Magnetic gun holder install
Discussion in 'General Tundra Discussion' started by Sas, Aug 13, 2018.
  1. Aug 13, 2018 at 6:39 PM
    Sas
    Sas [OP] Humor is everywhere
    OKC, OK
    '17 SR5 CM TSS 4WD MGM 5.7 FF
    Lost track after #1.
    This one was pretty easy and the gun stays on there exceptionally well. It's held on by two neodymium magnets that are mounted to the side of the center console.
    You'll need to position your seat accordingly so the gun rests comfortably for you while you're driving. I shouldn't have to say this, but obviously the gun shouldn't be there if anyone else is driving. The magnets won't get in the way if the seat has to be moved up.
    Magnets (comes in packs of two):
    https://www.amazon.com/gp/product/B074BLMB22/
    Hardware (all bought at Home Depot):
    #8-32 x 1" flat head phillips machine screws
    #8-32 Nylon lock nuts
    1/8" x 1" Fender washers
    Before you start make sure the magnets will stick to the gun you're wanting to mount! Only one side really sticks so flip the magnet over if it doesn't seem to be grabbing. These magnets are pretty damn powerful so you'll know it when they do.
    Put the magnets on the gun and get a feel for where you want to mount it. Take your time on this and make sure the surface is flat so both magnets will be flush against the gun and fully engaged when the gun is attached. After you figure out where you want your gun to mount you need to approximate where the hole needs to be drilled. You'll need to pop the cover off of your center console so you can install the magnets.
    There are a couple of fins on the inside of the center console that may get in the way of the washer depending upon where your have your seat. Pay close attention to those and know where the washer can sit so you don't drill a hole in the wrong place.
    Use a drill bit that's just a little smaller than the diameter of the screw (I think I used 1/8", wasn't paying attention to the size). When you get your magnet and washer placement figured out drill a hole thru the center console, put the screw thru the magnet, put the washer over the screw on the inside of the center console and put the nylon nut on.
    Tighten it all down until it's really snug. You'll need a box wrench or pair of pliers to hold the nut while you tighten the screw. Do the same for the second magnet.
    That's it!
    Now that you're done playing with your gun (not a double entendre) go drink a beer/shot/keg!
  2. Aug 13, 2018 at 6:42 PM
    4x4_Angel
    Bree
    Funky Town, Texas
    2014 SR5 CM Silver Sky
    nice write up! Keep us posted on how well it holds up while driving
    Sas[OP] likes this.
  3. Aug 13, 2018 at 6:43 PM
    Sas
    OKC, OK
    About to go test it on some rough roads. Will post back later this evening.
    4x4_Angel and NewImprovedRon like this.
  4. Aug 13, 2018 at 7:47 PM
    Sas
    OKC, OK
    Oh yeah, short of being dropped off a cliff, it ain't goin' anywhere. Did a little urban wheelin' (found some parking space curbs in an abandoned parking lot and rolled over several of them), went down some crappy dirt roads, thru some closed off, heavy road construction, and it didn't budge, rattle, squeak or even think about jumping off. It had a full mag +1 in the chamber. I'm happy and very confident that it's going to hold no matter where I go. Plus I got to get the truck a little dirty as a bonus.
  5. Aug 13, 2018 at 8:24 PM
    BTBAKER
    BTBAKER .
    Brad
    Castle Rock
    2022 Ram TRX Level 2
    Very nice! Problem for me is I’m a south paw which means I would have to mount it shotgun side and let the wife drive and that’s not happening.
    B1GTR1X, SomeGuy4, stevep1794 and 3 others like this.
  6. Aug 13, 2018 at 8:29 PM
    Sas
    OKC, OK
    Lol, yeah I guess the lefties would have to learn to switch it to their left hand if mounting like that. You could mount it to the door pocket if you don't mind showing it to the world when you get out I suppose.
    4x4_Angel and BTBAKER[QUOTED] like this.
  7. Aug 13, 2018 at 8:32 PM
    BTBAKER
    BTBAKER .
    Brad
    Castle Rock
    I suppose I could learn to transfer hands.
    Very well done! I’m going to consider doing it. I may not have it there the entire time but I could definitely see it’s usefulness.
    4x4_Angel and Sas[QUOTED][OP] like this.
  8. Aug 13, 2018 at 8:54 PM
    4x4_Angel
    Bree
    Funky Town, Texas
    Practice shooting with your off hand....just a thought.always good to be able to shoot with both :)
  9. Aug 14, 2018 at 4:54 AM
    BTBAKER
    BTBAKER .
    Brad
    Castle Rock
    I keep telling myself that at the range but never put any time in it.
    SomeGuy4 and 4x4_Angel[QUOTED] like this.
  10. Aug 14, 2018 at 12:31 PM
    4x4_Angel
    Bree
    Funky Town, Texas
    It's awkward but worth the time put in. Practice drawing your gun with your off hand too...one day you may need to do it. Better to have the knowledge/practice and not need it than to need it and have no clue
  11. Aug 14, 2018 at 1:43 PM
    BTBAKER
    BTBAKER .
    Brad
    Castle Rock
    Bed it? What’s on your mind?:D
    NewImprovedRon and Sas[OP] like this.
  12. Aug 14, 2018 at 2:19 PM
    4x4_Angel
    Bree
    Funky Town, Texas
    Sleep....lol
    NewImprovedRon likes this.
  13. Aug 14, 2018 at 3:25 PM
    Patch999
    Kyle
    TX
    2017 Bad@$$ TRD Pro
    Did the same thing, same spot, just a different mag (and gun). I'm a lefty but had nearly the same set up in my Jeep for years because there was no room between the seat and the door. Just take a little practice. If I have time to change to my left I can probably drive away from the trouble.
    4x4_Angel, BTBAKER and Sas[OP] like this.
  14. Nov 24, 2018 at 3:52 PM
    dw8494
    dw8494 New Member
    Lefties - mount to the bottom/under side of steering wheel area. As for shooting with your off hand, for sure should always practice every now and then. Also try to rack with your opposite hand - or just rack only using one hand (hint - use the heel of your shoe/boot).
    k11white37, 4x4_Angel and Patch999 like this.
  15. Dec 29, 2018 at 9:10 PM
    Textoytun
    Textoytun New Member
    2019 Blacked Out GST SR5 4x4 CM
    Anybody mount inside the console? That way, i could leave it in there.
  16. Dec 30, 2018 at 4:43 PM
    plumber802
    plumber802 New Member
    Andy
    Florida/Vermont
    2018 White Platinum CM
    That location defeats the purpose of the weapon being readily accessible.
    whodini12 and Patch999 like this.
  17. Dec 30, 2018 at 8:32 PM
    Textoytun
    In Texas, it has to be concealed. I figured in the console box would be close enough to reach and get target acquisition in time.
  18. Dec 30, 2018 at 9:07 PM
    Tundra Fan
    Tundra Fan Got 17's?
    Toby
    Nor Cal (Placer Co.)
  19. Dec 30, 2018 at 9:17 PM
    Textoytun
  20. Aug 22, 2019 at 8:44 AM
    DireWolf
    DireWolf The Dark Lord - Tundra Owner
    North East Florida
    2016 Dark Gray Tundra SR5 (MGM)
    none
    Question, Glocks being made of composite material will they work with the magnets?
  21. Aug 22, 2019 at 8:53 AM
    Gotyour6
    Gotyour6 New Member
    Fairport, NY
    2019 Tundra Pro
    They have metal in them.
  22. Aug 22, 2019 at 9:25 AM
    Omen
    Omen New Member
    Everything in the slide except stock sights is metal.
  23. Aug 22, 2019 at 10:12 AM
    Sas
    OKC, OK
    The slide on composite pistols is ferrous metal. That's how I'm attaching my RP45. It would be the same for the Glock, et al.
  24. Aug 22, 2019 at 10:17 AM
    Sas
    OKC, OK
    It's been a year and my 45 w/a full mag has never even thought about falling off. I haven't done any jumps or anything ridiculous w/the truck, but the gun has endured some pretty rough trails.
    4x4_Angel[QUOTED] likes this.
  25. Aug 22, 2019 at 12:57 PM
    DireWolf
    North East Florida
    none
    Thank You all.
  26. Aug 22, 2019 at 2:37 PM
    4x4_Angel
    Bree
    Funky Town, Texas
    Sweet! Thank you for the update!
  27. Aug 22, 2019 at 2:47 PM
    Angry Gunny
    Angry Gunny New Member
    Rob
    Bedford, PA
    2016 SSM 1794 4X4
    Yes please
    Awesome write up Sas, any chance these magnets would work if they were mounted behind the plastic?
    Sas[OP] likes this.
  28. Aug 22, 2019 at 3:10 PM
    Sas
    OKC, OK
    Hard to say, but you're likely going to mar up the plastic over time if you need to take the gun on and off.
  29. Nov 11, 2019 at 7:09 AM
    ZPMAN
    Minnesota
  30. Nov 11, 2019 at 8:01 AM
    Sas
    OKC, OK
