LSD or not?
Discussion in '1st Gen Tundras (2000-2006)' started by Doughnut, Dec 8, 2022.
  1. Dec 9, 2022 at 12:33 PM
    w666
    w666 D. None of the above
    Maryland
    04 Access Cab SR5 V8 4WD
    Use an impact wrench (I think it's 22 mm) and it should be OK
    Jack McCarthy and FrenchToasty like this.
  2. Dec 9, 2022 at 12:51 PM
    Jack McCarthy
    Bill
    North of Boston
    02 Tundra AC SR5 V8 4x4
    I’ve yet to hear of anyone who damaged the threads getting a 22 mm plug out. Just make sure you open the fill before drain and have new plugs to replace the old ones. Spray it down with PB blaster for a few days to put your mind at ease.
    w666 and Riverdale21 like this.
  3. Dec 9, 2022 at 12:54 PM
    DesertRoads
    DesertRoads Telecom Guy
    Utah's West Desert
    2005 DC SR5 V8 4WD LSD & TOW PKG
    LED Lights Galore. Mostly Stock
    Looks like your rear diff could use a good power washing/wire brush, and a fresh coat of Rustoilum paint. Every new to me truck I get I thoroughly check the frame and diffs, do a light sanding and spray paint them with anti rust paint once yearly--as I live in a state that gets snow. Helps them last longer.
  4. Dec 9, 2022 at 1:19 PM
    Abos
    Abos Long live 5.7L V8
    2014 SR5 Crewmax
    LMFAO!!!:rofl:
  5. Dec 9, 2022 at 1:20 PM
    Jack McCarthy
    Bill
    North of Boston
    That thing needs a hammer and a die grinder with a wire wheel attachment to make it decent enough to paint with a rust encapsulator.
  6. Dec 9, 2022 at 1:52 PM
    MEWaters
    MEWaters New Member
    Maine
    07 2UZFE; previous 02 AC 323k
    Poor OP
    We want pics of drained fluid and magnet when you get there!
    bmf4069 likes this.
  7. Dec 9, 2022 at 3:37 PM
    bmf4069
    Beau
    TX
    02 AC sr5 4wd v8
  8. Dec 10, 2022 at 8:24 AM
    tvpierce
    tvpierce Formerly New Member
    Maine
    Also a New Englander here. That rust is really bad... I would do something about it this weekend -- seriously! It's so easy to treat it before it starts leaking, and nearly impossible after it starts leaking. If you ignore it I would expect the diff will be leaking by spring.
    Jack McCarthy likes this.
