Lug nuts for black rhino wheels?
Discussion in 'Wheels & Tires' started by junior, Dec 16, 2019.
  1. Dec 16, 2019 at 8:54 PM
    junior
    junior [OP] Member
    Zach
    Santa Cruz, CA
    2016 Tundra TRD Off Road
    Black Rhino Rapid 17" 35x12.5 Mickey Thompson Baja Boss Fox Performance Elite 2.5 DSC at 3" with Coachbuilder 1/4" shim on driver side JBA UCAs Fox Performance Elite 2.5 DSC rear shocks Dobinsons HD Leaf Springs Firestone Airbags + Daystar Cradles Prinsu Cab Rack 2024 Four Wheel Camper Project M Camper Mods: Goal Zero Yeti 4000 house battery 200w solar IceCo fridge Truma Propane Heater
    Hi everyone,
    I'm excited to get my Black rhino Arsenal wheels installed, however I think I ordered the wrong kind of lug nuts: https://www.4wheelparts.com/p/pro-comp-24-piece-14x1-5-lug-nut-kit-black-16144b/_/R-BKBQ-16144B
    They are too long for the cover to fit over them and also the wrong type I think. Additionally, the bolt holes on the wheels don't look like the OEM TRD off road lug nuts will fit.
    From this thread I found that I actually need M14x1.5 "ET" nuts... however I'm having a hard time finding a set. Is this correct? If so, does anyone know of a good place to order some?
    https://www.tundras.com/threads/lug-nuts-on-aftermarket-wheels.23671/
    Thanks for any help
    Texas_artist and Darkness like this.
  2. Dec 16, 2019 at 9:18 PM
    junior
    junior [OP] Member
    Zach
    Santa Cruz, CA
  3. Dec 17, 2019 at 8:27 AM
    junior
    junior [OP] Member
    Zach
    Santa Cruz, CA
    Thanks for the reply. Those lug nuts look identical to the ones I already bought, the cone seat is correct. I think the threads won't go down far enough? In my case its also the length of the entire nut is a bit too long but I think thats because of the design of the Arsenal wheel (the center cap cover)
  4. Dec 17, 2019 at 8:58 AM
    Scuba
    Scuba Sober member
    Austin, Tx.
    2012 Texas Edition CM.
  5. Dec 17, 2019 at 9:31 AM
    Grendel
    Grendel New Member
    2016 Quicksand TRD PRO
    I just had the arsenals put on at discount tire. While they were swapping them out They put the new lugs on. I'm not sure what they are but I can look after work
    junior[OP] likes this.
  6. Dec 17, 2019 at 7:04 PM
    Scuba
    Scuba Sober member
    Austin, Tx.
    Probably Bimmec. I would have suggested that but the OP didn't say he was getting anything done there.
    I feel weird pimping out lugs vs wheels/ tires.
    But yes, Discount Tire/ Americas Tire will have or can get the lugs you need to install any wheels you have. :thumbsup:
    Most lug nut kits we have range from $35 to $55.
  7. Dec 17, 2019 at 7:08 PM
    unclebeejo808
    unclebeejo808 New Member
    Oahu
  8. Dec 17, 2019 at 7:18 PM
    Scuba
    Scuba Sober member
    Austin, Tx.
    I know the lugs on the front of a tundra are short but, I really don't think the closed end short ET lugs will work.
    I think they will bottom out on the stud inside.
    Hence why I posted the open ended ones.
  9. Dec 17, 2019 at 7:31 PM
    unclebeejo808
    Oahu
    I use them on my xd series rims.
  10. Dec 17, 2019 at 7:50 PM
    Grendel
    Grendel New Member
    These are the ones they put on mine6CC6D107-AED9-4DB1-97F3-E5F5C62C3BC6.jpg3BBA412C-6011-4DC0-B364-3AFF7BA5D10F.jpg
  11. Dec 17, 2019 at 8:09 PM
    Scuba
    Scuba Sober member
    Austin, Tx.
    I stand corrected then. :thumbsup:
    Those would be Gorilla.
    unclebeejo808[QUOTED] likes this.
  12. Dec 17, 2019 at 9:56 PM
    junior
    junior [OP] Member
    Zach
    Santa Cruz, CA
    Thank you everyone! This is exactly what I was needing help with. Really appreciate it.
  13. Nov 6, 2020 at 7:09 AM
    TRDProser
    TRDProser New Member
    Eric
    Ohio
    2017 Black SR5 Crewmax
    Diamondback bed cover. TRD Pro grill
    Hey junior, which lug nuts did you end up getting? I just bought arsenals and the first set of lug nuts I got were wrong.
  14. Nov 6, 2020 at 7:33 AM
    junior
    junior [OP] Member
    Zach
    Santa Cruz, CA
    I ordered the ones that Scuba linked to in post #4. They work just fine and lucky enough the arsenals cover them up with the cap.
    You could easily get the closed end version though, since the studs arent even close to the end of the open-ended ones
  15. Nov 6, 2020 at 7:44 AM
    TRDProser
    Eric
    Ohio
    Awesome, thanks! Love these rims. How have yours held up?
