Magnuson Magnum 2650
Discussion in 'Performance and Tuning' started by Fspmdt, Aug 8, 2023.
  1. Mar 29, 2024 at 9:28 AM
    #61
    Ctaylor76
    Ctaylor76 New Member
    Chaz
    Houston
    2021 Tundra Supercharged
    BDS 4.5 inch coil over lift BDS UCA’s 35 inch ridge grapplers AT 20 inch methods with offset 5.29 Nitro Gears ARB rear air locker with dual stage air compressor RC switch panel Both bumpers are RC LED Bumpers (6 pods and lower LED light bar) AMP Research power steps Lower RC Tow hooks B&M Transmission Pan CSF Radiator Radium Duel Catch Can BDS recoil traction bars Helwig adjustable rear sway bar Retrax Power Trax tunnel cover NSV LED front light bar Morimoto XB LED Head lights DOOD Rear smoked LED Tail lights (Amazon) NSLUMA Smoked 3rd brake light (Amazon) Morimoto 4 Banger LED A pillar lights Boostautoparts LED tow mirrors w/ power fold (smoked black) Full 3 inch true duel with XF Flowmaster mufflers custom Vbands Steelworks Longtube Headers RC seat covers OEM Audio plus full sound system duel sub 13 inch Phoenix Automotive In dash screen Stater X remote start system Uniden R8 Radar detector Odyssey Extreme Battery RC Seat Covers RC Rubber Mat Bed Cover Full body color door handles & TRD Grille OEM Magnuson TVS2650 Supercharger
    let us know , I am very interested to know how that specific tune looks because I actually have an MPVI as well and was looking to log the same way.
  2. Mar 29, 2024 at 10:46 AM
    #62
    Mdl
    Mdl Hey there...
    PNW, WA
    2007 TRD SC'd
    JBA Longtubes, Snivs 2.0 SC pulley, ASP crank overdrive pulley 6.71 in, DD Full 3inch dual exhaust, IPT valve body, Airbox mod, 4.5inch intake, Denso 750, 450 Walbro, W/M injection, GM 95mm TB, SABM, Camburg UCA, Icon shocks, Speedmaster LSD, Motive 5.29 Gears, Mickey Thompson Baja Legend EXP 35's, solid Offroad engine mounts, DIY Traction Bars, Tuning by snivspeedshop.com
    reywcms and Ctaylor76 like this.
  3. Mar 29, 2024 at 10:49 AM
    #63
    Ctaylor76
    Chaz
    Houston
    yeah so if you can log from it you should still be able to compare versus to what a real custom tune would look like correct ? Locked just means you can’t adjust it but if you plan on writing a new tune it still would be nice to know what magnuson actually tunes correct or is that false ?
    NatesNightMare likes this.
  4. Mar 29, 2024 at 10:59 AM
    #64
    Mdl
    Mdl Hey there...
    PNW, WA
    2007 TRD SC'd
    @carn_dogg @ARES35 what are the limits of the RTD from magnuson? Can you log from it and see the canned tune values?
    Thanks!
    Ctaylor76 likes this.
  5. Mar 29, 2024 at 11:05 AM
    #65
    Mdl
    Mdl Hey there...
    PNW, WA
    2007 TRD SC'd
    All I know is from reading on the SC forum where you can't see the tune. When writing a new tune HPt gives you a generic TRD tune based on your Vin or year. You can the build on that. You will also need a wide band O2 as the stock O2's only read to .82 lambda.
    Hopefully some other members will reply that used the RTD.
    Ctaylor76[QUOTED] likes this.
  6. Mar 29, 2024 at 11:15 AM
    #66
    Ctaylor76
    Chaz
    Houston
    yeah that makes sense, that RTD unit basically only designed to get things running not really meant to be logged from? I.e wide band install before hand, so if I had brand new headers probably would be smart to have a wide band installed before the collector?
  7. Mar 29, 2024 at 11:55 AM
    #67
    carn_dogg
    carn_dogg i don't think so
    Pat
    Eastern Shore MD
    2013 Black Tundra Platinum
    You can log from the rtd device but that’s it. Using vcm scanner.
  8. Mar 29, 2024 at 11:57 AM
    #68
    carn_dogg
    Pat
    Eastern Shore MD
    You can’t view the tune at all. It’s completely locked to anyone
  9. Mar 29, 2024 at 11:58 AM
    #69
    Mdl
    Mdl Hey there...
    PNW, WA
    2007 TRD SC'd
    carn_dogg likes this.
  10. Mar 29, 2024 at 12:26 PM
    #70
    Mdl
    Mdl Hey there...
    PNW, WA
    2007 TRD SC'd
    AEM is 18 inches and Innovate 24 inches from manifold. I have mine just before my primary cat and most aem and innovate user use the same location. Stock O2's just go in the header primary location.
  11. Mar 29, 2024 at 12:34 PM
    #71
    Ctaylor76
    Chaz
    Houston
    Yeah I am going to go with the innovate gauge on these.
    https://stainlessworks.net/headers-2014-toyota-tundra/
    With that 24 inch measurement do you know if that’s from the top of the manifold or the end?
  12. Mar 29, 2024 at 12:54 PM
    #72
    carn_dogg
    Pat
    Eastern Shore MD
    Of course man. If I see it, I’ll respond lol
    Fastzdriver likes this.
  13. Mar 29, 2024 at 1:02 PM
    #73
    Mdl
    Mdl Hey there...
    PNW, WA
    2007 TRD SC'd
    I'm not sure, but most just have the O2 bung welded in before the primary cat just after the collector flange. You just don't want it in the primary tube or too far away.
    Ctaylor76[QUOTED] and carn_dogg like this.
  14. Mar 29, 2024 at 1:10 PM
    #74
    carn_dogg
    Pat
    Eastern Shore MD
    Yeah right before the cat is logical and works for everyone as far as I’m aware. Just mount above 9:00/3:00 to avoid condensation on the sensor and you’re good to go.
    Mdl[QUOTED] and Ctaylor76 like this.
  15. Mar 29, 2024 at 1:18 PM
    #75
    Ctaylor76
    Chaz
    Houston
    sweet thank you @Mdl
    Mdl likes this.
  16. Mar 29, 2024 at 3:30 PM
    #76
    Fastzdriver
    Fastzdriver New Member
    Northern, VA
    2016 Tundra Crewmax TRD SC Magnuson TVS2650 @122k
    TRD Rear Sway Bars (2024) Rear Air Bags (2023) Magnuson TVS2650 Supercharger (2024) PowerTrax Grip Pro LSD (2024)
    Understood. I just did some logging with the RTD3 today for shits and grins. Just wanted to put it in the thread in case anyone who was considering the Mag 2650 SC they would know specifically what it comes with. I'll still be buying the MPVI3 and credits so I can get a tune from @snivilous once all my parts are in hand and installed.
    @carn_dogg What fuel pump are you running with your setup? My 76mm pulley arrived today and trying to get my complete list of parts finalized for the next stage of the build.
  17. Mar 29, 2024 at 3:39 PM
    #77
    Fastzdriver
    Northern, VA
  18. Mar 29, 2024 at 4:05 PM
    #78
    NatesNightMare
    NatesNightMare Is what it is
    Pinetop Az
    2018 Midnight black tundra S/C
    Pro comp 7", 35" tires, method wheels, brush guard, light bar, roof rack, pedal commander, magnuson 2650 supercharger
    Hes got the stock pump from the maggy kit. He did add 650 injectors recently. I believe he also will be getting a tune from sniv.
    I have the 76mm pulley on mine with all the reg kit parts and all ive done is boost reference my fuel rail. Carn is near or at sea level and im up 7k ft.
    One day if I ever get enough saved ill get the tools to get a custom tune from sniv also but thats quite a ways
  19. Mar 29, 2024 at 4:40 PM
    #79
    Fastzdriver
    Northern, VA
    Good to know. I was dreading dropping the tank.
  20. Mar 29, 2024 at 5:54 PM
    #80
    JustDSM
    JustDSM New Member
    Justin
    2023 Ford Raptor
    Just as an FYI, it is possible to write custom tunes via the RTD devices. You’re not locked into using what the Mfg. supplied.
    Overland Tailor can, we do it every day.
    Saves a significant amount of money using your existing hardware.
  21. Mar 29, 2024 at 6:17 PM
    #81
    Fastzdriver
    Northern, VA
    @JustDSM How much for a stock Magnuson 2650 remote tune for a 2016 Tundra?
  22. Mar 29, 2024 at 6:39 PM
    #82
    JustDSM
    JustDSM New Member
    Justin
    2023 Ford Raptor
    $425 for that setup, using the supplied RTD.
  23. Mar 29, 2024 at 7:16 PM
    #83
    Mdl
    Mdl Hey there...
    PNW, WA
    2007 TRD SC'd
    Ahh...after the 3rd or 4th time it's a cake walk!;)
  24. Mar 29, 2024 at 7:59 PM
    #84
    ARES35
    ARES35 New member for life
    Mile high
    Blown 2650 17 1794 Tundra 4x4 CM
    2650/750cc/76mm/SPD DP-DD exhaust/HP tuned
    Yes sir you can datalog but the tune is locked.
    Fastzdriver and Ctaylor76 like this.
  25. Mar 29, 2024 at 8:07 PM
    #85
    Fastzdriver
    Northern, VA
    Actually saw the TRD injectors maxing out at around 5600 rpm today which was a bit concerning. Definitely need a better tune until I'm ready to upgrade those and install the 76mm pulley.
    ARES35 and Mdl like this.
  26. Mar 29, 2024 at 8:39 PM
    #86
    Mdl
    Mdl Hey there...
    PNW, WA
    2007 TRD SC'd
    Its good that your at least logging and seeing the limitations on the canned tune.
    So many just load and go and don't realize it's not one size fits all. Some may not get into the upper rpm range but when they do it could cause a catastrophic failure under load as they are running out of fuel and lean out. Been there done that...
    ARES35 and reywcms like this.
  27. Mar 29, 2024 at 9:32 PM
    #87
    ARES35
    Mile high
    On stock tune I would see up to 11.5-12.2 A\F on WOT runs. Thus my personnel reason to switch to a MPVI 3 instead of the RTD tune.
    Mdl likes this.
  28. Mar 30, 2024 at 9:38 AM
    #88
    NatesNightMare
    Pinetop Az
    Have you boost refernced your fuel rail?
  29. Mar 30, 2024 at 9:38 AM
    #89
    NatesNightMare
    Pinetop Az
    @snivilous @carn_dogg
  30. Mar 30, 2024 at 10:01 AM
    #90
    Ctaylor76
    Chaz
    Houston
    what’s this exactly mean Nate?
