Lubing Propeller Shaft Yoke?
Discussion in '1st Gen Tundras (2000-2006)' started by zech, Mar 30, 2022.
  1. Mar 30, 2022 at 6:27 PM
    zech
    zech [OP] New Member
    2006 Maroon Tundra 4WD DC
    So I just greased all the zerk fittings, 8 total, on my 4WD. But the 2nd to last zerk fitting towards the rear, what I understand to be the Propeller Shaft Sliding Yoke took like 10+ pumps of grease and still no squeeze out.
    Where does the grease go? How do I know when to stop?
    It's the joint labeled B below.
  2. Mar 30, 2022 at 6:38 PM
    Johnsonman
    Johnsonman New Member
    Austin
    Sequoia
    My understanding is 3 pumps Max and don't insert so much to expect it to ooze out, that is causing damage and is old school approach, let it go and simply lube more often keeping to the 3 pump limit. Luck.
  3. Mar 30, 2022 at 6:42 PM
    shifty` All my rowdy friends have settled down
    FirstGenVol, bmf4069 and zech[OP] like this.
  4. Mar 30, 2022 at 7:38 PM
    zech
