Lug nuts for Method NVs
Discussion in 'Wheels & Tires' started by smslavin, Aug 27, 2017.
  1. Aug 27, 2017 at 12:37 PM
    smslavin
    smslavin [OP] Behind a lens...
    Hudson Valley
    2016 Tundra CrewMax SR5
    Some stuff
    i knew i was missing something. what size lug nuts do i need for method NVs?
  2. Aug 27, 2017 at 4:12 PM
    chphilo
    chphilo Tundra addict
    Western PA
  3. Aug 27, 2017 at 4:33 PM
    smslavin
    Hudson Valley
    Some stuff
  4. Aug 27, 2017 at 4:41 PM
    TheBeast The Beach
    I might get a set too. switching from chrome lug nuts to black :)
  5. Aug 27, 2017 at 5:26 PM
    BlueBottle
    BlueBottle not a PRO
    '16 Platinum 4x4
    See fine print
    These seem to be better quality
  6. Aug 27, 2017 at 6:45 PM
    PMG
    PMG New Member
    Amazon tuner lugs in black.
  7. Aug 27, 2017 at 7:09 PM
    Tundra_mike89
    Tundra_mike89 New Member
    Michael
    South Texas
    2016 TUNDRA CM 4x4
    Toytec boss coilovers Toytec shackles Total chaos uca's Method wheels Nitto ridge grapplers
    I got some nuts 4 u
    TheBeast and BlueBottle like this.
  8. Aug 27, 2017 at 10:57 PM
    TheBeast The Beach
  9. Aug 28, 2017 at 7:35 AM
    osidepunker
    osidepunker OsidePunker
    Alex
    2013 Tundra DC 4x4
    Full LT, full armor, fully self contained Speed Glamper
    DO NOT GET THE ET LUGS
    The lip can break off and get stuck on the stud. Then you can't get the wheel off. I've seen it in person (on the Mojave rd) and know at least 3 guys it's happened to
    The correct way to do it is to use the conical seat lugs and get longer studs for proper thread engagement.
    SC_TRD and BlueBottle like this.
  10. Aug 28, 2017 at 3:13 PM
    BlueBottle
    '16 Platinum 4x4
    See fine print
    I've heard that. Dustin over at FN Wheels told me he designed his wheels with deep pockets so you can use regular conical lugs on his wheels without getting extended studs. One reason I went with his wheels. I been running his wheels with regular conical lugs with no issues. Knock on wood*
    osidepunker[QUOTED] likes this.
  11. Aug 31, 2017 at 9:23 AM
    TheBeast The Beach
    FYI the Camburg I just got are the same ones (same box too)..for $15 cheaper..
    Sniperinhisname and Rica25 like this.
  12. Aug 31, 2017 at 4:35 PM
    TheBeast The Beach
  13. Jan 9, 2018 at 4:33 PM
    Flyinryank
    Flyinryank New Member
    Ryan
    Las Vegas, NV
    White 2015 CM 4x4
    What lugs/studs do you run?
    I have method nvs and the mugs that 4wp gave me. Trying to avoid any issues.
    How are these?
    http://store.sdhqoffroad.com/ToyotaTundraBlackSplinedLugNutKit-1.aspx
    Rica25 likes this.
