Magnetic Gray Metallic-MGM (1G3) Picture Thread
Discussion in 'General Tundra Discussion' started by 14tundra, Nov 22, 2016.
  1. Oct 8, 2017 at 11:34 AM
    #361
    borntostun
    borntostun New Member
    Lots.
    Placed the TRD Dual on yesterday. Several parts on order . . . Revolver X2 with BakBox; Amp Research Bed Extender; Driver Side Handle . . . already got the TRD Shift Knob in there. ;). Working on the sway bar today . . .
    Likely going with the Bilstein level (5100) all around and 1" block in the back for a slight rake . . . Toyota hasn't released the specs to vendors yet, so the Bilsteins and the Amp Research PowerSteps are sort of on pause for a bit.
    Once all of that is completed . . . I'll start thinking about a tire size up or so . . .
    What am I missing? ;).
  2. Oct 8, 2017 at 12:31 PM
    #362
    SoCalDave
    SoCalDave New Member
    Dave
    2016 DC 4x4
  3. Oct 8, 2017 at 12:36 PM
    #363
    Brimaster
    Brimaster New Member
    2017 Magnetic Gray Metallic DC TRD
    Joined the club....
  4. Oct 8, 2017 at 9:48 PM
    #364
    Chief_Will
    Chief_Will New Member
    James
    Colorado Springs, CO
    2015 MGM CM
    Couple of pics from today’s run up Pikes Peak.
    99CAA41A-2A8E-4DD3-ACD3-8A6CD96A33D8.jpg A9C525B2-1038-4AD0-A77A-ABF5E0C9B459.jpg C166C82A-D4A6-4930-A37E-54E0E4772E0E.jpg
    Big J, The Juice, GAknight and 6 others like this.
  5. Oct 8, 2017 at 9:58 PM
    #365
    BayRunner
    2017 Tundra Platinum
    Very sharp looking!
  6. Oct 9, 2017 at 2:22 AM
    #366
    :thumbsup:
    Akrapovic1199 likes this.
  7. Oct 9, 2017 at 2:23 AM
    #367
    :thumbsup:
  8. Oct 9, 2017 at 2:23 AM
    #368
    :thumbsup:
  9. Oct 11, 2017 at 7:02 AM
    #369
    Akrapovic1199
    Akrapovic1199 New Member
    2017 Mag Gray Tundra TRD
  10. Oct 11, 2017 at 7:06 AM
    #370
    :headbang:
    Akrapovic1199[QUOTED] likes this.
  11. Oct 29, 2017 at 6:13 AM
    #371
    Ps3udonymous
    Ps3udonymous Who is the smart ass that changed the title?
    Good looking truck, what lift did you use? How do you like it?
  12. Oct 29, 2017 at 6:57 AM
    #372
    War_Wagon312
    War_Wagon312 Puddle Dodger
    Rich
    2025 sequoia MGM TRD PRO
    Stock horse
    Just got some tires.
    Bdebs, THOR's, Mhorst1 and 9 others like this.
  13. Oct 29, 2017 at 6:57 AM
    #373
    :headbang:
    War_Wagon312[QUOTED] likes this.
  14. Oct 29, 2017 at 7:49 AM
    #374
    Akrapovic1199
    Thanks man! I used the Radflo/Toytec Performance 3" lift but instead of the shackles in the rear, I went with 1.5" blocks.
    I like it a lot! The tires rub a little bit in reverse and sometimes going forward in a tight turn while compressing a bit so I'm planning to do the body mount chop here shortly.
    Ps3udonymous[QUOTED] likes this.
  15. Oct 29, 2017 at 8:05 AM
    #375
    Ps3udonymous
    Are the blocks better than the shackles?
  16. Oct 29, 2017 at 8:09 AM
    #376
    Akrapovic1199
    Just a personal preference, I can't answer if they are better.
    How I see it : To me, moving the springs upwards with a block and throwing in U-bolts seems much safer in the long run than extending the mount point for my leaf springs and additional horizontal stress.
  17. Oct 29, 2017 at 8:16 AM
    #377
    Ps3udonymous
    That makes sense. What size tires are you running? And did you buy the pro wheels or paint the off road ones?
  18. Oct 29, 2017 at 8:19 AM
    Akrapovic1199
    I'm running the BFG 35x12.5x18. I had the off road ones powder coated matte black to match the Tundra badging which is a matte and gloss and then threw on the TRD pro hub caps to match the gloss.
  19. Oct 29, 2017 at 8:20 AM
    #379
    Ps3udonymous
    Sweet. You do the normal cutting?
  20. Oct 29, 2017 at 8:22 AM
    #380
    Akrapovic1199
    Thanks! Yup, trimmed the front mudflap pretty much off and the front fog light bumper area down quite a bit as well. I'm getting ready to put on color matched front bumper caps soon so I'll be out there trimming again... :)
  21. Oct 29, 2017 at 8:27 AM
    #381
    Ps3udonymous
    The 35's fit without a cmc?
  22. Oct 29, 2017 at 8:42 AM
    #382
    Masshole
    Masshole Lovin' The Great North Woods
    New England
    2014 DC MGM 4X4 SR5 TRD
    The leaves are changing color in this picture. Most on the ground now. :(
  23. Oct 29, 2017 at 5:05 PM
    #383
    Akrapovic1199
    CMC?
  24. Oct 29, 2017 at 5:18 PM
    #384
    Ps3udonymous
    Cab mount chop
  25. Oct 29, 2017 at 5:21 PM
    #385
    Akrapovic1199
    Ah okay. Funny you mention that... I'm going to do the body mount chop soon since my buddy owns a welding shop but I've only rubbed once going forward and a sharp turn. In reverse, turning slightly and compressing, it definitely rubs the mount every time.
  26. Oct 29, 2017 at 5:23 PM
    #386
    Ps3udonymous
    Ahh ok. That's sweet. I want to go for a look similar to yours. I have been searching to find one and yours has been the closest to what I've been imagining. Thanks for your patience through my interrogation
  27. Oct 29, 2017 at 5:26 PM
    #387
    Akrapovic1199
    Happy to help and thanks! I definitely like the look!
    If you're looking to same money, I'd recommend the Toytec 3" lift that doesn't have the external rear reservoirs and Radflo up front. My buddy has it on a 2016 and I've ridden in his truck a bunch and it is just as capable and a few hundred cheaper.
  28. Oct 29, 2017 at 5:32 PM
    #388
    Ps3udonymous
    Is that one worth the extra money vs. The toytech/eibach?
  29. Oct 29, 2017 at 5:38 PM
    #389
    Akrapovic1199
    I think the Toytec/Eibach is just as capable but I'd definitely give Toytec a call. They always have someone knowledgable on hand when you call
  30. Oct 29, 2017 at 8:16 PM
    #390
    mlucas555
    mlucas555 New Member
    Mark
    San Antonio, Tx
    2016 MGM Double Cab
    Still rocking the stock height.
    Just noticed that I had not posted on this thread.
