Lug nut removal without key
Discussion in 'Wheels & Tires' started by cctxquicksand, May 3, 2021.
  1. May 3, 2021 at 5:31 PM
    cctxquicksand
    cctxquicksand [OP] IG - TRDistheWrd
    This is a tricky one, trying to remove a set of rays Duranuts but I can’t find my key! I’m sure it will turn up in a day or two when I no longer am itching to mount these bad boys
    but let’s just say I don’t find it... what then? I have tried fitting a socket and jamming with a hammer but the lock is seven sides so no parallel sides for it to lock onto and it was super soft and was rounding the edges. I tried chiseling it but the aluminum is just too soft. I had discount tire try with there fancy lug removal kit and same results too soft to grip. Tried chiseling a slot of a screwdriver but... nothing... am I really going to have to drill these out of do you guys know a trick?
    Not a lot of room to work with here and really trying not to damage these pricey wheels
  2. May 3, 2021 at 5:35 PM
    15whtrd
    15whtrd Mr. Blonde
    Hammer a 12 point socket? It looks like you’re already starting to jack up the wheel. Keep looking for the key!
    cctxquicksand[OP] and MentalBill like this.
  3. May 3, 2021 at 5:41 PM
    FortyNorth
    FortyNorth New Member
    Northern ON
    2014 Tundra Super White SR5
    The redneck option, assuming you have access to a welder, is you can weld a large nut or bar to it. It will probably mean some scorch marks. There is also a tool that tire shops use, it will trash the lug but will come off. But pretty cheap service generally and probably your best bet.
  4. May 3, 2021 at 5:55 PM
    If you had the key code for the lock the manufacturer could sell you a replacement key. I had to do that with a McGard lock a couple of years ago.
    TTund16 likes this.
  5. May 3, 2021 at 6:00 PM
    Hightide
    chadington von banks
    Abalama
    Magic School Bus
  6. May 3, 2021 at 6:08 PM
    ScenicRoute
    ScenicRoute New Member
    2021 Tundra CM Nightshade
    Eibach stage 2 (JUNK), SmartCap, Airbags, CoachBuilder Stuff, Bora spacers, 35” falken AT3W tires.
    He did mention it was “soft aluminum” weld a steel nut to an aluminum lug?
    I’d also say he is past the trashing the lug point based on the pictures.
    cctxquicksand[OP] likes this.
  7. May 3, 2021 at 8:33 PM
    cctxquicksand
    This idea may work I’ve never seen one this thin walled but I’d need one a bit bigger. I had to hammer on a 20mm socket and it would probably have to be either a universal or a 12 pointer. Thanks for the suggestion I’ll look into finding one
    probably going to try a few tire places before work tomorrow I can’t be the only one this has happened too. I just don’t know if I trust old tire tech joe to be careful with my gramlights.
    Hightide[QUOTED] likes this.
  8. May 3, 2021 at 8:36 PM
    cctxquicksand
    The key code is in the key :mad:
    I was talking to showstoppers offroad and apparently Ray’s makes 16 different keys and you have to show proof of purchase to get a replacement from mackin industries.
  9. May 3, 2021 at 9:12 PM
    1lowlife
    DADA
    THE GREAT STATE OF TEXAS
    2014 MGM DC SR5
    You might try the Toyota dealership.
    They forgot to give me my key back a few years ago after a tire rotation.
    I went back the next day and they had a box full of lug keys.
    Found one that fit mine and gave it to me....
    I have TRD spine lugs and locks now.
    Ordered a second key when I bought them.
    One is in the console, one is in the swing case..
  10. May 3, 2021 at 9:18 PM
    Cruzer
    Cruzer Wheeling Full Size
    Cruz
    Sunnyvale, CA
    I lost my key and just ended up using the closest size socket and just hammering it on, worked pretty good - has to be tight. Lugs nuts are useless anyways since you don't have the key so destroying them to get them off shouldn't be an issue.
  11. May 3, 2021 at 10:17 PM
    Toyotoholic
    Toyotoholic -4Life-
    Jmz
    17' MGM
    Pro suspension, sways
    The dealership will have the means of removing it. They deal with that sorta thing every day. Also any tire shop will have a "lug lock remover" it's a tapered socket you hammer on designed for your type of problem.
    Hightide likes this.
  12. May 3, 2021 at 11:07 PM
    thearborbarber
    thearborbarber New Member
    SoDak
    2018 Tundra SR5
  13. May 6, 2021 at 6:31 PM
    cctxquicksand
    Another day of no luck. Tried multiple tire shops and no one would touch them. Bought a couple different lug nut removers from auto part stores and nothing can bite.
  14. May 6, 2021 at 6:33 PM
    cctxquicksand
    the lug nut currently...
  15. May 6, 2021 at 6:45 PM
    Cruzer
    Cruz
    Sunnyvale, CA
    That sucks.
    Last resort is to drill through the lug nut and drill out the stud. Use progressively bigger bits. First hole needs to be dead center.
  16. May 6, 2021 at 7:05 PM
    CodyP
    CodyP Such a n00b
    Cody
    CDA, ID
    2006 Tundra 4x4 DC
  17. May 6, 2021 at 7:10 PM
    Bob_Wiley
    Bob_Wiley I feel good, I feel great, I feel wonderful...
    Eric
    AZ
    2016 Black SR5 Crewmax 5.7 FFV
    Well, on the plus side I guess you know the lugs worked as advertised...still, that sucks!
  18. May 6, 2021 at 7:21 PM
    ScenicRoute
    That sucks. I guess if I didn’t care about the rim I’d just burn it off. I think you need a slightly larger socket to hammer on. The scuff marks don’t look like they go deep enough to get a good purchase on what’s left.
    MS22 likes this.
  19. May 6, 2021 at 7:36 PM
    cctxquicksand
  20. May 6, 2021 at 7:36 PM
    cctxquicksand
    I was thinking the same but yeah it does suck
  21. May 6, 2021 at 7:41 PM
    CodyP
    CodyP Such a n00b
    Cody
    CDA, ID
    2006 Tundra 4x4 DC
    But you could measure your lugs and that would narrow it down.
    Also, the code is on the lug near the bottom. Get a light and scope around for the number, then buy that key
  22. May 6, 2021 at 7:44 PM
    cctxquicksand
    I ordered the one that was closest to what I have... shipping was more than the key itself
    thanks for link
    CodyP likes this.
  23. May 6, 2021 at 7:45 PM
    CodyP
    CodyP Such a n00b
    Cody
    CDA, ID
    2006 Tundra 4x4 DC
    Here’s hoping :fingerscrossed:
  24. May 6, 2021 at 7:46 PM
    cctxquicksand
  25. May 6, 2021 at 8:18 PM
    Kanobi13
    Kanobi13 New Member
    Seem like good lug nuts anti theft
  26. May 13, 2021 at 4:20 PM
    cctxquicksand
    KWC, CodyP, biebs96 and 1 other person like this.
  27. May 13, 2021 at 10:35 PM
    CodyP
    CodyP Such a n00b
    Cody
    CDA, ID
    2006 Tundra 4x4 DC
    @cctxquicksand you lucked out with ordering the correct one?!?!? Sweet
    glad it worked out for ya buddy!
    KWC likes this.
