LSD Issues
Discussion in 'Towing & Hauling' started by wawaski, Jan 29, 2018.
  1. Jan 29, 2018 at 6:33 AM
    wawaski
    wawaski [OP] New Member
    2004 Tundra ext cab
    Vehicle Modifications:
    At 60K I had my previous dealership change the diff oil in my LSD rear end. It got to shuddering when turning left from a stop, and my new mechanic put ears on the wheels and found the noise was coming from the diff. After looking at the info on the service tag, they found they didn't put the called for additive in it. They did that, and the noise/vibration went away. Now after about 3K it's back. Am I looking at a rebuild? Gear damage perm?
    Thanks!!!!
  2. Jan 29, 2018 at 6:41 AM
    Patriot
    Patriot Member
    Western NC, “Boondocks”
    Welcome from Western NC, Post up pics of your Tundra!
    What year?
    :worthless:
  3. Jan 29, 2018 at 6:48 AM
    tundraj
    tundraj New Member
    Guess I'm showing my age. Was expecting some sort of LSD rehab discussion.
  4. Jan 29, 2018 at 6:50 AM
    Eclipsed & Floating
    I’m right where I need to be
    Voluptuous Whitey
    I was hoping for fractals
    Wynnded and HBdirtbag like this.
  5. Jan 29, 2018 at 6:52 AM
    Noodle
    Noodle That Guy
    Files creek
    2016 Tundra Limited TRD DC Inferno
    Sounds like damage to me, does it sound like the gears are “slapping” together? Especially when making turns? Any posi rear requires a friction modifier additive or posi lube as us old guys call it. If it wasn’t added and you put 3k on it the damage is probably done unfortunately. If it was done at the dealer and is documented you should be covered IMO.
  6. Jan 29, 2018 at 7:24 AM
    HBdirtbag
    HBdirtbag New Member
    Walnut Creek, CA
    2017 limited cm
    BWAHAHHHAH........memories.....i mean flashbacks
  7. Jan 29, 2018 at 7:31 AM
    Eclipsed & Floating
    Voluptuous Whitey
    Right?
    HBdirtbag[QUOTED] likes this.
  8. Jan 29, 2018 at 7:46 AM
    I saw this thread title and was thinking OP was having a bad head trip :anonymous:
    tundraj and Eclipsed & Floating like this.
  9. Jan 29, 2018 at 7:48 AM
    Eclipsed & Floating
    Voluptuous Whitey
    Bwahahahahaha!!!!!!
    @coosbaybaker
  10. Jan 29, 2018 at 7:48 AM
    blue16
    blue16 New Member
    steve
    Mesa AZ
    2016 tundra
    Welcome from AZ. With the LSD you need the additive and from what I have read you have to use a certain type of oil like a non synthetic oil or synthetic oil.
  11. Jan 29, 2018 at 8:26 AM
    831Tun
    831Tun heartless Bastrd
    Warren
    Santa Cruz
    '16 CM limited
    Welcome from Ca.
  12. Jan 29, 2018 at 8:57 AM
    Darth Tundra
    Curt
    17 CM TRD Black
  13. Jan 29, 2018 at 11:16 AM
    alalmcgrath
    alalmcgrath Old Fart at Large!
    Al
    Boulder Creek Ca
    2016 SEQUOIA SR5
  14. Jan 29, 2018 at 11:21 AM
    alalmcgrath
    Al
    Boulder Creek Ca
    2016 SEQUOIA SR5
    Unless you have an aftermarket differential you don't have an LSD.
    Limited slip in the Tundra is simulated by using brakes on the rear wheels to control wheel spin.
  15. Jan 30, 2018 at 9:34 AM
    15whtrd
    15whtrd Mr. Blonde
    He has a first gen. I think they came with an LSD if im not mistaken.
    831Tun likes this.
  16. Jan 30, 2018 at 9:35 AM
    831Tun
    Warren
    Santa Cruz
    '16 CM limited
    That's what I seem to remember. At least I remember the salesman telling me something like that.
    15whtrd[QUOTED] likes this.
  17. Jan 30, 2018 at 9:40 AM
    AxelsHumanDad
    AxelsHumanDad Get off my lawn.
    KAIG, NW of The Frozen Tundra
    2015 CM Platinum
    Some suspension tweaks
    My '03 and '06 both had it factory.
    blue16, 831Tun and 15whtrd[QUOTED] like this.
  18. Feb 2, 2018 at 5:20 AM
    wawaski
    2004 Tundra ext cab
    Thanks for all the replies! I got the ball rolling starting with the original service center. Thanks Noodle!
  19. Feb 2, 2018 at 5:39 AM
    1UPPER
    1UPPER Not A New Member
    TEXAS
    Flux capacitor!
    Glad to hear you got some resolution to this. If you happen to have an Auburn LSD. I called them when I had mine done and they recommended 80-90 Weight oil with additive.
  20. Feb 2, 2018 at 6:06 AM
    OBXTundra
    OBXTundra Member
    Southeast USA
    2018 Nissan Armada, 4x4
    Had a factory LSD in my Superduty. Changed diff oil and added the recommended amount of the additive. After driving around for 15-20 minutes I noticed slight chatter in parking lots and slow speed turns. Pulled the fill cap, let a little oil drain out, and added 2 more ounces of the additive. Never had another issue.
    They can be pretty finicky about the type of oil, type of additive, and amount of additive. I wouldn't say the damage has been done, but you should get it checked out. Chances are a fluid change and replace with correct oil/additive will do the trick.
    speedtre likes this.
  21. Apr 3, 2018 at 6:29 AM
    wawaski
    2004 Tundra ext cab
    Thanks to all who posted, after 3 calls to the Toyota help line, the results were disappointing. They couldn't get the dealership to return their calls, nor did the dealer return mine. surprise. Toyota told me they couldn't force the dealer to step up even though it was their fault, suggested BBB, social media etc. So, my calls to Toyota were basically wasted. Just thought I'd let everyone know in case they had any issues.
    Aggravated.....
    wawaski
