will keep me safe when traveling into lower elevations and not have to swap pulleys everytime.
    Right now im pretty solid on kit parts, boost ref and the 76 at 7k ft. Hitting about 9psi
  15. Apr 3, 2024 at 3:46 PM
    #135
    Fastzdriver
    Northern, VA
    Injectors are next on my list. Not swapping the pulley until they are installed. I'm down at sea level so its way more critical I keep the fuel flowing, otherwise I'll just be inviting major problems. I'm just hoping the fuel pump from the Magnuson kit will be sufficient.
    NatesNightMare likes this.
  16. Apr 3, 2024 at 7:37 PM
    #136
    NatesNightMare
    Pinetop Az
    It may not be as someone else got the pulley and swapped the injectors yet still manages to max out fuel. I think hes looking into a pump next as well
  17. Apr 4, 2024 at 12:17 AM
    #137
    PannTher
    PannTher New Member
    Hey folks. Really appreciate this thread.
    I’m having a shop install a TVS2650 on the 18th. I’m not looking for crazy HP numbers but just some smiles per miles. My assumption was everything should be good to go out of the box to keep my 2013 engine as reliable as possible. From reading this thread, I’m confused if I should ask the shop to perform other modifications?
    Cheers!!
    Mdl, ARES35, Saltyhero13 and 2 others like this.
  18. Apr 4, 2024 at 6:25 AM
    #138
    snivilous
    snivilous snivspeedshop.com
    SW UT
    300k+ Supercharged 2008
    No, you should be fine out of the box. If you want more power than the stock supercharger then you'll start wanting to look at other modifications to maintain reliability.
    Mdl, ARES35, PannTher[QUOTED] and 2 others like this.
  19. Apr 4, 2024 at 6:34 AM
    #139
    nobodyintexas
    nobodyintexas What?
    South of Houston
    S/C'd 2020 White 1794 Tundra
    famous last words.
    reywcms, Mdl, ARES35 and 5 others like this.
  20. Apr 4, 2024 at 8:53 AM
    #140
    AZTundra
    Paul
    Phoenix, AZ
    It's highly recommended to get a custom tune otherwise you should be good to go until you start looking to make additional power.
    Mdl, ARES35, Saltyhero13 and 3 others like this.
  21. Apr 4, 2024 at 9:08 AM
    #141
    helidave
    helidave Hellacopter
    flagstaff
    2015 DC 4x4
    And a wideband O2 sensor would be a good idea
  22. Apr 4, 2024 at 10:29 AM
    #142
    NatesNightMare
    Pinetop Az
    Shits expensive, not everyone is loaded lol
  23. Apr 4, 2024 at 7:29 PM
    #143
    PannTher
    PannTher New Member
    Appreciate the replies. Thanks!
  24. Apr 4, 2024 at 7:41 PM
    #144
    ZPhilip
    ZPhilip Custom title here
    Philip
    West Chester, PA
    2015 Platinum Super White Crewmax
    Harrop supercharger, TRD Pro Fox suspension, CB +1 shackles, 295/70-18 Toyo ATIII, TRD Pro forged rims
    Smaller pulley with bigger injectors are also good ideas!
    nobodyintexas, Mdl, ARES35 and 2 others like this.
  25. Apr 4, 2024 at 7:59 PM
    #145
    helidave
    flagstaff
    2015 DC 4x4
    So the "stock" kit is just fine without modification and is all you'll need, except for a tune, wideband, exhaust, bigger injectors, and a smaller pulley. :rofl:
    PannTher, nobodyintexas, Mdl and 4 others like this.
  26. Apr 4, 2024 at 8:01 PM
    #146
    Fastzdriver
    Northern, VA
    Exactly
    Mdl likes this.
  27. Apr 4, 2024 at 8:08 PM
    #147
    ARES35
    Mile high
    I'd have to say, at least for me the stock kit was underwhelming after some ass time in the seat. At least at 5k+..... Maybe sea level it feels much more peppy idk
  28. Apr 4, 2024 at 8:56 PM
    #148
    helidave
    flagstaff
    2015 DC 4x4
    Stock pulley is much more impressive at lower elevations. The first time I went down to 1000' with mine it was ridiculous how much more powerful the truck felt. I think I ordered a smaller pulley as soon as I got home
  29. Nov 5, 2024 at 9:18 AM
    #149
    nasher75
    nasher75 New Member
    Erik
    Los Gatos, CA
    2006 Tacoma TRDS 4X4, 2021 Tundra LR TRD Pro
    I'd like to hear in cab audio with the Mag 2650. I actually want minimal supercharger whine noise in cabin. Some of the posts saying the 2650 is louder is giving me pause....
  30. Nov 5, 2024 at 9:22 AM
    #150
    nobodyintexas
    nobodyintexas What?
    South of Houston
    it is not louder than the 1900.
    it is terribly quieter.
    like you can barely hear it.
    and I run my 2650 (harrop) with a smaller pulley.
    ARES35, Wynnded, Silver17 and 3 others like this.
